Author Topic: Effect of plate on tune?  (Read 1820 times)
Offline 10centNickle
« on: Sat, 20 March 2021, 12:14:28 »
Do different plate materials affect tune?  Des thickness of a plate affect tune?
Re: Effect of plate on tune?
« Reply #1 on: Sat, 20 March 2021, 13:03:57 »
Yes, the plate material affects the sound profile. Some materials are stiffer than others.
Thicker plates are stiffer and transfer more sound into the case but they are uncommon both for that reason and because they are more involved to make and thus more expensive.
The way the plate is mounted in the case also makes a difference.
There are quite a few plate sound comparison videos on Youtube. Here's one:
Offline Leslieann
« Reply #2 on: Sat, 20 March 2021, 22:56:37 »
A whisper in a loud room goes unnoticed but the same whisper in a silent room sounds like a shout.
If you have a noisy board, clicky switches factory lube, you might be able to identify it when listening for it specifically or side by side but is it worth the effort, probably not. On the other hand, if you have a solid aluminum board fully lubed with foam and silent switches, absolutely.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
