Author Topic: [IC] Butterfly Mats// desk mat designs  (Read 3594 times)
Offline Becky| TOTL
  • Formerly Butterfly Mats
« on: Fri, 26 March 2021, 14:00:36 »
Introducing the "Stratosphere" desk mat design.
Looking for opinions on what I would change or add.
Would you buy?
https://imgur.com/EtxiVX0
https://imgur.com/VsyzlIp
https://imgur.com/IP35tUU
Offline Harue
Re: [IC] Butterfly Mats// desk mat designs
« Reply #1 on: Fri, 26 March 2021, 15:07:13 »
Why didn't you continue on this post? https://geekhack.org/index.php?topic=111923.0  ;)
Offline treeleaf64
    • treeleaf64
« Reply #2 on: Fri, 26 March 2021, 15:13:43 »
Yes but now they want to know if they should change anything or if we are going to buy it. So they made a different post instead of commenting on the original thread.
Bad Butterfly mat
Everyone must pay the cat tax
Offline Ustinj
« Reply #3 on: Fri, 26 March 2021, 15:17:02 »
Not to be offensive, but the mats aren't good at all. They look like they were done with only a few days of experience dabbling in Photoshop/Illustrator/Inkscape. There is nothing particularly attractive about the design, other than the charm of it being 'so bad it's good' like a lot of memes are nowadays... but it dances on that boundary so closely that you can't really tell if it's intentionally bad (charming and requires some skill / talent) or if it's a trying attempt - which makes it a hard pass from me.
IMO, you either have to work a lot on the design to make it a lot better, or dumb it down to make it a lot worse. It's pretty bad as it is, but I can't tell if it's intentional. So the intent is unclear. Good luck
Offline Baka Bot
« Reply #4 on: Fri, 26 March 2021, 15:20:44 »
Would you buy?
No.
Offline Faehriss
« Reply #5 on: Fri, 26 March 2021, 16:20:51 »
This feels like low effort blobs made in MS paint as the background with some default wordpad text katakana thrown on top. Then, in the bottom corner theres a butterfly that looks exactly like the doodles my little brother does in birthday cards. So honestly, no, wouldn't buy.
church of the POM keeb
Offline SDKCAMPING
« Reply #6 on: Fri, 26 March 2021, 16:43:50 »
It doesn't look professional or good  but i give you props for  at least doing your own work instead of using google images :D
« Last Edit: Sat, 27 March 2021, 15:26:06 by SDKCAMPING »
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline Chippy
  • sus chef
« Reply #7 on: Fri, 26 March 2021, 18:08:25 »
I feel like this is one of the most jumbled IC's I have seen in a while. Why did you post on multiple threads, why aren't the images embedded into your post or at least in the same album? I'm not really a big fan of them personally but I feel like you should work on your presentation.
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
