Author Topic: [IC] Whi65 | Round 2 Prototpyes Ordered | (9/4/2021 Update)  (Read 130557 times)
Offline billy.types
« on: Sat, 10 April 2021, 11:01:18 »
Whi65
A 65% gasket mounted keyboard
Discord | Instagram
Let us know if you are interested in this board and if you have any feedback: >> IC Form (CLOSED as of 7/25/2021)<<
Hey everyone, we are two friends who are passionate keyboard hobbyists, and we also happen to be engineers. We started our company, 383 Boards, to bring our numerous years of product design and engineering expertise to the keyboard space.
With that, I present to you our very first board, the Whi65.
The biggest inspiration for this keyboard has been my Betta fish whose name this keyboard takes on, Whi. This fish, who refuses to die, has been with me for a very long time and has inspired the weight and badge designs. Whi was named after Kawhi Leonard in remembrance of him helping the Toronto Raptors win a NBA championship in 2019. Toronto has always been our home and we wanted to pay homage to the city and its basketball team, thus you will see subtle allusions to the Raptors logo as well as the hexagon corners of the board that represent the 6ix.
0. CONTENTS
  • DETAILS
  • STATUS
  • VENDORS & PRICING
  • PHOTOS
  • SOUND TEST
  • FAQ
1. DETAILS
  • Isolated plate gasket mount
  • Sleek screw-less assembly
  • Typing angle: 7.0°
  • Front height: 19.5mm
  • Materials: 6061 Aluminum housings, Sandblasted brass weight, spacer, and badge
  • Mass: ~2.0kg (total), ~0.5kg (weight)
  • Plates: Aluminum & Polycarbonate (FR4 & Brass are being considered, TBD)
  • PCB: Mill-max hot-swap and soldering versions - configurable with QMK/VIA, ESD protection
  • Layout options:
    The soldering version of the PCB will support a variety of layout options: ANSI, ISO, split Left Shift, split Backspace, and stepped Caps Lock
    The hot-swap version will only support the ANSI layout.
  • Color options:
    E-White   |   Black   |   E-Lilac   |   Deep Blue
    All colors are meant to be as close to reality as possible. There may be some discrepancies between these renders and actual production units.
Design Revisions from V1 prototypes:
The following design changes were made after using and testing out the V1 prototype board as a daily driver. These changes will be tested in the second round of prototypes:
  • Gasket strips have been made wider going from 2.5mm to 4mm to allow for easy application
  • The space between the PCB and bottom case has been increased from 1mm to 2.5mm, to give more room for the board to flex without bottoming out
  • Screws were added to the mid spacer to allow for an easier assembly
  • Switched from Phillips M1.2 screws to Torx M2 screws to give more durability
  • Plates were updated to add "leaf spring" type cuts around the edges to allow for easier flex
  • The weight's mounting design also had to be updated to accommodate for the above changes
2. STATUS
First round of prototypes were delivered 05/06/2021, PCBs were delayed but were delivered 05/26/2021. We are currently in the process of putting together the board and creating some sound tests that will be uploaded to this thread soon.
Start Interest check Opened April 10, 2021
Order prototypes Ordered April 15, 2021
Test prototypes for appropriate sound profile and fitment Tested and made minor design revisions July 03, 2021
Announce Vendor partners  Announced July 22, 2021
Finalize color options Original 4 colors finalized
Order R2 prototypes Ordered Sept 3, 2021
Test R2 prototypes
Send Prototype boards out to content creators
Finalize design and close interest check
For more regular status updates be sure to join our discord server
3. VENDORS & PRICING
Vendors
  • USA - Space Cables
  • CA - Ashkeebs
  • EU - Mykeyboard
  • UK - Proto[Typist]
  • SEA - Zion Studios
  • AUS - DailyClack
Pricing and Number of Units
  • TBD
4. PHOTOS
V1 Prototype
Renders
  • E-White renders:
  • E-Lilac renders:
  • Deep Blue renders:
  • Black & Gold renders:
5. SOUND TEST
6. FAQ
  • Estimated GB Date?
    Late 2021 Q4 - Early 2022 Q1
  • How is the GB going to be run? Is it going to be FCFS, Limited, or Unlimited?
    It will be a limited FCFS group buy. Number of units per region is still TBD
  • Estimated Price?
    No price yet, a few of our manufacturers are standing firm on not providing us mass production quotations till after our second prototype run is complete. This is due to the fast changing material prices and the global chip shortage. They want the quotation to GB date window to be smaller, which is understandable in today's market. Apart from speaking to manufacturers, we also need to speak to all our vendors and make pricing agreements with them once we have the quotations. Thus at this time we will not be releasing a price. It will only come after proto2 is completed.
Banner:
If you like to show support for this IC and our design, please do so by adding the following to your signature:
Code: [Select]
[url=https://geekhack.org/index.php?topic=112229.0][img width=480 height=120]https://i.imgur.com/hKb4Cyp.png[/img][/url]
Thanks for taking the time to read through this, we appreciate any comments, suggestions or feedback you may for us. Don't forget to fill out the IC form as well!
« Last Edit: Tue, 21 September 2021, 19:31:21 by billy.types »
Offline billy.types
Re: [IC] Whi65 by 383 Boards, Gasket Mount Keyboard Kit
« Reply #1 on: Sat, 10 April 2021, 11:06:37 »
Change Log / Updates
  • April 10, 2021 - Started Interest Check
  • April 10, 2021 - Updated OP with total and weight masses
  • April 13, 2021 - Changed front height from 19.5mm to 21.5mm, updated masses accordingly
  • April 14, 2021 - Hot swap and soldering versions of the PCB confirmed
  • April 15, 2021 - First set of prototypes ordered, expected delivery ~3 weeks
  • April 26, 2021 - Finalized layout and PCB options, will have support for both hot-swap and soldering PCBs. Different layout options supported on the soldering version
  • April 29, 2021 - R1 of prototypes completed by the manufacturer, shipped and enroute to us. Expected to receive them May 5th
  • May 11, 2021 - Prototype V1 pictures added to Original post, PCB delivery has been delayed
  • May 25, 2021 - PCB delivery was made, in process of building the board and creating some early sound tests
  • June 15, 2021 - Initial sound test of board posted
  • July 3, 2021 - Design Revisions made
  • July 22, 2021 - Vendors announced
  • July 25, 2021 - IC Form closed
  • Sept 4, 2021 - Estimated GB data updated to end of Q4 2021 or early Q1 2022. GB will be limited FCFS, updated FAQ accordingly.
« Last Edit: Sat, 04 September 2021, 17:44:21 by billy.types »
Offline FishyKeebs
  • hey
« Reply #2 on: Sat, 10 April 2021, 11:14:40 »
That lilac would go really nice with Kat pbj
Offline hello21
« Reply #3 on: Sat, 10 April 2021, 11:30:03 »
I love fish, will probably cop one for my GMK Coral set.
Can you please share a photo of your betta
« Last Edit: Sat, 10 April 2021, 11:31:50 by hello21 »
Offline kk73715
  • Why are you even reading
« Reply #4 on: Sat, 10 April 2021, 11:52:42 »
1. I don't like this screwless implementation because of the small screws you are forced to use (usually they are ****ty and low quality, usually)
2. you might not be able to screw the top few screws with JWK switches, definitely not with Gat Inks (eye-balling off render)
3. that front-height is yikes, will probably be hard to use especially with a 7° typing angle as well
4. why so much foam? whats the point of muting everything? why isolate the plate?
5. total mass? mass of weight?
6. approximate price?
7. A 65% gasket mounted keyboard Another 65% gasket mounted keyboard *with blocker
8 at least the design is somewhat different (definitely been done before though) and its not a top right blocker
9. you sneaky mother****er, this **** is hotswap. you added standoff cutouts on the plate so this is just noob-bait (65%, gasket mount, hotswap, blocker, foam, foam, and more foam)
10. also it only has 4 standoffs? good luck?
personally, I don't think 6 months is enough time. Maybe I'm wrong, who knows. I'm just some random dude on the internet, take this with a grain of salt
Offline treeleaf64
    • treeleaf64
« Reply #5 on: Sat, 10 April 2021, 12:03:49 »
all keyboard look the same
Billy types
Everyone must pay the cat tax
Offline Cubic // esc lab
  • Formerly 'esclab'
    • esc lab
[IC] Whi65 | 65% Layout | Gasket Mount
« Reply #6 on: Sat, 10 April 2021, 13:20:10 »
Definitely would like to see a prototype first! Hard to give feedback or judge a board/anything from renders alone.
I think for anything outside of keycap sets, it's become fairly common to have at least R1 protos ready during IC phase. Shows commitment from the designer and thought.
GLWIC.
Offline billy.types
Re: [IC] Whi65 | 65% Layout | Gasket Mount
« Reply #7 on: Sat, 10 April 2021, 14:25:17 »
GLWIC.
That is a fair point. We are going to be ordering the prototypes in the next day or so, so I will update the IC as soon as we get them in house.
Thanks for the comment!
Offline Baka Bot
« Reply #8 on: Sat, 10 April 2021, 15:55:20 »
The triangle has been completed, we did it!
Offline mezok
« Reply #9 on: Sat, 10 April 2021, 15:59:02 »
the design looks stunning and the different colors look amazing. yet, i am put off by the thicker edges of the keyboard and that the badge takes up two keys. If the badge itself could be one key, that would be preferable imo. otherwise, I could see myself picking one up in the future. I would also prefer a soldering version of the pcb, as I live in Europe and require an ISO layout.
« Last Edit: Sat, 10 April 2021, 16:00:37 by mezok »
Offline Chippy
  • sus chef
« Reply #10 on: Sat, 10 April 2021, 16:16:19 »
semantics, but I believe this would be a 66% layout. For example: https://clueboard.co/clueboard-66-v4-5
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
Offline billy.types
« Reply #11 on: Sat, 10 April 2021, 17:58:24 »
We will be evaluating multiple screws during the prototyping phase. This will be followed by durability testing for the mounting system.
Obviously this was a concern for us too during the design stage, but we believe that our current design should avoid interferences with those switches. Again, we will be verifying this in the prototypes and adjust accordingly. Same thing goes for the front height, we are open to lowering that height as we experiment with our prototypes.
The foam is definitely an optional item that the user has the choice of using. We want to provide the best sounding keyboard and thus the thickness of the foams, material and cutouts will all be evaluated during prototyping. Everything is subject to change.
The total mass is approximately 2kg while the weight is approximately 0.6kg. I’ve updated the post to reflect this.
Not sure yet. We will know more as we continue to talk with vendors and manufacturers for mass production. We are currently in the process of getting quotes for mass production pricing.
« Last Edit: Wed, 14 April 2021, 12:31:05 by billy.types »
Offline Clone6001
« Reply #12 on: Sat, 10 April 2021, 18:09:31 »
Very cool design and theme for the board. Definitely considering it, hope to see more updates in the future.  :thumb:
Offline lush_bunny
« Reply #13 on: Sat, 10 April 2021, 18:10:48 »
That badge. Betta...
Is there any chance Whi is a fighting fish? If so, no wonder he refuses to die.
Offline billy.types
« Reply #14 on: Sat, 10 April 2021, 18:18:22 »
Whi getting alot of attention today LOL
Offline kk73715
« Reply #15 on: Sat, 10 April 2021, 20:06:15 »
Thanks for the reply :)
Hope the prototypes are up to your expectations
Offline sup3r170va
« Reply #16 on: Sat, 10 April 2021, 20:53:02 »
I like the design but 21.5mm for the front height is a dealbreaker for me. I think I can only go up to 20mm. Is there any way u can lower it?
Offline billy.types
« Reply #17 on: Sat, 10 April 2021, 21:17:14 »
Yes, we are definitely looking to lower that down to be sub 20mm. It shouldn't really affect the shape of the keyboard so its doable.
Offline ManoliVisuals
« Reply #18 on: Sat, 10 April 2021, 21:58:29 »
Nice choice for keycaps  ;D Looking forward to seeing how this turns out after protos! GLWIC
Offline spedywin
  • Formerly spedywin
« Reply #19 on: Sun, 11 April 2021, 02:52:37 »
Love the betta fish weight cutout and badge. Excited for what is to come!  ;D
Offline lush_bunny
« Reply #20 on: Sun, 11 April 2021, 02:58:26 »
If you put two Whi65 boards in the same table, will they fight each other to the death.
Offline HappyB0T
  • I'm a Piggie
« Reply #21 on: Sun, 11 April 2021, 14:38:44 »
This is great - LOL!
Offline tofulo
« Reply #22 on: Sun, 11 April 2021, 15:59:06 »
I may be in the minority, but I feel like the rear design would look cleaner without the eye dot
Offline mr_foggy
  • neue = nope
« Reply #23 on: Sun, 11 April 2021, 17:36:16 »
it looks beautiful
Offline fredprinz21
« Reply #24 on: Sun, 11 April 2021, 21:47:14 »
Filled out the IC form. Looking forward to the prototype.
Good luck with IC + GB.
Please consider Zion Studios PH as PH/SEA vendor. Thanks a lot!
More pics of your fish and prototype, PLEASE.
***Gary Trent good pick-up, boss.
For the night is dark and full of terrors.
Offline glenntmm
« Reply #25 on: Mon, 12 April 2021, 05:22:16 »
Damn dude, just take my money, can't wait for the GB phase to come already, GLWIC
Offline billy.types
« Reply #26 on: Tue, 13 April 2021, 11:43:45 »
Hey everyone
We received a few comments in this thread as well as in the IC form regarding the keyboard's front height, and how it is higher than most other keyboards you see in the market (esp ones with a 7 degree typing angle).
we felt like this was a valid point and instead of ordering prototypes we decided to change this height and make it lower before we send out the orders.
  • the front height has now been changed from 21.5mm to 19.5mm
  • estimated total mass = 2.23kg
  • estimated mass of weight = 0.55kg
Offline billy.types
« Reply #27 on: Wed, 14 April 2021, 15:38:31 »
Well good news is that we are intending to support both hot-swap and soldering versions of the PCB. The soldering version, as you mentioned, will have compatibility for the ISO layout however the hot swap version will not. We will also be updating the plates so that they support both ANSI and ISO layouts.
Offline billy.types
Re: [IC] Whi65 | 65% Layout | Gasket Mount - Prototypes Ordered
« Reply #28 on: Thu, 15 April 2021, 13:34:58 »
First round of Prototype ordered!
It will be the Deep Blue colorway with the polycarbonate plate.
Further updates to come!
Join our discord for more regular updates: https://discord.gg/uytwB8TG
Offline Michelle Obama
« Reply #29 on: Thu, 15 April 2021, 20:49:15 »
will there be more colors?
Sent from my Redmi Note 8 Pro using Tapatalk
Offline humpafei
« Reply #30 on: Fri, 16 April 2021, 10:25:52 »
Just wondering, when are you guys planning to launch the GB? like estimated timeframe.
Offline billy.types
« Reply #31 on: Fri, 16 April 2021, 17:40:07 »
It all depends on how our prototyping goes, but we are aiming to start the GB early Q4.
We have started working with manufactures and are talking to vendors, we will be able to have an updated timeline soon.
Offline mizuwolf
« Reply #32 on: Mon, 19 April 2021, 09:15:43 »
ooh looking forward to seeing prototypes - just have to voice that i LOVE that e-lilac!!
Offline hhynes11
« Reply #33 on: Thu, 22 April 2021, 05:32:21 »
Pretty new to the community so not sure how touchy "copying" is but it would be very cool if you sold extra badges with different designs/colors and maybe even optional poron/silicone gasket strips like the ikki68 did to make it super customizable. I have been waiting for a 65% with a blocker and a badge for a while now without having to pay a ridiculous amount on the aftermarket and this looks perfect but having that extra customizability would make it a done deal for me. The only thing I can pick out is I would prefer a centered USB C but that's just me being picky.
« Last Edit: Thu, 22 April 2021, 05:41:54 by hhynes11 »
Offline billy.types
« Reply #34 on: Mon, 26 April 2021, 12:56:28 »
Based on feedback and suggestions gathered through our IC form, Geekhack thread, and our Discord server we have decided to support 2 PCBs: a hot-swap version and a soldering version.
The soldering version of the PCB will:
- support a variety of layout options, such as: ANSI, ISO, split Left Shift, split Backspace, and stepped Caps Lock. An overview of the support layout options is shown below
- provide QMK & VIA support
- have added ESD protection
The hot-swap PCB will:
- use Mill-max sockets to provide hot-swap functionality
- support only the ANSI layout, will not support ISO or any of the split/stepped options from the soldering version
- 5 pin hot-swap
« Last Edit: Mon, 26 April 2021, 13:10:15 by billy.types »
Offline Lucy Lumi
  • Formerly 'Happy Forge'
« Reply #35 on: Mon, 26 April 2021, 21:37:59 »
I LOVE this board! Love the inclusion of arrow keys, the sides are gorgeous, and that lilac purple colour way with the brass, just stunning! Really excited for this board :)
Count me in for the purple :D x
Offline treeleaf64
    • treeleaf64
« Reply #36 on: Mon, 26 April 2021, 22:41:20 »
I enjoy the small dents in the corners.
When I accidentally drop my keyboard on the ground, I will not be able to tell the difference in appearance. How nice.
Offline captainkai
« Reply #37 on: Tue, 27 April 2021, 17:14:53 »
I actually really like them, and they differentiate the board's design a bit.  They remind me a bit of an aluminum GK68XS case, but a lot more refined.
Offline billy.types
« Reply #38 on: Thu, 29 April 2021, 12:31:11 »
Just got word that our prototypes have finally been finished and are currently on a plane enroute to us. We expect to get them in hand sometime early next week.
Here are a few pictures we asked the manufacturer to send us before they shipped them out. They are not the best quality so please take them with a grain of salt.
Estimated delivery date is May 5th, foams and gaskets will also be arriving the same day.
« Last Edit: Thu, 29 April 2021, 13:35:59 by billy.types »
Offline DaaDaa
« Reply #39 on: Thu, 29 April 2021, 13:27:34 »
there is a lot of points to muting everything. all the foams are very much appreciated and a great design. what is with all the #$#$ty loud clacky dumb keyboards for incel lunatic mech key nutjobs?
« Last Edit: Thu, 29 April 2021, 13:29:53 by DaaDaa »
piggy60 red upgraded PVD w/ GMK umka zaku | tiramisuit w/ GMK noire JWK silk emerald | mr.suit black/chrome glossy chamfers w/ GMK minimal cow POM stem | jelly epoch w/ SA oblivion zaku | mode80 deco w/ gmk boneyard alpaca | mode 80 imperial with ePBT origami alpaca| MODE80 viridian /w CRP boba LT | RAMA thermal kuro w/ GMK muted 2 pewter | BBox60 C64 wih marshmellows and c64 keycaps | MODE Sonnet green /w MW voynich gateron ink box pink
Offline Ranger_Trivette
Re: [IC] Whi65 | Gasket Mount - Prototypes Shipped
« Reply #40 on: Fri, 30 April 2021, 09:30:28 »
any idea of the final price?
do you have an idea of the minimun quantity to start the GB?
and also, how many feedback have you received from the IC?
Offline treeleaf64
    • treeleaf64
« Reply #41 on: Fri, 30 April 2021, 10:41:56 »
 I do not like Noob Bait keyboards. I do not like the use of sound dampening foam when it is not needed. Please calm down and be nice to my friend. He was just commenting on what was an unfinished IC
Offline billy.types
« Reply #42 on: Fri, 30 April 2021, 17:03:35 »
As we are still trying to figure out the logistics of the group buy we don't have a definitive answer to all your questions. There is no estimated price point yet, we will know really soon though. We want to steer away from giving an estimated price just yet with the main reason being that it might change as we talk to more vendors and manufacturers and finalize a MOQ volume.
As for the feedback in the IC form, there are currently around 1000 responses. We are really happy with this turnout and excited to take this to a GB.
Offline billy.types
« Reply #43 on: Sat, 01 May 2021, 12:47:02 »
Thank you, I think for round 1 we probably will stick to only one badge design, and perhaps do an extra run for different designs/colors if this original GB does well. This is a bit lower on our list of priorities at the moment but if we can figure out a good cost-effective way of providing multiple designs we will consider it.
Offline billy.types
Re: [IC] Whi65 - Gasket Mount | PROTOTYPE PICS ADDED (5/11/2021 Update)
« Reply #44 on: Tue, 11 May 2021, 20:30:10 »
Version 1 of prototypes were delivered earlier this week and so far really happy with how they have turned out. Very pleased with the overall fit and look of the keyboard. The PCBs have been delayed by a bit, we contacted the manufacturer yesterday and they told us they've finished the PCBs but the SMT part still needs to be completed. They were moving offices and that's why there's been a slight delay, and having the worldwide chip/component shortage doesn't help either. Once they get their production line up and running they will inform us, hopefully, it's soon.
In the mean time, we have been able to take some picture of the Whi65 in all of it's glory, I have updated the original post and added these pictures, hope you guys enjoy them.
We will adding more pictures and sound tests as we get the PCB in and put the entire thing together.
Offline Victus
« Reply #45 on: Wed, 12 May 2021, 00:20:36 »
best board on IC rn, i wont hear otherwise
« Reply #46 on: Wed, 12 May 2021, 04:52:14 »
plate and case seems not well aligned on the right corner.
probaly che plate cut need to be more precise :thumb:
Offline antsinyourpants
« Reply #47 on: Wed, 12 May 2021, 22:29:12 »
Thanks for the update! Looking forward to a typing test once the PCB arrives :)
Offline mizuwolf
« Reply #48 on: Fri, 21 May 2021, 16:00:47 »
Oh man I just saw that this will have millmaxed hotswap pcb i am SO HERE FOR THIS and that proto has come out gorgeous I'm really going to struggle on what color to get ;o;
Offline MadBinton
  • 40/45/65/75% user
« Reply #49 on: Fri, 21 May 2021, 16:13:15 »
This board looks really good, and the shot of the arrow cluster and badge up close look sweet from up close.
The looking at the board in overview, two things bother me:
The small (0.25u?) blocker left of the arrows - it rubs me the wrong way. I would much rather have had the option to have wider mod keys left of the space bar. Or just one 1.5u and then more room for the blocker.
The badge sits at an offset from the keys, which is fine, but clearly sits outside of the "frame" of the board. By an to my eyes unpleasant amount. It really hurts how uniform the bezel looks, since there's two and there's just this small infraction.
Now I'm not just here to nag, I only found this board and proto today, but I must say I'm completely captured by the colors and the weight and the design of the badge, the brass rim around the edges, the side profile...
I want this board, but these two elements are really disruptive to me.
