Author Topic: [IC] Midway60 | O-Ring Sandwich Gasket 60% Keyboard | UPDATES 6/4  (Read 35151 times)
Offline Bolsa Huncho
Midway60 | Bolsa Supply
The Midway60 is the first board designed in house by Bolsa Supply in collaboration with fellow community board designer and good friend N.Rdy. The goal Midway60 aims to achieve is extremely simple: to look, sound, and feel good. Midway60 is essentially a combination of features and aspects that we as keyboard enthusiasts like in keyboards. 60% layout, flex, and o-ring sandwich gasket because of the sound signature that it provides. N.Rdy took these features and effectively brought those ideas to reality with the Midway60.
The name is not anything special or related to keyboards, but holds meaning to us and Bolsa as a brand. Where Bolsa Supply is originated from, there is a city named Midway City in which Bolsa Avenue (where the brand name comes from) is the main street. Midway city; Midway60
Design Highlights
- Exaggerated seam
- Front/rear slant on the top and bottom side of the case
- Enlarged o-ring channels on the interior to accommodate the usage of screw-in stabilizers
- Low front height due to slant at 13.75mm from tip of angle (17.75mm from highest point of slant)
Board Details
- 60% Layout, available in both WK, WKL, and HHKB.
- 7 degree typing angle
- Materials: Anodized Aluminum (6063) chassis, brass weight
- Color options: Black, Gray, and Navy
- Plate Options: Aluminum default, Polycarbonate and Carbon Fiber as addons
- PCB: 60% Solder PCB using an Ai03 styled Daughterboard (center USB). Designed by FJLabs.
- Mounting Method: O-Ring Sandwich Mount utilizing a AS568-262 O-Ring.
- Roughly 1.5kg fully built
Color Options
Dark Navy
Iron Gray
Black
Limited Edition
- We are a sucker for limited edition things which is why we are making a limited edition variant for the Midway60
- Limited edition will feature an Obsidian colorway and a copper weight. The obsidian color is very unique with the color varying between gray to purple depending on the lighting situation.
- Limited to 20 units.
- Price TBD.
Vendors, Pricing, and Sales Format
- This board will be sold FCFS via raffle
- Standard edition will be priced at $370, LE will be priced at $425.
- This will be a limited group buy, limited to 125 spots. We are keeping it limited not for the sake of exclusivity, but because this is our first board group buy. As with any first time project we want to make sure we are not biting more than we can chew and that this group buy goes as smoothly as it possibly can for a 2 man team.
- Group buy date is still TBD, but we are aiming to have the sale happen closer to the end of Q2.
- Group buy turn around time will be estimated at 4-6 months after the sale has ended. As with all group buys please take this timeline with a grain of salt as projects like these can be subjected to delays.
Renders and Prototype Pictures
Production Obisidian LE - Manufacture had slightly altered the color to better match the pantone itself and it came out perfectly. It is slightly different from the prototype images above.
Sound Test (Specs in Video Description)
Typing Test by Filled Types
To-do List
- Test 50 Duro O-Rings (currently using 70 Duro)
- Order samples for gray, black, and navy colorways
- Send sample units to streamers and content creators
- Packaging design (if anyone has expertise in this field, please reach out to me!)
Special Thanks
- Big thank you to N.Rdy of course for making this project possible. He has been an absolute joy to work with so far and we have more boards that we plan on doing together!
- Thank you to my degen affiliates Kimchi, Nathan, and Tim for providing me with useful insight and criticisms to help get the board to where it is today
- And lastly, without trying to be being a complete cornball, everyone who has supported Bolsa Supply thus far, as if it were not for you guys we would not be where we are today!
Join our Discord for further updates on this project! We will continue to update this GH post as things come but our Discord will generally see immediate updates first.
https://discord.com/invite/JAGuHSj
Interest Check Form Here: https://forms.gle/erZAGoyq8c1nsTFV9
Edit Log
4/21/2021 - First edit right off the bat, the large request for HHKB layout did not go unnoticed, and it was actually planned when Midway60 was being conceptualized; meaning we already have the file for the HHKB top. After speaking to my manufacture I am glad to announce that this will be available in HHKB as well. I will put up some renders of it when I get the opportunity and will also order an HHKB sample as well.
4/30/2021
- We have released a form for FCFS or raffle. Fill out the form here: https://forms.gle/dxjmXnViQATBCfqX6
- Price point will be solidified at $370. LE will be $425. This is not including the cost of shipping (shipping from California).
- Finalized plate options: Aluminum full, Aluminum half, polycarbonate full, and carbon fiber full
- Heavily aiming for a June release.
5/10/2021
- We have found that there is a slight tolerance issue with the plate sandwiching in between the top and bottom piece which causes the assembly to have some movement even when the case is fully put together. To alleviate this issue, all kits will receive thin poron strips that can be applied to the top case piece. These strips will help keep the assembly in place and will eliminate any movement while keeping typing sound and feel the same. Alternatively, you can also use electrical tape on the plate tabs if you do not wish to use the poron strips, or you can just leave the plate as is (the board is 100% usable without any of these modifications).
- We are on track for a end of June release! The sale is now being switched to a raffle style sale which we think will be a bit more fair. Additionally, this will allow users to select whichever plate they want versus having the board come standard with an aluminum plate. Users can also add in any extra's (PCB's and plates) they would like to include. Pricing is solidified at $370 before shipping.
- Linked below is @kimchijodyboi VOD of the prototype build stream as well as some clips of the typing test with and without the plate modified.
Unmodified Plate: https://www.twitch.tv/videos/1017580348?filter=highlights&sort=time
Modified Plate: https://www.twitch.tv/videos/1017581917?filter=highlights&sort=time
Taped PCB Flex Cuts: https://www.twitch.tv/videos/1017584581?filter=highlights&sort=time
Full VOD: https://www.twitch.tv/videos/1017438757
6/4/2021
- Gymleadernathann did a stream build on our prototype and it was absolutely money. Check it out here: https://www.twitch.tv/videos/1045213388
- Tolerance issue has been 100% alleviated with the use of 1mm poron strips that will go on the top piece of the case only. Has been tested and we have found that it does not effect the sound or feel of the board whatsoever, it only acts as a guide to keep the plate in place and reduce movement (which is what we were aiming for).
- Obsidian anodization has been slightly changed to better match the pantone itself. Our manufacture sent us a picture of it and we are in love. Image of it will be posted above.
- Production PCB's are finalized and we have already received fully functioning samples. Board has been fully ported into VIA and is ready for usage.
- Raffle is unfortunately going to be pushed back until sometime mid July. We are waiting for production sample units to finish so we can send it out to all the respective streamers prior to the launch of the raffle.
- We have teamed up with a fantastic packaging designer and are currently in the works of finishing that up
« Last Edit: Wed, 16 June 2021, 02:06:49 by Bolsa Huncho »
Offline Neely_12
Re: [IC] Midway60 | O-Ring Gasket 60% Keyboard | Bolsa Supply
« Reply #1 on: Wed, 21 April 2021, 15:03:12 »
Following on discord, and I love the board. Great work Bolsa Supply!
Offline kimchijody
« Reply #2 on: Wed, 21 April 2021, 15:10:20 »
Offline themasterphi
« Reply #3 on: Wed, 21 April 2021, 15:24:07 »
That obsidian colorway :eek:. This is looking solid, been following on Discord for a while too, happy y'all making good progress.
Offline rt_es
Re: [IC] Midway60 | O-Ring Sandwich Gasket 60% Keyboard | Bolsa Supply
« Reply #4 on: Wed, 21 April 2021, 15:30:27 »
Heard about you guys when you started out with switch GBs and it's great to see y'all have released your first board! Will follow closely.
Offline TimKeyLess
    • Twitch
« Reply #5 on: Wed, 21 April 2021, 15:42:44 »
I will have you know that the obsidian colorway has made me moist.
Offline StingrayShuffle
« Reply #6 on: Wed, 21 April 2021, 15:47:14 »
Great looking board Bolsa and N.Rdy!
« Last Edit: Wed, 21 April 2021, 15:48:50 by StingrayShuffle »
Offline Fredington
    • Instagram
« Reply #7 on: Wed, 21 April 2021, 15:47:41 »
NE HHKB avail?
Offline kidpid
« Reply #8 on: Wed, 21 April 2021, 15:59:24 »
NE HHKB avail?
This. Also, NE half plate addon avail?
Offline pixelpusher
« Reply #9 on: Wed, 21 April 2021, 16:03:57 »
Welp, I pretty much like everything about this.  Sign me up, boss.
Offline pixelpusher
« Reply #10 on: Wed, 21 April 2021, 16:05:23 »
NE HHKB avail?
Oooh, yeah.  This might be pretty sweet with a 1/2 plate.  Good call.
Offline heyimpanda
« Reply #11 on: Wed, 21 April 2021, 16:18:42 »
that front lip and seam are super nice, will be following along with great interest as i simp for every possible 60% WKL board
« Reply #12 on: Wed, 21 April 2021, 17:02:55 »
NE HHKB avail?
If there is enough shared interest we may offer HHKB as well, we have the design files made for it already :)
Also being explored as well! We are going to be prototyping a half alu plate and depending on the results it may be offered.
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #13 on: Wed, 21 April 2021, 17:08:16 »
30a oring is very fun please consider trying that as well
« Last Edit: Wed, 21 April 2021, 17:10:04 by Kokaloo »
Offline Chippy
  • sus chef
« Reply #14 on: Wed, 21 April 2021, 17:11:06 »
can you consider including an assortment of orings with each keyboard. They don't cost much and are a great way to customize the feel. 30A, 50A, and 70A are the most common. Thank you, love the plum.
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
Offline Mt_Ursa
« Reply #15 on: Wed, 21 April 2021, 17:23:46 »
Sheeeeeeeeeesh... That Obsidion/Lavender Black color is downright gorgeous. Very eagerly awaiting more information for the GB.
Offline kk73715
  • Why are you even reading
« Reply #16 on: Wed, 21 April 2021, 19:11:24 »
Is there a Pantone for the Obsidian colorway?
Offline Shoobs
« Reply #17 on: Wed, 21 April 2021, 20:16:51 »
obsidian so lit
Offline deedz
« Reply #18 on: Wed, 21 April 2021, 20:58:06 »
I need this.
Good job guys, looks amazing sheeeesh
Offline armintehgreat
« Reply #19 on: Wed, 21 April 2021, 20:59:31 »
I like
Offline Jefff
    • jlabs.co
« Reply #20 on: Wed, 21 April 2021, 21:07:33 »
What kind of price are you looking at?
Offline treeleaf64
    • treeleaf64
« Reply #21 on: Wed, 21 April 2021, 21:23:06 »
That seam is getting on my nerves
« Last Edit: Wed, 21 April 2021, 22:21:07 by treeleaf64 »
Everyone must pay the cat tax
Offline kimchijody
« Reply #22 on: Wed, 21 April 2021, 22:06:07 »
Hi treeleaf. I made a note about it to Bolsa and they are considering adding a small chamfer to the seam to make it more intentional. Still in the works but fingers crossed.
Offline kohalified
« Reply #23 on: Wed, 21 April 2021, 22:10:15 »
Liking these colors  :cool:
Offline xinxinwong
« Reply #24 on: Wed, 21 April 2021, 22:55:16 »
those colors tho
Offline bubbachuck
« Reply #25 on: Wed, 21 April 2021, 23:02:30 »
can i have one
Offline n.rdy
« Reply #26 on: Wed, 21 April 2021, 23:05:11 »
I see you.
Offline NoxNoxNox
« Reply #27 on: Thu, 22 April 2021, 00:46:56 »
Liking this design a lot
Offline Clay333
« Reply #28 on: Thu, 22 April 2021, 06:09:43 »
I love it. The Ogre was my endgame that I couldn't get. This looks like a perfect substitute that is even better in one way that is quite important to me, screw in stabs on an o-ring mount. I will definitely be trying my luck on this one and crying in a corner for a few weeks if I miss out on it.
Offline ManoliVisuals
« Reply #29 on: Thu, 22 April 2021, 10:46:17 »
V interested in this bad boi
Offline AstralYT
« Reply #30 on: Thu, 22 April 2021, 14:01:50 »
That seam and wedge looks great, will definitely buy one. Thanks for considering sending one off to shoobs, he's been my favourite keeb creator lately.
I would have like some more spice in the seam personally, sorta like this board.
https://geekhack.org/index.php?topic=108639.0
Sent from my Redmi Note 7 Pro using Tapatalk
Offline MIGHTY CHICKEN
« Reply #31 on: Thu, 22 April 2021, 14:13:43 »
Consider me intrigued
Offline chung
« Reply #32 on: Thu, 22 April 2021, 14:37:57 »
very nice im in
Offline WiseLucas
« Reply #33 on: Fri, 23 April 2021, 00:24:00 »
Looks good
Offline WaS
    • TELEPORT
« Reply #34 on: Fri, 23 April 2021, 03:44:34 »
i would love a brighter color, for me more fitting to the extra weight, just my2c
Offline UGunaLOSE
« Reply #35 on: Fri, 23 April 2021, 07:14:31 »
This looks great!!!
« Reply #36 on: Mon, 26 April 2021, 14:56:40 »
Just a few updates! (Will also be posted on the main post at the top)
- HHKB is now going to be available as an option meaning this board will be available in WK, WKL, and HHKB
- I have just received pictures of our copper weight for the Obsidian LE variant which will be shown above in the main post
- Typing test video from Filledtypes is available now which is much better than the one we filmed. There will be another typing test video from Filledtypes with JWK+PC plate later this week.
Filledtypes Typing Test
« Last Edit: Mon, 26 April 2021, 16:59:04 by Bolsa Huncho »
New updates posted above! Please fill out the FCFS or raffle poll if you can!
Offline SDKCAMPING
I will buy it/  :thumb:
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Major updates for 5/10! Check it and if you have any questions feel free to ask :)
Offline bananarama
I just want the limited edition, not for any other reason than to just have it y'know.
Offline Qwapa
Def trying for this raffle hope I win!!
Offline Ranger_Trivette
that's wonderfull
Re: [IC] Midway60 | O-Ring Sandwich Gasket 60% Keyboard MAJOR UPDATES 5/10
« Reply #43 on: Fri, 04 June 2021, 11:33:42 »
New updates for 6/4! We are getting very close to the finish line  ;D
Offline Domantas
Re: [IC] Midway60 | O-Ring Sandwich Gasket 60% Keyboard | UPDATES 6/4
« Reply #44 on: Sat, 17 July 2021, 03:02:22 »
Can other pcb used in this? If it has ai03 daugtherboard connection? I mean will gh60 standart fit?
« Last Edit: Sat, 17 July 2021, 03:04:09 by Domantas »
Offline Curin Derwin
« Reply #45 on: Sat, 17 July 2021, 21:49:26 »
I saw this on MechGroupBuys. Is / Was this open?
