Author Topic: [IC] Modulus (Updated)  (Read 30583 times)
Offline Zeeejay
« on: Wed, 16 September 2020, 14:45:44 »
Modulus
Hi everyone. I started designing this keyboard over a year ago to achieve a specific side profile I wanted. I’m a big fan of the basic wedge design in keyboards but I also wanted just a bit of added flair to still keep my design unique. After a lot of testing and redesigning I’m happy enough with the second prototype to revive this IC.
Form:https://forms.gle/LCLxwDDpfosoev1e6
Details
- Top Mount Aluminum Case
- 6 Degree Typing Angle
- ≈17.8mm front height
- Brass weight
The board was designed to use PCBs with ports centered between the “esc” and “1” keys such as the ANC-60 and WT60.
Renders
The plate is top-mounted with 4 mounting points. The cutout around the spacebar is inspired by Windeh's Omega 60 and has been further stylized to look like a linked list.
Prototype Photos
The second prototype features revisions to the port and seam to better achieve the aesthetic I was aiming for. The underside has also been changed to an engraving (infilled) paired with a through weight which depicts a binary search tree where the root node is accented by the brass. The final board design currently differs slightly from this proto by featuring 4 case screws and the redesigned plate shown in the renders. The PCB in the build is an ANC-60 from Cannonkeys.
Group Buy Plans
- Price is TBD but my target is ≈350 USD at a decently sized MOQ (≈80 units) with vendor involvement
- I'm leaning towards offering WK and WKL layout options based on current IC feedback
- I'm quite happy with the gray and red anodization on my prototypes so they will likely be the options for the group buy. Feel free to suggest colors on the form since I may change my mind or find it feasible to add more color options. Pictures of the gray ano on prototype 1: https://imgur.com/a/FcqEoeV
- I plan on including a PCB in the kit
Extra Info
Inspiration
The Modulus is a programming-themed keyboard. The binary search tree and linked list are both common data structures and the name of the board is a reference to modulo operations.
https://en.wikipedia.org/wiki/Linked_list
https://en.wikipedia.org/wiki/Binary_search_tree
Fitment and Design
The board is designed with a tiny bit of extra tolerance in the two rear corners of the board between the top and bottom halves of the case. This is to ensure that there is only one plane of contact between the halves when they are fitted together. Besides the complexity of the seam, the design of this board follows a simple top-mounted wedge.
« Last Edit: Wed, 18 August 2021, 19:42:15 by Zeeejay »
Offline OtherAndrew
Re: [IC] Modulus
« Reply #1 on: Wed, 16 September 2020, 14:46:47 »
sick
Offline Kokaloo
  • 🤘(• ω •)🤙
Re: [IC] Modulus
« Reply #2 on: Wed, 16 September 2020, 14:51:26 »
yep
what PCB did you end up using for the proto?
« Last Edit: Wed, 16 September 2020, 14:54:28 by Kokaloo »
Offline jooobe
Re: [IC] Modulus
« Reply #3 on: Wed, 16 September 2020, 14:51:46 »
Nice
Sent from my Pixel 4a using Tapatalk
Offline undecidedshark
Re: [IC] Modulus
« Reply #4 on: Wed, 16 September 2020, 14:53:05 »
noice!
Offline Fredington
    • Instagram
Re: [IC] Modulus
« Reply #5 on: Wed, 16 September 2020, 14:53:13 »
HHKB please
Offline kyuut
  • i just learned a new dance
Re: [IC] Modulus
« Reply #6 on: Wed, 16 September 2020, 14:53:55 »
interesting
TGR Jane v2 | TGR Jane v2 CE | TGR x SINGAKBD Unikorn 2.2 | SINGAKBD Kohaku R2 Prototype | HHKB Professional 2
Offline Boy_314
Re: [IC] Modulus
« Reply #7 on: Wed, 16 September 2020, 14:57:23 »
« Last Edit: Mon, 04 August 2025, 02:18:43 by Boy_314 »
Offline Zeeejay
Re: [IC] Modulus
« Reply #8 on: Wed, 16 September 2020, 15:09:29 »
yep
The 1st proto was built with a DZ60 because I initially designed the port to be compatible with all standard 60% type C pcbs (if you zoom in on the second picture you can tell there is significant additional clearance). I decided to tighten the port for aesthetic reasons so the DZ60 should no longer be compatible with the revised design.
Offline Bl4ck
Re: [IC] Modulus
« Reply #9 on: Wed, 16 September 2020, 15:18:11 »
yep
If your goal is to support most 60% pcbs, you should probably keep it as the proto, its actually pretty tight for a universal board already
Offline KingOfMemes
Re: [IC] Modulus
« Reply #10 on: Wed, 16 September 2020, 15:38:24 »
Offline paperassgasket
Re: [IC] Modulus
« Reply #12 on: Wed, 16 September 2020, 16:02:58 »
I actually really like that side seam  :thumb:
Offline yui_
Re: [IC] Modulus
« Reply #13 on: Wed, 16 September 2020, 16:04:19 »
i love seamed designs like this. ne 6.25 avail (or at least open-sourced plate files after gb, as this would allow for iso plates to be made too).
glwic!!
Offline dingusxmcgee
Re: [IC] Modulus
« Reply #14 on: Wed, 16 September 2020, 17:01:59 »
Happy to see this awesome seam work come to GB! Good luck! :)
Offline alspdx
Re: [IC] Modulus
« Reply #15 on: Wed, 16 September 2020, 19:02:41 »
Looks great, also interested in HHKB!
Offline n.rdy
Re: [IC] Modulus
« Reply #16 on: Wed, 16 September 2020, 19:03:40 »
Yo this is super cool!!
Offline Janoma
  • certified nerd
Re: [IC] Modulus
« Reply #17 on: Wed, 16 September 2020, 19:26:32 »
that WEIGHT *chef's kiss*
Offline ItszBrian
    • GMK Devoted
Re: [IC] Modulus
« Reply #18 on: Wed, 16 September 2020, 19:33:43 »
The design isn’t over the top but the seams give a nice edge to it. If I may suggest, anodized purple would look awesome.
Offline heyimpanda
Re: [IC] Modulus
« Reply #19 on: Wed, 16 September 2020, 20:07:06 »
yes bb
Offline Rozalin81
Re: [IC] Modulus
« Reply #20 on: Wed, 16 September 2020, 20:14:36 »
Very clean! I like that side seam a lot!
Reddit - u/Rozalin81
Discord - Arstallie#4516
Duck Octagon v3 // Vintage Blacks // Modern Dolch
Offline Mcnos
    • GMK Fuyu
Re: [IC] Modulus
« Reply #21 on: Wed, 16 September 2020, 20:42:20 »
That's pretty cool
Offline Avocadough
Re: [IC] Modulus
« Reply #22 on: Wed, 16 September 2020, 22:58:28 »
this is so so so nice
Offline nasp
Re: [IC] Modulus
« Reply #23 on: Thu, 17 September 2020, 06:35:47 »
yep
So is the DZ60 PCB's USB not in the same location as the ANC-60 or WT60 USB?
Offline Paputcher
Re: [IC] Modulus
« Reply #24 on: Thu, 17 September 2020, 08:06:36 »
looks really good
Offline The.Ryan.Gamer
Re: [IC] Modulus
« Reply #25 on: Thu, 17 September 2020, 10:11:00 »
IC Filled.
Interested to get the WKL version. Man, this looks clean.  :thumb:
Offline Zeeejay
Re: [IC] Modulus
« Reply #26 on: Thu, 17 September 2020, 10:12:56 »
glwic!!
I do plan on releasing plate files after the group buy.
yep
The DZ60's port sits slightly closer to the "esc" key. The variation in port location is quite small but after receiving the prototype I think the extra space bothers me just enough that I would prefer tightening the port; hence the design change.
Offline kw88
Re: [IC] Modulus
« Reply #27 on: Thu, 17 September 2020, 12:01:35 »
at first I was excited about this, but then I read dz60 is not supported, and now I am sad :(
nonetheless, very good keyboard, plain and simple
Offline CustomerSupport
  • 🕸 developer
    • Discord
Re: [IC] Modulus
« Reply #28 on: Thu, 17 September 2020, 13:50:11 »
Yeah it isn't necessarily up to preference either; if a PCB has issues or a critical mistake is made down the line, this beautiful case is rendered obsolete. Supporting DZ60, GH60, and other similar PCBs allows for easy replacement in the unfortunate (and hopefully unlikely) instance that the proprietary PCB becomes unusable. Also, it may be cheaper to use an existing PCB than design a proprietary one.
Anyways, also interested in this board and love the design. WinKey and HHKB layouts pique my interest.
Offline kwerty
  • beep boop i'm a robot
Re: [IC] Modulus
« Reply #29 on: Fri, 18 September 2020, 00:53:48 »
I like this a lot
Offline Pizza_on_Pineapple
Re: [IC] Modulus
« Reply #30 on: Fri, 18 September 2020, 01:12:56 »
I'm interested! Looks great
Offline Shutter_Shock
Re: [IC] Modulus
« Reply #31 on: Sat, 19 September 2020, 01:04:44 »
I’m interested. ANSI support would be a good option to allow compatibility with hotswap ANSI PCBs like the Instant60. Also good for people like me that prefer ANSI for 60% because it adds a key to the bottom row. A plate that allows for an ANSI bottom row and still a split right shift would be ideal IMO.
Offline Cloods
Re: [IC] Modulus
« Reply #32 on: Sat, 19 September 2020, 02:36:21 »
Could see people painting the line with some enamel paint or something to make it really pop. Cool board
Re: [IC] Modulus
« Reply #33 on: Sun, 20 September 2020, 12:01:59 »
Love the seam on this, looking forward to seeing it happen.
Re: [IC] Modulus
« Reply #34 on: Sun, 20 September 2020, 12:07:18 »
I was thinking the exact same thing. If I can get one, I’ll probably cerakote it black with hot pink in the seam and on the weight.
Offline fritte
Re: [IC] Modulus
« Reply #35 on: Sun, 20 September 2020, 19:34:06 »
As others have mentioned it would look even sicker if you had color options for the line/seam. Regardless, nice case. Any idea when you may get a price estimate?
Offline Zeeejay
Re: [IC] Modulus
« Reply #36 on: Tue, 06 October 2020, 21:28:24 »
It would be after I recieve and evaluate the 2nd prototype.
Offline SenseiJia
  • Hey you.
Re: [IC] Modulus
« Reply #37 on: Tue, 06 October 2020, 22:40:49 »
Looks interesting! gj
Offline lush_bunny
Re: [IC] Modulus
« Reply #38 on: Tue, 06 October 2020, 22:44:45 »
ngl those seams as SICK
Offline Benedikt
Re: [IC] Modulus
« Reply #39 on: Wed, 31 March 2021, 10:01:48 »
Is this project still alive? I love that seam.
Offline Skeil
  • I drink art and draw coffee
Re: [IC] Modulus
« Reply #40 on: Sat, 10 April 2021, 08:50:06 »
I love the seams and the brass weight, glwic!
Offline NovaRMK
Re: [IC] Modulus
« Reply #41 on: Sat, 10 April 2021, 12:41:30 »
Please
Offline AstralYT
Re: [IC] Modulus
« Reply #42 on: Mon, 12 April 2021, 01:16:52 »
Please
Sent from my Redmi Note 7 Pro using Tapatalk
Offline AstralYT
Re: [IC] Modulus
« Reply #43 on: Sat, 17 April 2021, 17:43:17 »
OP come on, come back and start the GB fast.
Offline Zeeejay
Re: [IC] Modulus
« Reply #44 on: Sat, 24 April 2021, 00:22:19 »
Thanks for all the support so far, the redesign is currently still being tweaked. I would love to run a group buy but since this is my first board it is very important that I take my time to ensure that I am happy with everything before I can give it further consideration. I'm quite excited about the changes so far and I hope I'll be able to post more substantial updates soon!
Offline AstralYT
Re: [IC] Modulus
« Reply #45 on: Mon, 26 April 2021, 10:27:56 »
Will be keeping an eye out for all the updates. Take your time, make a great keeb.
Offline UswordM
Re: [IC] Modulus
« Reply #46 on: Sat, 08 May 2021, 01:49:15 »
I really like the design of this board. So noicee
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
Re: [IC] Modulus
« Reply #47 on: Sat, 08 May 2021, 02:24:05 »
Nice to see that is has USB-C :cool:
Offline handmademedal
Re: [IC] Modulus
« Reply #48 on: Sat, 08 May 2021, 09:44:43 »
WKL would be noice
Offline AstralYT
Re: [IC] Modulus
« Reply #49 on: Sat, 08 May 2021, 09:48:00 »
Consider adding flex cuts to the plate, leaf-spring mount will be interesting.
