Author Topic: [IC] GMK Star - LIVE NOW! GB THREAD IS HERE  (Read 94520 times)
Offline Paputcher
« on: Mon, 02 November 2020, 11:45:49 »
ARE YOU READY KIDS?
Hello everyone, and welcome to
GMK Star
This set is inspired by a pink star with cool pants
GB thread:
Prices:
GB Date:
23rd February
Kits:
Base kit
Novelties
40s kit
Spacebar kit
And some renders:
(Images do not show the final product)
Fjell by Mekanisk
RAMA U80-A by RAMA
IRON-165 by Smith+Rune
RAMA M60-A by RAMA
Alice-like-case by KraizesGB
M0LLY by TKC
SP-111 by BlindAssassin111
Deskmat:
RAMA Keycap:
Colors Used:
Vendors:
NA: Kono
Asia: ThicThock
Oceania: Dailyclack
NA for RAMA: RAMA WORKS
Collaborations:
GMK Star x RAMA^
GMK Star x ArtKey
GMK Star x GSK
GMK Star x Luxe Cables
GMK Star x Nacho Customz (mouse)
To do list:
Make a deskmat design
Find vendors
Collaboration with someone
Special thanks to:
Swishy, Blamby, Konstantin, Bachoo, Meatsmoothies and others from keycap designer discord server
If you want to support the set consider adding this signature to your profile
Code: [Select]
[url=https://geekhack.org/index.php?topic=109392.0][img width=302 height=120]https://i.imgur.com/79cWe9m.jpg[/img][/url]
Updates:
11/6/2020 Kitting update:
Base kit: added extra B, and replaced the R3 #~ with an R3 \| key
40s kit: added R3 1u and R3 1.25 code keys, added a R4 1u accent-colored enter and changed the non-accented one with R4 1u data key, added a 1.75u spacebar key and moved extra B to base kit
11/19/2020:
Novelties: added 1.50u novelties
Announced vendors
Revealed the deskmat design
Added new renders
1/11/2021:
Announced collaborations
Announced the GB date
Showed colors used
2/22/2021:
Announced prices
« Last Edit: Wed, 24 February 2021, 00:38:26 by Paputcher »
Offline Paputcher
Re: [IC] GMK Star
« Reply #1 on: Mon, 02 November 2020, 11:46:09 »
Reserved
Offline NotYeMK
  • I will yeet your keyboard
Re: [IC] GMK Star
« Reply #2 on: Mon, 02 November 2020, 11:47:45 »
For the goofiest of goobers around.
Offline HoodrowThrillson
Re: [IC] GMK Star
« Reply #3 on: Mon, 02 November 2020, 11:48:09 »
Dang I was pretty spot on with my guess of what this would look like, strictly based off of the original IC title.
[Mostly] Retired from Keyboards
Typing on: TKL One - Zealios v1 - 55g TX Springs, TX Films, Lubed with 205g0 - Xiami Beige Cadet + RGB
Collection: IDB60 (gone), Austere (gone), Matrix 1.2og (gone), Matrix 2.0add (gone), RS (so lit), Infinitum (gone), THRILL Proto (destroyed), Matrix 2.0add xmas Starry Night (gone), RS60 (traded), MC65 (traded), Jane v1 CE (gone), GSKT-00 (gone), TKL One Poly (returned), TKL One, RS60, Serenity Proto, Boulevard Proto
Offline norb
Re: [IC] GMK Star
« Reply #4 on: Mon, 02 November 2020, 11:50:49 »
can you feel it, mr. krabs?
Offline Lizcuits
  • KAT PBJ
    • KAT PBJ
Re: [IC] GMK Star
« Reply #5 on: Mon, 02 November 2020, 11:53:24 »
why do i actually kind of like this
Offline dingusxmcgee
Re: [IC] GMK Star
« Reply #6 on: Mon, 02 November 2020, 11:53:32 »
this is it
Offline Dotnick
Re: [IC] GMK Star
« Reply #7 on: Mon, 02 November 2020, 11:59:12 »
I hate this and like this equally. Which means I’ll buy it.
Offline bisoromi
  • Formerly Duwang
  • owo
Re: [IC] GMK Star
« Reply #8 on: Mon, 02 November 2020, 12:00:24 »
is mayonnaise an instrument
(credits to Kokaloo)
Offline Kinesiologist
Re: [IC] GMK Star
« Reply #9 on: Mon, 02 November 2020, 12:01:45 »
Offline treeleaf64
    • treeleaf64
Re: [IC] GMK Star
« Reply #10 on: Mon, 02 November 2020, 12:11:45 »
Patrick and sponge bob
Everyone must pay the cat tax
Offline Paputcher
Re: [IC] GMK Star
« Reply #11 on: Mon, 02 November 2020, 12:30:11 »
:thumb:
Offline paperassgasket
Re: [IC] GMK Star
« Reply #12 on: Mon, 02 November 2020, 12:34:33 »
Yeah everything about this is spot on.
Colors are good. Kitting is good. The only thing is that the Spatula and Krabby Patty kinda don't relate to Patrick but I can get over that.
Maybe bubbles instead? or a rock?
Offline Paputcher
Re: [IC] GMK Star
« Reply #13 on: Mon, 02 November 2020, 12:41:08 »
I was thinking about it and I tried to add rock and bubbles, but on the keycap it seemed a bit boring imo
Offline pixelpusher
Re: [IC] GMK Star
« Reply #14 on: Mon, 02 November 2020, 13:06:02 »
The legend color on the alphas doesn’t seem right to me.  But I love the other colors and the theme.
What does a very light pink for the alpha legends look like?
Offline Swishy
Re: [IC] GMK Star
« Reply #15 on: Mon, 02 November 2020, 13:12:27 »
I fell in love with this set from the first time you posted it 6 months ago. #MyNamesNotRick
Offline guill3m
  • Shut up and take my money
Re: [IC] GMK Star
« Reply #16 on: Mon, 02 November 2020, 13:53:32 »
I kind of don’t really like the colors. At the same time I do really like the set. :-\
Good luck with the IC!
Offline Paputcher
Re: [IC] GMK Star
« Reply #17 on: Mon, 02 November 2020, 14:23:11 »
Thanks for your feedback!
Offline Bachoo
Re: [IC] GMK Star
« Reply #18 on: Mon, 02 November 2020, 14:23:15 »
its about time  :thumb:
Offline paulgali
    • SKME
Re: [IC] GMK Star
« Reply #19 on: Mon, 02 November 2020, 14:46:21 »
ISO layout, but no ISO UK in base? Plssss <3
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
Re: [IC] GMK Star
« Reply #20 on: Mon, 02 November 2020, 14:57:39 »
why is this an unironically good anime set
Offline forevermadrigal
Re: [IC] GMK Star
« Reply #21 on: Mon, 02 November 2020, 15:12:35 »
is this the krusty krab?
Offline Ustinj
Re: [IC] GMK Star
« Reply #22 on: Mon, 02 November 2020, 15:52:57 »
well executed sir
Re: [IC] GMK Star
« Reply #23 on: Mon, 02 November 2020, 15:55:57 »
What if you made one of the novelties to feature Plankton, due to his color, size, and all?
Offline Sissy
Re: [IC] GMK Star
« Reply #24 on: Mon, 02 November 2020, 16:48:02 »
Theme aside I find these colors pretty nice.
Offline treeleaf64
    • treeleaf64
Re: [IC] GMK Star
« Reply #25 on: Mon, 02 November 2020, 16:59:16 »
Pat rick
Offline Kajoler
Re: [IC] GMK Star
« Reply #26 on: Mon, 02 November 2020, 18:09:29 »
aye aye capn
>:0
Re: [IC] GMK Star
« Reply #27 on: Mon, 02 November 2020, 22:33:54 »
honestly best IC of the week
Offline JiiA
Re: [IC] GMK Star
« Reply #28 on: Mon, 02 November 2020, 22:34:02 »
he's beauty, he's grace
Offline stein3
Re: [IC] GMK Star
« Reply #29 on: Mon, 02 November 2020, 22:35:09 »
Re: [IC] GMK Star
« Reply #30 on: Mon, 02 November 2020, 23:01:48 »
LMAO this is actually REALLY good damn
Offline nalf
Re: [IC] GMK Star
« Reply #31 on: Mon, 02 November 2020, 23:07:57 »
This made me laugh but its actually really good
Offline Blamby
Re: [IC] GMK Star
« Reply #32 on: Tue, 03 November 2020, 04:39:23 »
A meme set=a great set
Offline FoC_Tow
  • Brokehlicious
Re: [IC] GMK Star
« Reply #33 on: Tue, 03 November 2020, 05:20:22 »
This is painfully beautiful somehow...
But I guess that means I'm buying one
Offline Janoma
  • certified nerd
Re: [IC] GMK Star
« Reply #34 on: Tue, 03 November 2020, 07:50:45 »
This is a fantastic idea. Maybe even a RAMA green enter cap with an eye on it :eek:
Offline Paputcher
Re: [IC] GMK Star
« Reply #35 on: Tue, 03 November 2020, 08:05:10 »
this set is more about Patrick, so I don't think the novelty of plankton will fit here
Offline Mearaz
Re: [IC] GMK Star
« Reply #36 on: Tue, 03 November 2020, 09:51:34 »
I love the colors! I hope this becomes successful then we might get a sponge bob series...
Offline Scucka
Re: [IC] GMK Star
« Reply #37 on: Tue, 03 November 2020, 13:17:14 »
 :thumb:
Offline depletedvespene
    • Keyboard-related resources.
Re: [IC] GMK Star
« Reply #38 on: Tue, 03 November 2020, 15:41:42 »
You may want to check the "ISO alphas" keys. As the kit stands now, you have an R4 <> (used in English (USA), terminal style) and an R3 #~ (used in English (UK)) key, a combination that doesn't make sense. I'd suggest replacing the latter with an R3 \|.
You may see http://www.farah.cl/Keyboardery/Interactive-Comparator-of-Different-National-Layouts/?left=enUSte&right=enUK to contrast both layouts side by side.
Offline Paputcher
Re: [IC] GMK Star
« Reply #39 on: Wed, 04 November 2020, 00:08:21 »
Already done, I will update today :D
Offline Pach
Re: [IC] GMK Star
« Reply #40 on: Wed, 04 November 2020, 08:03:46 »
I feel like GMK Starfish is a more related name for this set :p
Offline kaysoo1337
Re: [IC] GMK Star
« Reply #41 on: Thu, 05 November 2020, 04:22:29 »
patrick is underrated af imo >:D
Offline Paputcher
Re: [IC] GMK Star
« Reply #42 on: Fri, 06 November 2020, 08:24:25 »
Offline Paputcher
Re: [IC] GMK Star
« Reply #43 on: Sun, 08 November 2020, 14:42:18 »
no this is patrick
Offline CodeMayhem
Re: [IC] GMK Star - [11/6/2020 Kitting update]
« Reply #44 on: Mon, 09 November 2020, 00:57:41 »
we're gonna need a rock artisan for this. Maybe a novelty knob.
Offline kimchijody
« Reply #45 on: Tue, 10 November 2020, 01:48:27 »
Yes
Offline sp.people
« Reply #46 on: Thu, 12 November 2020, 23:24:26 »
cute novelties kit!! :thumb:
Offline beigeandbrown
« Reply #47 on: Fri, 13 November 2020, 14:57:52 »
Can we do a whole keycap series based on spongebob? For real, A colorway based on squidward would look sick. Another cool colorway could be something based upon sandy's squirrel suit.
Offline Paputcher
« Reply #48 on: Mon, 16 November 2020, 12:05:24 »
Offline Paputcher
Re: [IC] GMK Star - Update: Vendors announced, deskmat revealed, new renders
« Reply #49 on: Mon, 23 November 2020, 15:19:11 »
A little update here, I hope you like it
Announced vendors
Added new renders
