Author Topic: Modifying springs  (Read 2488 times)
Offline jcoffin1981
Modifying springs
« on: Sat, 24 April 2021, 01:32:31 »
I love the Kaihl Box Burnt Orange, but they are just too heavy and fatiguing.  The travel distance of these is less than the standard Cherry-  3.6mm vs 4.0mm.   Will this very miniscule amount make a difference in spring selection when replacing?
Offline Pylon
Re: Modifying springs
« Reply #1 on: Sat, 24 April 2021, 01:37:00 »
Box switches do not fit normal Cherry-style springs.
Offline jcoffin1981
« Reply #2 on: Sat, 24 April 2021, 03:44:40 »
Do I need Kaihl branded springs, or are there acceptable aftermarket/generic available?
Offline Leslieann
« Reply #3 on: Sat, 24 April 2021, 08:25:43 »
Sprit has Box compatible springs.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Leopard223
« Reply #4 on: Sat, 24 April 2021, 08:26:53 »
I think sprit sells Kailh BOX compatible springs
Offline Faceman76
« Reply #5 on: Sat, 24 April 2021, 09:14:23 »
G Heavy in Canada has a large selection available.  Don't go too light though as the switch may not reset.
Sent from my SM-G975U using Tapatalk
1800s and heavy springs
Offline jcoffin1981
« Reply #6 on: Sat, 24 April 2021, 11:12:42 »
So if I use Box Brown weight it will not reset?
Offline Faceman76
« Reply #7 on: Sat, 24 April 2021, 11:19:44 »
You'll have to do your own research as to the minimum weight as I went the opposite direction.  It should be safe to assume a slightly lighter spring, one that is used by another box switch, should be a safe bet.
Offline Leopard223
« Reply #8 on: Sat, 24 April 2021, 11:51:21 »
IIRC Pale blue has the 0.25 clickbar which can go pretty low, you can definitly go as low as BOX white, probably more than that.
Offline Leslieann
« Reply #9 on: Sat, 24 April 2021, 16:45:54 »
Dropping 5-10g is usually safe for most switches especially if you add lube (clickbars are usually well lubed), but there is no universal rule because it has to do with how tactile they are, and in the case of Box switches you also have the clickbar.
Basically unless someone already has tried your preferred springs (or lighter) you will have to just try it and see.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline jcoffin1981
« Reply #10 on: Sat, 24 April 2021, 21:24:42 »
I have some experimenting to do.  Thanks for the input guys. :thumb:
