Author Topic: [IC] Axon 40% through-hole keyboard kit  (Read 6795 times)
Offline PewPewLiu
« on: Wed, 05 May 2021, 10:34:40 »
AXON
Pictures:
https://imgur.com/a/w1VYpt1
Please note that these pictures represent version 1.0 which I built for my personal use. A group buy would be conducted with a version 1.1, which has a number of small improvements (see Details section).
IC Form:
https://forms.gle/Cvzs5t53VCi45C3H7
Description:
Axon is a 40% keyboard built using only through-hole components, similar to and inspired by many other keyboards including Plaid, Gingham, Romeo, Discipline, etc.
Axon is very compact at only 12u wide, is QMK compatible, and has a USB-C connector.
This is a continuation from my post on r/MechanicalKeyboards:
https://www.reddit.com/r/MechanicalKeyboards/comments/n0fhxn/axon_my_diy_40_throughhole_keyboard/?utm_source=share&utm_medium=web2x&context=3
where many commentors expressed their interest in a group buy.
I am willing to run a group buy if there is indeed sufficient interest, so please fill out the IC form if you are interested!
Axon is open hardware; you can find the designs on my github: https://github.com/thatfellarobin/axon.
Of course, this means that you can produce Axon for yourself without going through a GB process for a kit, but the GB would save you the effort of sourcing parts and will lower the cost if all you want is a single unit.
Details:
- An illustrated build guide will be created.
- The kits will ship from Ontario, Canada.
Changes for Axon v1.1 (GB version):
Note: this change list is not finalized
- Fixed issue where the stabilizer blocked a mounting hole.
- Spacebar widths can be swapped (i.e. 2.25u-2.75u or 2.75u-2.25u).
- Update screw placements to ensure acrylic cover symmetry along both x and y axis.
- Optimize decoupling capacitor placement.
- Polyfuse now has room to lay horizontally if desired.
- Minor adjustments to back side silkscreen.
- Numerous minor layout and routing changes.
To be included in the kit:
- Top and bottom PCB
- Acrylic component cover
- Standoffs and fasteners
- All necessary electrical components
- ATmega328p with bootloader installed
Not included:
- Soldering tools (soldering iron, solder, flux, etc.)
- Other tools (screwdriver, side cutters, etc.)
- USB-C cable
- Keyswitches
- Keycaps
Regarding group buys and trust:
I will be fully transparent: I have never run a group buy before, and have never sold product online. However, I believe that this group buy can be successful for the following reasons:
- The available quantity will be limited to ensure that I do not end up with an unmanageable number of orders.
- This kit does not involve substantial manufacturing risk. The parts are not difficult to procure, and I will source the PCBs and other components from reputable sources.
- The online store will be run as a Shopify store or similarly reputable online commerce platform in order to make sure that payments and your data are secure.
Offline MIGHTY CHICKEN
Re: [IC] Axon 40% through-hole keyboard kit
« Reply #1 on: Wed, 05 May 2021, 11:08:37 »
Would love if a 3d printed case could be made, one with thiccccc bezels
Offline XCaellaX
« Reply #2 on: Wed, 05 May 2021, 11:13:43 »
Very interesting and quite nice design! Do you have an idea of the targeted manufacturing/purchase price?
Offline frostykoala
  • consider Nightlight
    • Check out some Renders :)
« Reply #3 on: Wed, 05 May 2021, 11:18:24 »
through hole AND 40s  :eek:
sign me up
« Last Edit: Wed, 05 May 2021, 11:22:40 by frostykoala »
Offline PewPewLiu
« Reply #4 on: Wed, 05 May 2021, 11:28:27 »
Thanks! I have a price target in mind that is in line with similar kits, but I haven't finalized it yet. If there's enough interest to proceed, I'll seek quotes for the kit components which will allow me to finalize prices.
Offline kidpid
« Reply #5 on: Wed, 05 May 2021, 12:06:47 »
It's great to see this come to GB! Have you thought about reaching out to Jake from P3D for an acrylic and/or 3D-printed case for this?
« Reply #6 on: Wed, 05 May 2021, 12:52:17 »
Would love
Offline ZeroZeroOne
« Reply #7 on: Wed, 05 May 2021, 14:42:26 »
I was thinking about ordering the PCB from your github and sourcing the components myself, but seems like I wont need to now! Very nice!
Offline PewPewLiu
« Reply #8 on: Wed, 05 May 2021, 15:00:57 »
Great feedback. It hasn't crossed my mind before but I will give it some serious thought  :thumb:
Offline Bonsa
« Reply #9 on: Wed, 05 May 2021, 17:21:58 »
I like it! glad to see you're in the discord too :)
+1 on the big bezel case! also WKL option for a V2?  ;D
Offline minicap
« Reply #10 on: Wed, 05 May 2021, 17:46:07 »
This looks great, love the diode symmetry and through-hole kits with visible components are super fun. Would love to build this as my first 40%!
Offline Fweedum
« Reply #11 on: Thu, 06 May 2021, 00:48:24 »
I think it looks super cute! Better looking than a romeo imo. I would love to see the bottom row become symmetrical and support a 6u spacebar. Then this would become my endgame travel board in a heartbeat.
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #12 on: Thu, 06 May 2021, 01:27:33 »
Very cool, I like seeing all the bits on top.
Offline minicap
« Reply #13 on: Wed, 23 June 2021, 01:26:18 »
Any updates on this project? :D
