Author Topic: [IC] EPBT Cool Kids 2  (Read 24637 times)
Offline biip
    • @biipmk
« on: Tue, 11 May 2021, 03:13:37 »
Did you miss the boat to be a cool kid? Now you have a second chance!
Already a cool kid? Let’s be even cooler!
Group buy info
From June 1st to 30th 2021.
Shipping ETA: Q4 2021.
Proxies:
  • Worldwide: KBDFans
  • SA: Fancy Customs
  • CA: DeskHero
  • EU: Candykeys
  • Asia: KBDFans
  • SEA: Monokei
  • Oceania: DailyClack
Material:
  • 1.5mm thick dye-subbed PBT keycaps (Smileys are PBT double-shot) manufactured by EnjoyPBT.
Colors:
  • 030 60 50
  • 080 80 60
  • 150 70 40
  • 240 70 30
  • 080 93 05
Renders
boop65
boop65
Kei
Kei
Kits
Deskpads
Smileys line
Smileys pattern
Cool smileys
Line smileys but cool
D60Lite Cool Kids edition
Specs:
  • Layout: 60% WK and HHKB
  • PCB: DZ60RGB-WKL/DZ60RGB ANSI V2, RGB hot-swappable PCB ( QMK and VIA supportable, Type-C, support Windows, Mac, Linux )
  • Plate: Polycarbonate
  • Stabilizers: KBDfans transparent stabs
  • Gasket: 2 sets of gaskets, injection-molded silicone gaskets, foam gaskets
  • Mute mat: install between PCB and Plate
  • Bottom silicone pad:which is tightly fitted. Compared with kbd67lite, it is a newly added configuration.
  • Case: PC+ABS material, using an injection molding process, the surface is matte, opaque
  • USB-C Cable
  • Colors: Bottom Case (white); Top Case (White), USB Port (white) - color matched with ePBT Cool Kids
  • Typing angle: 6°
  • Structure:Gasket mount
Reminder: D60Lite and ePBT Cool Kids keycaps are sold separately.
Estimated Ship Date:2 months after the group buy
Cables
Custom Cool Kids cables will be available during the group buy through Keebstuff
Thanks for the support.
Signature:
Code: [Select]
[url=https://geekhack.org/index.php?topic=112754.0][img width=302 height=120]https://media.biipmk.com/epbt_coolkids/EPBT_CoolKids-signature.png[/img][/url]
« Last Edit: Mon, 31 May 2021, 12:04:36 by biip »
Offline Ella
  • Why is it called an oven
Re: [IC] EPBT Cool Kids 2
« Reply #1 on: Tue, 11 May 2021, 03:15:43 »
no way
Offline Curin Derwin
« Reply #2 on: Tue, 11 May 2021, 03:16:00 »
Look great! Any changes from last run?
Offline biip
    • @biipmk
« Reply #3 on: Tue, 11 May 2021, 03:16:40 »
Some kits adjustment and addition of colorful smileys :thumb:
Offline Techdude594
« Reply #4 on: Tue, 11 May 2021, 03:17:27 »
Loving my R1 kit, glad to see cool kids back again so soon! Definitely in for the colorful kit, and maybe some more. ePBT is excellent quality as well!  :thumb:
Offline KnoblesseOblige
« Reply #5 on: Tue, 11 May 2021, 03:18:24 »
Kitting looks great! Any chance you could include another 3u in the small bars kit?
Discord: Taylor#2460
Offline Hell-es
« Reply #6 on: Tue, 11 May 2021, 03:22:36 »
Very nice... Thanks for including colorful kit and more smileys
Thought about "colorful" bottom row?
Offline dededecline
    • Linktree
« Reply #7 on: Tue, 11 May 2021, 03:32:51 »
+1 for a second 3u spacebar
Offline dstaar
« Reply #8 on: Tue, 11 May 2021, 04:21:02 »
so can I mix match with Round 1?   are the colors all same?
Offline biip
    • @biipmk
« Reply #9 on: Tue, 11 May 2021, 04:30:21 »
Yup :thumb:
Offline LaserCrafter
  • reeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
« Reply #10 on: Tue, 11 May 2021, 04:52:55 »
lets go.
Keyboard Collection: Unikorn, Orion v1, Orion v3, Realforce 87u, Das II, 356mini, Wang 325-3770, Lightpad v2, Deko Fast Action
Keyset Collection: OG Doubleshots x2, CRP 2551 R4, Muted 2, Cyan R1, WoB, DCS Wyse, ISO OG POM, ePBT Blanks, BSP Blanks, BoW + Gigachild, Minimal R1, SAD Dyesubs,
Offline dstaar
« Reply #11 on: Tue, 11 May 2021, 05:01:45 »
Yup :thumb:
this is cool and so welcome!  :cool:
Offline Rossman360
    • Montsinger
« Reply #12 on: Tue, 11 May 2021, 05:40:41 »
Hmmm, rubbers must be British for erasers  :)
« Last Edit: Tue, 11 May 2021, 05:42:15 by Rossman360 »
Offline NoPunIn10Did
    • NoPunIn10Key
« Reply #13 on: Tue, 11 May 2021, 05:47:09 »
Maybe these should be the Too Cool Kids.
Offline Entity.
  • Entity#1234
« Reply #14 on: Tue, 11 May 2021, 06:42:42 »
😳 Rubbers
Offline XiXora
« Reply #15 on: Tue, 11 May 2021, 07:46:32 »
UK ISO is missing R1 `| 2@ 3£
US ISO is missing R3 |\
Any real reason?
Offline biip
    • @biipmk
« Reply #16 on: Tue, 11 May 2021, 07:56:23 »
Any real reason?
The intention was to offer a very basic ISO support.
Offline NovaRMK
« Reply #17 on: Tue, 11 May 2021, 08:03:43 »
Do I like it? Yes. Do I want it? Yes. Will I get it? Most definitely.
But seriously tho, I'm glad to see this came back for a r2.  :thumb:
Offline AshF
« Reply #18 on: Tue, 11 May 2021, 08:17:03 »
Any real reason?
A great shame! This is the reason I didn't hop onto the 1st GB, would be nice to  see some changes to this on the second run (quietly keeping my fingers crossed).
 GLWIC > GB
Offline iinko_mk
  • Status: broke
« Reply #19 on: Tue, 11 May 2021, 08:55:14 »
when the kids are just too cool
    • NoPunIn10Key
« Reply #20 on: Tue, 11 May 2021, 10:01:09 »
Any real reason?
If that's the case, I'd remove:
- R4 Backslash-Pipe
- R3 Quote-@
- R3 Hash-Tilde
And then add:
- R3 Backslash-Pipe
That would yield a much more consistent layout and saves you two keys.  Alternatively you can go for full UK, which would drop one of your current keys (R4 <>) and add three UK keys to the number row.  Either way is a good path, but you're weirdly halfway between them at the moment.
Offline Yumelon
« Reply #21 on: Tue, 11 May 2021, 11:15:44 »
I guess I'm reupping on more smiles :D Smile my alphas
« Last Edit: Tue, 11 May 2021, 11:17:16 by Yumelon »
Offline norb
« Reply #22 on: Tue, 11 May 2021, 11:47:08 »
as an already cool kid i can't say no to the colorful kit :thumb: :thumb: :thumb:
Offline danliu
« Reply #23 on: Tue, 11 May 2021, 12:11:37 »
+1 for 1 extra 3U bar. there are a few board/pcb in development with double 3u spacebars including the Type-K, sst60, plexus75, etc. 3U has the advantage of symmetry and stability (3u bars use 3u stabs, 2.75u use 2u stabs - not as stable)
Offline Leviathan
« Reply #24 on: Tue, 11 May 2021, 14:21:18 »
Cool Kids Too
Too Cool Two Kids
Offline BabyBoy2k
« Reply #25 on: Tue, 11 May 2021, 14:23:08 »
Nice! I love my set. I'll definitely be picking up the colorful smileys and rubber kits on R2.
Offline asciisii
« Reply #26 on: Tue, 11 May 2021, 15:45:05 »
Definitely in for the colorful smileys kit to add onto my round 1. My Rubbers kit's white spacebars were scuffed and unusable in R1 (dealt with vendor), so hoping thats fixed. The crooked B to the kit for alice compat is a nice addition! Might have to pick it up XD
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #27 on: Tue, 11 May 2021, 15:59:06 »
Will be waiting for the US vendor :cool:
Looking forward to seeing the PBT doubleshot in person even if it's not the whole set.
Offline LiTurk
« Reply #28 on: Tue, 11 May 2021, 23:03:39 »
lets go
Offline Woovie
« Reply #29 on: Wed, 12 May 2021, 00:06:06 »
Great set, didn't hop on round one and probably won't here, but if you ever make an SA version I'll be there! Such a fun idea.
As an aside, curious what about this thread is defined as an IC? It's fully planned and kitted, vendors are determined, renders are done, dates are set, pricing is set.
Is this just a pre GB post? What's the point? It's just an ad at that point.
Not trying to be hateful, it's a genuine question. From my understanding, this was the kind of thing discussed by geekhack staff as something they weren't allowing anymore. A bit of a meta topic.
Offline vestun
« Reply #30 on: Wed, 12 May 2021, 02:10:58 »
I like the design of this set! Simply amazing! the letters are also really cool.
Offline Lazesummerstone
  • ҠѤӋϚΔΡѕ
    • MY Keycap set - Transmutation
« Reply #31 on: Wed, 12 May 2021, 14:13:23 »
I still would like to see your bad-kid version of this set. Something a little darker, messier... the kind of kid that ain't doin their homework.
Offline lecorsair
« Reply #32 on: Wed, 12 May 2021, 15:18:05 »
That would be called SA Troubled Mind  :p
Offline AshF
« Reply #33 on: Wed, 12 May 2021, 15:19:34 »
Ooooo, I think you maybe onto something here!
+1 bad-kidz
Sent from my ASUS_I003D using Tapatalk
  • ҠѤӋϚΔΡѕ
« Reply #34 on: Wed, 12 May 2021, 15:28:02 »
+1 bad-kidz
[/quote]
I'm sure that Biip will continue coming up with cool and quirky takes on keycaps! At least I hope so because to me each one feels like a breath of fresh air.  :thumb:
Offline biip
    • @biipmk
« Reply #35 on: Fri, 14 May 2021, 10:05:25 »
Any real reason?
- R4 Backslash-Pipe
- R3 Quote-@
- R3 Hash-Tilde
And then add:
- R3 Backslash-Pipe
Here you go
    • NoPunIn10Key
« Reply #36 on: Fri, 14 May 2021, 10:23:53 »
Offline treeleaf64
    • treeleaf64
« Reply #37 on: Fri, 14 May 2021, 12:30:08 »
What if I don't want to be cool    What if I just want to be happy  Then what do I do,  Mr Biip ?
Everyone must pay the cat tax
Offline Afresh
« Reply #38 on: Fri, 14 May 2021, 13:24:55 »
certified cop  :thumb:
Offline azzipa
« Reply #39 on: Fri, 14 May 2021, 13:31:21 »
looks great! and to add to the fun factor, i would love to see R3 1.75u "have fun!"  glwgb!
Offline norb
« Reply #40 on: Fri, 14 May 2021, 19:27:36 »
buy only smileys kit i guess :-*
Offline LordHaveMercy
« Reply #41 on: Sun, 23 May 2021, 14:48:15 »
Wanna know something I just realized about this set?
It’s sort of inspired by the designer label “coolkidsnyc”. I had no darn idea. I thought it was a challenge to Biip to make the most “ridiculous” keycap set they could imagine.
Maybe it was both?
Offline biip
    • @biipmk
« Reply #42 on: Sat, 29 May 2021, 10:50:22 »
Cool update:
Specs:
  • USB-C Cable
  • Typing angle: 6°
Reminder: D60Lite x ePBT Cool Kids doesn't come with the keycaps.
