Author Topic: [IC] Valli60 - 60% Keyboard  (Read 20705 times)
Offline made in China
« on: Wed, 19 May 2021, 06:12:56 »
I am very glad to share our second product with you, I am  ABBB, where are you?
First of all, let us take a look at Valli60 with the  pictures, which is our definition of this product, simple and meaningful of design.
Kit information:
Typing Angle: 7°
Construction: Gasket mount
Case options:
         Aluminum: anodized black, anodized silver,anodized gray
         Carbon fibre:black
         PC:transparent
-Plate options
        Brass: Primary
        PC:transparent
        carbon fiber :black
Optional accessories:wired not hot-swap pcb,QMK&VIA suppor
sound test https://youtu.be/5uZdvUFw0zc
for latest update,pls follow:https://discord.gg/D6tzYKgv67
Update history
2021/5/19 IC post
2021/5/20 add and change some pics
2021/5/21 add sound test
« Last Edit: Thu, 20 May 2021, 20:06:24 by made in China »
Offline marshskitow
Re: [IC] Valli60 - 60% Keyboard
« Reply #1 on: Wed, 19 May 2021, 06:40:58 »
Looks good, like that there is a different top. Looks like it's customizable  :thumb:
Offline MIGHTY CHICKEN
« Reply #2 on: Wed, 19 May 2021, 12:17:08 »
Gah damn, that leafspring tho
Offline SDKCAMPING
« Reply #3 on: Wed, 19 May 2021, 13:31:35 »
Looks like the Leaf Springs probably won't do anything since the gasket covers the entire thing
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline cecioclock
« Reply #4 on: Wed, 19 May 2021, 18:26:02 »
Loving the carbon fiber X aluminum combination. Drooling rn...
Offline Ustinj
« Reply #5 on: Wed, 19 May 2021, 18:31:39 »
Please no north facing LEDs.
Offline treeleaf64
    • treeleaf64
« Reply #6 on: Wed, 19 May 2021, 18:55:12 »
Yes it is a stupidly designed  thing because the  "leaf spring"   doesn't actually do anything.   it's basically top mount   or like normal "gasket" mount   or whatever this stupid   hobby calls it
The treeleaf is angry at the Hobby and  He doesn't like it!! Stupid Inconsistent Terminology!
Everyone must pay the cat tax
Offline Cubic // esc lab
  • Formerly 'esclab'
    • esc lab
« Reply #7 on: Wed, 19 May 2021, 18:59:17 »
Exterior design wise looks interesting
Would need to get some protos out for real functional judgement though
Also can we just agree that keeb ICs should have protos?
Renders alone only tell so little of the story
« Reply #8 on: Wed, 19 May 2021, 20:22:17 »
In fact we already have a protype, I will update the sound test later
Offline adi
  • adi.kbds; Consider ePBT Fruit Chew
    • Adi Nikumbh
« Reply #9 on: Wed, 19 May 2021, 21:15:52 »
North facing LEDS? in 2021?
Also, how much flex you reckon those leaf springs actually add compared to standard gasket?
Offline LiTurk
« Reply #10 on: Wed, 19 May 2021, 21:33:07 »
 :-X i have nothing to say
Offline seh0nk
    • tech advantage blog
« Reply #11 on: Thu, 20 May 2021, 01:09:59 »
If the gaps in the middle of the plate are 1.53mm, that means the plate strips on either side are 0.5mm   :eek:
seems like the plate will be hard to build with and not very durable. Especially with more brittle materials.
« Reply #12 on: Thu, 20 May 2021, 04:23:45 »
We  test  the protype and feel that it is OK. The PC material is not fragile,It's been in use for almost a month
« Reply #13 on: Thu, 20 May 2021, 04:27:11 »
Have you ever used it?
« Reply #14 on: Thu, 20 May 2021, 06:26:18 »
sorry,wrong render
Offline Ranger_Trivette
« Reply #15 on: Thu, 20 May 2021, 08:28:35 »
the upper part prevent the leaf spring to bend upward. true.
but, compared to the same design with solid/filled plate, this leaf spring plate will result more flexible.
am i wrong?
Offline treeleaf64
    • treeleaf64
« Reply #16 on: Thu, 20 May 2021, 09:31:28 »
Y'all don't have proto pictures, so I'm assuming you haven't used it either  :rolleyes:
Offline treeleaf64
    • treeleaf64
« Reply #17 on: Thu, 20 May 2021, 09:33:48 »
am i wrong?
maybe if you're pressing hard but I can't see it being different in normal typing
Offline Ella
  • Why is it called an oven
« Reply #18 on: Thu, 20 May 2021, 11:03:07 »
Yay useless leafsprings
Sent from my M2007J20CG using Tapatalk
Offline Que7797
« Reply #19 on: Thu, 20 May 2021, 12:50:37 »
The aesthetic and some of the layout choices are not my personal preference, especially the open bottom row, but the rest of the plate is interesting. Im not sure how functional the flex cuts will be, and durability would definitely be a concern but you have obviously put some time into the design and im looking forward to seeing and hearing the proto, if only so you can silence all the armchair designers in this thread, haha!
« Last Edit: Thu, 20 May 2021, 12:55:50 by Que7797 »
Offline Joaquox
« Reply #20 on: Fri, 21 May 2021, 01:30:43 »
Sound test is up
I think it's worth mentioning that ABBB and his team has probably made the fastest GB of 2021 with the Vast-60, which was delivered in under 2 months at a very juicy price point!
Offline SDKCAMPING
« Reply #21 on: Fri, 21 May 2021, 02:34:43 »
the sound is not to my taste, maybe lubing the switches will help but it sounds too hollow and not much better than an entry tray mount like tofu, maybe another plate material or some foam would help but it will have to be a pass from me.
by the way for the leaf springs people are talking about maybe it is that the designer was not aiming for them to be leaf springs since they are completely blocked from below so they cant flex, maybe it is just for aestheic purpose
Offline SDKCAMPING
« Reply #22 on: Fri, 21 May 2021, 02:36:57 »
the space bar sounded like it was a whole different keyboard, WTF
Offline Joaquox
« Reply #23 on: Fri, 21 May 2021, 06:11:18 »
The plate is cut very differently for the bottom row!
Offline hottrout
  • I'd Hit Dat Key
« Reply #24 on: Sat, 22 May 2021, 04:28:55 »
Love the CF on the top. great looking board design and could sound really good to use.  Watching.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
« Reply #25 on: Sat, 22 May 2021, 09:56:12 »
the spacebar sounds strange.
not bad, but still strange  :D
Offline kioskhill45
« Reply #26 on: Sat, 22 May 2021, 19:31:07 »
How does HHKB or WKL or that weird arrow key layout work with the clear polycarbonate? Do you see the plate under it or will the case have blockers? It sort of seems like the latter in the renders, but I'm not sure.
« Reply #27 on: Sat, 22 May 2021, 21:40:58 »
have blockers,you are correct
Offline kioskhill45
« Reply #28 on: Sun, 23 May 2021, 01:14:00 »
Ok cool! Really excited for this
« Reply #29 on: Sun, 23 May 2021, 22:22:23 »
Poron on the top and the bottom of the plate , and the flex cut of the plate itself can indeed make the keyboard feel a relatively soft typing
Offline menuhin
« Reply #30 on: Fri, 28 May 2021, 11:14:47 »
Please use some nicer feet - these feet have been there since 2013 or older and are featured in < $70 low-profile keyboard cases.
I look forward to the evolution of this design otherwise.
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline Domantas
« Reply #31 on: Thu, 05 August 2021, 14:50:59 »
Hey,
Is it universal plate design? And gonna be honest yeah those feets ugly, please change it
Offline VAMP
  • VAMP
    • Buy me a Ko-fi maybe?
« Reply #32 on: Mon, 09 August 2021, 06:20:09 »
i like how this looks!
Your friendly neighbourhood graphic designer. Hit me up if you need any graphic works! ✏️
https://www.instagram.com/by.vamp/
