Author Topic: I made the jump to 65% (NK65)  (Read 2293 times)
Offline arock0627
« on: Mon, 24 May 2021, 19:22:37 »
I made this thing fully aware I'd eventually need to get a new Swiftcables cable (due to the Arctic KAT set I'm waiting on) but I have decided to make the jump and use what I had anyway, and I'm now the proud owner of a fully functional NK65 Aluminum Silver.
I have been blown away at the difference, and not in the ways I expected
1. It's quieter.  Despite using the same type of keycaps I had on my old keyboard, it's half as loud.
2. I'm typing faster and have nearly gotten used to the FN+Num instead of function row.
3. I think I'm just typing better.  I make a lot less errors.
I really like how solid and heavy this slab of aluminum is, and I'm also really impressed at the lack of pinging.  I may have to install a dampener sometime to lower the volume  but for right now I'm kind of completely satisfied.  Now I just need my Arctics to arrive so I can get this thing in its full grey/blue/silver glory.
Offline Kelph1
Re: I made the jump to 65% (NK65)
« Reply #1 on: Mon, 24 May 2021, 22:28:09 »
What is that capset and where did you get it?
Offline arock0627
« Reply #2 on: Mon, 24 May 2021, 23:12:06 »
Keycap set is Varmilo Morse Code, you can get it here
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=7698
Offline niner
« Reply #3 on: Tue, 25 May 2021, 14:55:54 »
Love the keycaps.
