Author Topic: [IC] Iskar - 65% Keyboard from Bitmap Studio  (Read 92370 times)
Offline Bitmxp
  • I値l take 12
    • Bitmap Studios
Re: [IC] Iskar - 65% from Bitmap Studio
« Reply #50 on: Mon, 14 June 2021, 20:33:07 »
Maybe I am missing it, but what is the mounting on this, gasket strips?
Will be gasket mounted.
Offline NightRye_
  • keebs n' fluff
Re: [IC] Iskar - 65% Keyboard from Bitmap Studio
« Reply #51 on: Mon, 14 June 2021, 23:30:08 »
so Frusta Fundamental with brass weight?
Sent from my SM-M115F using Tapatalk
Offline Bitmxp
  • I値l take 12
    • Bitmap Studios
« Reply #52 on: Tue, 15 June 2021, 01:08:56 »
During the design phase, I became aware of the Frusta Fundemental and knew that this question would come up. Iskar and Frusta Fundamental are not associated in any way and development on Iskar had already begun before the Frusta was announced (August 2020). I was simply waiting for a suitable time to post an IC.
Offline sup3r170va
« Reply #53 on: Tue, 15 June 2021, 01:52:06 »
what's the front height of the keyboard?
One concern I have with Frusta Fundamental is that the front height of 22mm is too high to type with comfort.
Offline Bitmxp
  • I値l take 12
    • Bitmap Studios
« Reply #54 on: Tue, 15 June 2021, 11:24:50 »
The front height of Iskar is 20mm (subject to change), but around 20mm +- 3mm is pretty standard for keyboards in general.
Offline sup3r170va
« Reply #55 on: Tue, 15 June 2021, 11:58:05 »
usually 20mm or lower. other than a keychron, all my proper boards are 20mm or lower.
Offline Neely_12
« Reply #56 on: Tue, 15 June 2021, 12:23:28 »
Cool idea with the rims. I would love to have a blue case with white rim
Offline anpoint
« Reply #57 on: Tue, 15 June 2021, 12:24:28 »
yup, sign me up for one!
Offline NightRye_
  • keebs n' fluff
« Reply #58 on: Wed, 16 June 2021, 00:24:00 »
I was just joking, there is always going to be similar boards that come up, glwic anyway.
Offline Bitmxp
  • I値l take 12
    • Bitmap Studios
« Reply #59 on: Wed, 16 June 2021, 00:43:59 »
No worries! Thanks for giving me an opportunity to answer that question. :)
Offline Bitmxp
  • I値l take 12
    • Bitmap Studios
« Reply #60 on: Wed, 16 June 2021, 00:44:16 »
Navy/Silver
Offline Bitmxp
  • I値l take 12
    • Bitmap Studios
« Reply #61 on: Sat, 19 June 2021, 22:00:08 »
Major things of note:
- Gasket Mount design is confirmed. Plate design is not.
- Iskar's switches are oriented to not interfere with any keycaps (GMK Included). The orientation may affect RGB lighting.
Thank you for your interest!
« Last Edit: Wed, 23 June 2021, 20:53:04 by Bitmxp »
Offline DogSpark
« Reply #62 on: Wed, 23 June 2021, 20:41:13 »
- Iskar features North Facing switches, not south facing.
Why make this decision to go back to North facing as showed in the renders, which you corrected it would not be?  I'm hoping you made a typo here.
Offline DogSpark
« Reply #63 on: Wed, 23 June 2021, 20:58:58 »
phew... :D
Offline ThomasLT
    • ThomasLT Studio
« Reply #64 on: Thu, 24 June 2021, 03:04:00 »
wow I want one
Offline Bitmxp
  • I値l take 12
    • Bitmap Studios
« Reply #65 on: Wed, 30 June 2021, 16:41:54 »
No typo, thanks for your patience
Offline steamb0x
« Reply #66 on: Thu, 01 July 2021, 22:10:50 »
I think I'm in love :-*
Offline FluffyWaffle
« Reply #67 on: Fri, 02 July 2021, 04:15:16 »
I'm picking this one up, whatever the price  :D
Offline Scriba
« Reply #68 on: Mon, 12 July 2021, 13:50:55 »
interesting
Offline S�lstic3
« Reply #69 on: Sat, 24 July 2021, 23:54:32 »
Beautiful board any updates? And can we also get a render with the rose weight.
Sent from my ONEPLUS A6013 using Tapatalk
Offline Bitmxp
  • I値l take 12
    • Bitmap Studios
« Reply #70 on: Tue, 27 July 2021, 17:44:27 »
Protos are almost done! new PCB and board design.
Offline Xherion
« Reply #71 on: Fri, 30 July 2021, 02:41:47 »
Can't wait to check out the protos, will there be a sound test too?
Offline JavelinJyc
« Reply #72 on: Wed, 25 August 2021, 23:26:34 »
is the iskar make in china?
Offline Bitmxp
  • I値l take 12
    • Bitmap Studios
« Reply #73 on: Wed, 01 September 2021, 13:37:37 »
Offline Bitmxp
  • I値l take 12
    • Bitmap Studios
« Reply #74 on: Wed, 01 September 2021, 13:38:00 »
Yep! Soon.
Offline SovereignFate
« Reply #75 on: Tue, 07 September 2021, 04:33:18 »
Yep! Soon.
Will it be with linear and tactile aswell?
Offline Bitmxp
  • I値l take 12
    • Bitmap Studios
« Reply #76 on: Sat, 09 October 2021, 18:29:04 »
Yep! Soon.
It will not come with switches.
Offline _rubik
« Reply #77 on: Sun, 10 October 2021, 14:04:20 »
Yep! Soon.
I think they meant "will the sound test be performed with both linears and tactiles"
ai03 Meridian 、 Mech 27 、 E8.5 、 Brutal60 、 SSK White Label 、 HHKB Pro JP 、 vAEK68 Alps Blues 、 RF87u
Offline Bitmxp
  • I値l take 12
    • Bitmap Studios
« Reply #78 on: Sun, 10 October 2021, 15:57:47 »
Yep! Soon.
Oh! I will be sending prototypes to different streamers so you値l get sound tests with a variety of switches.
Offline Bitmxp
  • I値l take 12
    • Bitmap Studios
« Reply #79 on: Thu, 16 December 2021, 23:28:14 »
Bumping as this project is about to resume and final protos about to come in.
Offline 8um8lebee
« Reply #80 on: Sun, 26 December 2021, 20:48:39 »
I'll be honest I'm not the biggest fan of the "curved" edge of the bottom mirror finish bottom piece. Reminds me of the Viktus Sinne. Looks kinda like an Asian kid schoolbag...I just can't unsee it
280378-0
280374-1
280376-2
Wish that bottom edge is either just completely flat (ala 7V) or a more aggressive inverted triangle of some sort.
« Last Edit: Sun, 26 December 2021, 20:51:11 by 8um8lebee »
