Author Topic: [IC] Deep Purple Linear Switches  (Read 7589 times)
Offline KeyboardPeople
« on: Sat, 12 June 2021, 18:21:40 »
Introducing the Deep Purple Switches from Keyboard.People, a new NA Vendor.
We’re founded by a couple of hobbyists who have become deeply immersed in the keyboard scene over the past couple of years. So enough vague information about us and onto the switch at hand.
What are they? They are a full polycarbonate double-spring linear switch manufactured by Tecsee! The switch feel we were trying to obtain is moon-shoe-like, so stronger spring resistance for infrequent bottom outs and an extremely smooth housing.
Deep Purple Switch Info
  • Linear switch manufactured by Tecsee, makers of the Purple Panda and Blue Velvet switches.
  • Purple-dyed polycarbonate housing and stem, aiming to be near Pantone 274-C
  • 68g Gold plated double-length spring
  • Factory-lubed
  • MOQ of 50k.
  • Pricepoint to be near 0.65c but not locked down
What has been done so far? We’ve already received a small batch of uncolored samples from Tecsee, and they came out wonderful! We are both fans of linear switches and, although the market is already flooded with recolored JWKs and heavy hitters, we wanted to give this a shot with this manufacturer after being so impressed.
Sound and Feel? Being an all polycarbonate switch, they are most similar in sound to the Water King switches. The double-length spring provides a more consistent feel throughout the press. There is very little noticeable scratch stock, but heavier lube will bring a deeper sound. The housing is very tight with minimal stem wobble that does not require filming.
Why? We wanted a switch that straight from the manufacturer provided a great experience. Also... you know... because they are purple! They trigger that nostalgia reflex from our childhood gaming consoles and make for some seriously good barebones keyboard pics.
To Do:
  • If we see a lot of positive feedback,  we’ll order a sample batch large enough for a whole keyboard and do a sound test. (Hopefully any one of my delayed GB keyboards shows up, so I can conduct the sound test :^) ). Larger sample batch on its way!
  • Determine international proxies
  • Reviews - Please contact us if you are a content creator looking to test these out!
Please let us know your thoughts in this IC Form
« Last Edit: Sat, 12 June 2021, 18:34:42 by KeyboardPeople »
Re: [IC] Deep Purple Linear Switches
« Reply #1 on: Sat, 12 June 2021, 18:23:13 »
Reserved
Offline Rowbear
« Reply #2 on: Sat, 12 June 2021, 18:29:11 »
Looks nice! GLWIC
Offline TheWonderBubble
« Reply #3 on: Sat, 12 June 2021, 21:09:15 »
You had me at purple.
In on this for more info.
Shhhhh...my wallet doesn't know I'm here.
Offline Alpha1
« Reply #4 on: Sat, 12 June 2021, 22:07:08 »
Neat. GLWIC!
Offline Neely_12
« Reply #5 on: Sat, 12 June 2021, 23:06:41 »
Feel like a white stem or some contrasting color for the stem could be cool
Offline Rubbermilitia
« Reply #6 on: Sun, 13 June 2021, 01:07:43 »
Cool idea, maybe gray if they are going for the nostalgic look like buttons on a translucent purple gameboy or joystick on a n64 controller.
Also watching this and very curious.
Sent from my SM-G950U1 using Tapatalk
Offline Mr Chrome
« Reply #7 on: Sun, 13 June 2021, 08:19:55 »
I’m apparently a big purple fan so this looks real nice. I find full polycarbonate too clacky for me though, but if you ever run other switches I’ll keep an eye out  :)
“This plastic rectangle is alright. The plastic rectangles on top of it, though...”
Offline HelloThisIsDog
« Reply #8 on: Sun, 13 June 2021, 12:43:04 »
I'm definitely down for that all deep-purple colorway! Way to go!
Offline drfilco
« Reply #9 on: Sun, 13 June 2021, 15:55:16 »
I love the all-purple polycarb look - and I'm also interested to see Tecsee's take on the stem material.
Offline AKiwi92
  • KiwiKeebs
« Reply #10 on: Sun, 13 June 2021, 16:22:13 »
Look purp gang assemble I am down for these :P
Offline azzipa
« Reply #11 on: Sun, 13 June 2021, 20:30:54 »
deep purple and grey? sounds like smoke on the water!
and fire in the sky!
« Last Edit: Mon, 14 June 2021, 08:51:58 by azzipa »
« Reply #12 on: Mon, 14 June 2021, 09:39:00 »
We did consider contrasting stems at a time, but once we decided on all polycarb we thought the all-purple theme suited them better.  However the housings are really rad, so they could be prime frankenswitch material. Heck maybe a dark grey kiwi stem would ace that n64 theme and make for a crazy tactile... We'll definitely explore this.
Offline Bonobo
« Reply #13 on: Mon, 28 June 2021, 12:39:11 »
reserved
Offline Keeblet_257
« Reply #14 on: Tue, 29 June 2021, 07:58:10 »
hope we get a EU vendor
Offline james97
« Reply #15 on: Tue, 29 June 2021, 10:08:44 »
Look mysterious and nice  ;D
