Author Topic: [IC] MIXTAPE V.1 65%  (Read 22502 times)
Offline i_Do7
« on: Tue, 22 June 2021, 21:31:37 »
Hello Geeks :)
Introducing the 65% Keyboard that I've been working on lately, its called
( MIXTAPE V.1 )
Inspired by the Cassette tape
Features :
- Top and Bottom Aluminum Case (E-Coated Black-Yellow-White).
- 7° typing angle.
- Brass bottom weight
- Top mount.
- Plate ( Brass - Aluminum - PC )
- PCB Still WOP.
Dimensions :
Rendered images :
The colors might be slightly different between the renders and the prototype :)
IC Form : https://forms.gle/ZeWDGzafbEdAjc3o7
Discord : https://discord.gg/KGvFa2FHrZ
All the other information will be added to this IC later on.
Can't wait to hear your guys opinion on this design :)
Credits :
Keycaps
GMK LASER R2 https://www.reddit.com/r/mechmarket/comments/hnq8xc/gb_gmk_laser_round_2_99_and_110_kits_til_july/
GMK DUALSHOT R2  https://omnitype.com/products/gmk-dualshot-2-keycap-set
GMK ARABIAN SEA https://geekhack.org/index.php?topic=112907.0
3D Objects
"Headset" (https://skfb.ly/LHUA) by rasolrpd is licensed under Creative Commons Attribution (http://creativecommons.org/licenses/by/4.0/).
"Cassette tape (Fita cassete)" (https://skfb.ly/6SSTp) by Anderson Ferreira is licensed under Creative Commons Attribution (http://creativecommons.org/licenses/by/4.0/).
"Sony TC-D5 Recorder" (https://skfb.ly/6XDBW) by Artem P is licensed under Creative Commons Attribution (http://creativecommons.org/licenses/by/4.0/).
« Last Edit: Wed, 21 July 2021, 03:00:48 by i_Do7 »
Offline Alejo1707
  • Gimme some more caps!
Re: [IC] MIXTAPE V.1 65%
« Reply #1 on: Tue, 22 June 2021, 21:53:07 »
Reserved
Also...goddamn, that's a sexy looking board
Offline lecorsair
« Reply #2 on: Tue, 22 June 2021, 22:43:17 »
Very cool concept! Maybe outside of the realm of practicality but would be awesome to have an oled/led matrix that can scroll across where the tape would be.
Offline doggo1dance
« Reply #3 on: Tue, 22 June 2021, 23:09:04 »
looks really interesting! glwic!
Offline Baka Bot
« Reply #4 on: Tue, 22 June 2021, 23:18:14 »
Is this meant to be a "screw less design"?
Offline nevin
« Reply #5 on: Wed, 23 June 2021, 01:23:03 »
love the concept, very original.
you're probably going high end aluminum custom, but i'd love to see maybe a black or smoke grey polycarb insert to represent the tape. would help show off the cutouts of the front of the case as well on the lighter colors.
like this...
271133-0
... and a TDK keycap set to go with it.
Offline g_hack_it
« Reply #6 on: Wed, 23 June 2021, 06:16:30 »
This bad boy is way too unique to ignore, great job! Please don't make me sell the other kidney for it.
Sent from my LM-V600 using Tapatalk
Offline i_Do7
« Reply #7 on: Wed, 23 June 2021, 06:24:17 »
Reserved
Thank you so much  ;D
Offline i_Do7
« Reply #8 on: Wed, 23 June 2021, 06:25:32 »
That actually will be a great idea!
Thank you so much for the feedback <3
Offline i_Do7
« Reply #9 on: Wed, 23 June 2021, 06:32:26 »
There is 4 screws for the Top and the bottom case, and 6 for the plate
and might add some extra for the case, depends on the prototype
LOL, you already sold the other one! ^-^
Thank you Thank you <3
Offline RoyalOak88
« Reply #10 on: Wed, 23 June 2021, 06:33:25 »
Really nice concept! Does ISO make part of the plans?
Offline i_Do7
« Reply #11 on: Wed, 23 June 2021, 06:38:46 »
like this...
Thank you for your feedback, as for the tape i thought about using frosted PC with an LED strip n the back
but i don't want it to scream RGB
will try to do a PC tape and see how it will goes   :thumb:
Offline paulgali
    • SKME
« Reply #12 on: Wed, 23 June 2021, 08:31:21 »
How is this supposed to mount? You have plate screws AND resting points for poron (or another material), I'm a little confused  ;)
Offline paulgali
    • SKME
« Reply #13 on: Wed, 23 June 2021, 08:35:15 »
Reserved
Mate why you reserve someone elses IC when its clearly not a sh*tpost  :))
Offline mr_foggy
  • neue = nope
« Reply #14 on: Wed, 23 June 2021, 08:48:39 »
I just LOVE the inspiration and the looks. I want one so bad.
Please consider clear and/or smokey polycarbonate cases, most cassettes I own are see through plastic.
Offline i_Do7
« Reply #15 on: Wed, 23 June 2021, 10:13:44 »
it is a top mount with gaskets, that was the best choice i found for the vibration
but i guess im going to change it to top mount
Offline i_Do7
« Reply #16 on: Wed, 23 June 2021, 10:16:14 »
Thank you so much
will see about the translucent cases  ;)
Offline Alejo1707
« Reply #17 on: Wed, 23 June 2021, 19:36:03 »
Reserved
I was first to this awesome project, I have my right!
To be honest, because I do want to provide further feedback and help OP if possible, nothing else.
Sent from my GM1917 using Tapatalk
Offline Extra Fox
  • quis qui sais
« Reply #18 on: Wed, 23 June 2021, 20:34:34 »
This is a genuinely cool design, it's got some good nostalgia feels too.
My two suggestions,
  • Seconding @lecorsair, I think it would look fantastic to represent the magnetic ribbon. My personal thought was to use smoked polycarbonate, backlit by RGB LEDs in a chasing pattern.
  • Color wise, I think it would be great to see a medium/dark, non-metallic gray akin to some of the high end Maxell and TDK cassettes that were available.
A-a-ron
Offline Keeblet_257
« Reply #19 on: Thu, 24 June 2021, 05:50:41 »
interesting design I hope the community would agree on the fact tht we really want some typing test as well as some build steams GLWIC
Offline ReverbSlush
  • 16/52 RNG score
« Reply #20 on: Thu, 24 June 2021, 06:27:23 »
I've legit bought so many cassette tapes in the last 5 years that I *absolutely* need (would like) this.
Offline Neely_12
« Reply #21 on: Thu, 24 June 2021, 07:01:59 »
That side profile is super nice. Little confused about the mounting, but I’m sure whenever you get a proto
 It will be easier to explain. Speaking of proto, any plans for ordering one?
Offline i_Do7
« Reply #22 on: Thu, 24 June 2021, 09:19:16 »
My two suggestions,
thank you so much
im working on the materials and as i will try to see how it goes with the RGB :thumb:
Offline Alejo1707
« Reply #23 on: Thu, 24 June 2021, 09:22:15 »
Mate a quick suggestion. I think it would look nicer to have 2 pieces of brass weight instead of a single one with that oval in the middle, it will be more reminiscent of old tapes.
Also, adding other colors for the weight might improve the overall aesthetic.
Offline i_Do7
« Reply #24 on: Thu, 24 June 2021, 09:24:00 »
old is gold  :D
thank u
sure just need to fix a few stuff before ordering, will share everything here and in my Discord  :thumb:
Thank u, Of course i will provide all of that once i get the proto!  ;)
Offline Therien
« Reply #25 on: Thu, 01 July 2021, 14:28:49 »
Filled out the form  :thumb: ISO love and shipping to EU please!
Offline paperassgasket
« Reply #26 on: Thu, 01 July 2021, 15:38:17 »
I like the design and inspiration. Not a fan of 65's but GLWIC.
Offline RA Can
« Reply #27 on: Thu, 01 July 2021, 22:03:11 »
interesting. good luck with the ic  :thumb:
Offline wahfuhls
« Reply #28 on: Mon, 19 July 2021, 20:32:57 »
discord link is broken
Offline Engedi_
« Reply #29 on: Mon, 19 July 2021, 22:23:06 »
I understand the front cutouts, but it doesn't look right. Like it's not complete. May I suggest a design change?
And I think about dust collecting place
Offline noodleman
« Reply #30 on: Mon, 19 July 2021, 22:46:45 »
really cool looking design!  Have you considered flipping the design 180 it so that the tape part is on the backside?  this makes the back of the keyboard more interesting, and the front just have the little nubs on the other side of the cassette.  You could even extend the lip downwards some more to be part of the feet design.
Offline senencito1
« Reply #31 on: Tue, 20 July 2021, 04:07:48 »
I am interested. This is a fun idea.
Offline Klyback
« Reply #32 on: Mon, 02 August 2021, 23:28:01 »
GL W IC
Offline antx1701
« Reply #33 on: Tue, 03 August 2021, 16:48:53 »
Love this design. It'd be great to see an acrylic option.
Offline keywi
« Reply #34 on: Sun, 05 September 2021, 05:02:47 »
Love this idea! Gave some feedback via the IC form.
Good luck and I hope to see it reaching a GB.
Offline hottrout
  • I'd Hit Dat Key
« Reply #35 on: Sun, 05 September 2021, 06:34:05 »
Polycarbonate version in a tinted hue to suit the GMK Laser would be awesome in every way.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline g_hack_it
« Reply #36 on: Sun, 05 September 2021, 06:35:30 »
There are so many sets that would work perfectly with this board. I love the updated weight design and I really hope this thing happens.
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #37 on: Sun, 05 September 2021, 11:44:40 »
Really cool concept! GLWIC!!!
Please add ISO support :cool:
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline i_Do7
« Reply #38 on: Mon, 06 September 2021, 17:41:28 »
Thank you all for supporting <3 .. Still working on this bad boy and will update u guys soon  :thumb:
Offline i_Do7
« Reply #39 on: Mon, 06 September 2021, 17:42:32 »
 It does support ISO & ANSI now  ;)
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #40 on: Tue, 07 September 2021, 06:55:55 »
"The Tape is strong with this one".
(cit. Darth Taper)
