Author Topic: [IC] GMK Nimbus ☁️  (Read 113654 times)
Offline scottdesigns
Re: [IC] GMK Nimbus ☁️ | GB Date Announced!
« Reply #100 on: Sat, 08 January 2022, 11:30:53 »
will there be plans to add a nordeuk kit because otherwise there is nothing wrong with these keycaps
We had plans for it, but decided to take it out as the kit would be too difficult in reaching MOQ.
Offline Starston3
Re: [IC] GMK Nimbus ☁️ | GB on 2/22/22
« Reply #101 on: Sat, 08 January 2022, 11:35:49 »
Your icon kit is missing 2 R4 1.5u GUI keys for Mac and *nix users that use tsangan
« Reply #102 on: Sat, 08 January 2022, 17:42:59 »
Thanks for mentioning this! To answer this, all kits have been finalized with GMK. They are basic icons so all users could still use them with their OS. And far too little people use it to add it to the kit and greatly increase the kit price. Apologies if this is an inconvenience for you.
Offline Starston3
« Reply #103 on: Sun, 09 January 2022, 13:10:51 »
Oh… yeah… that’s just bad kitting on your part then…
glwgb
Offline konstantin
  • Formerly constexpr
« Reply #104 on: Mon, 10 January 2022, 11:37:27 »
glwgb
While 1.5u Mac/Tsangan keys in the icon kit definitely would have been nice to have (something I suggested way back in August), I think the overall kitting actually looks pretty great. Looking forward to the GB :thumb:
P.S. You can use the R4 1.5u cloud novelties if you really need to.
Offline Starston3
« Reply #105 on: Mon, 10 January 2022, 19:14:35 »
glwgb
That would require to buy 3 kits instead of just 2 though.
There have been other Icon kits on other sets that included the keys missing. I was pointing it out.
The designer is more than in their right to choose which keys to include, but at some point there needs to be a some sort of “best practice.” Prior Icon kits seem to fit the bill.
Offline Plurrkeebs
Re: [IC] GMK Nimbus ☁️ | Monokei Collab Revealed!
« Reply #106 on: Tue, 18 January 2022, 19:37:19 »
This looks awesome.
Offline whee74
« Reply #107 on: Fri, 21 January 2022, 14:25:25 »
Really love that light blue color. Definitely gives a feeling of floating high in the sky. GLWIC
« Reply #108 on: Sun, 23 January 2022, 17:51:22 »
Re: [IC] GMK Nimbus ☁️ | Harbour65 Collab Reveal
« Reply #109 on: Tue, 25 January 2022, 00:40:19 »
Collab with Harbour revealed!
Re: [IC] GMK Nimbus ☁️ | GB 2/22/22
« Reply #110 on: Thu, 03 February 2022, 01:58:15 »
Collab with Clackeys revealed!
« Reply #111 on: Tue, 15 February 2022, 17:16:59 »
Group buy in exactly one week!
Re: [IC] GMK Nimbus ☁️ | GB LIVE
« Reply #112 on: Tue, 22 February 2022, 19:29:56 »
GB is now live on all regions!
GLOBAL/ASIA: KBDfans
CA: AlphaKeys
EU: MykeyboardEU
UK: Prototypist
OCE: Daily Clack
SA: Fancy Customs
SEA: Kibou
ME: StacksKB
KR: Swagkeys
Offline dokternik
« Reply #113 on: Thu, 24 February 2022, 16:49:58 »
Heck yes. I love this set.
« Reply #114 on: Sun, 06 March 2022, 21:32:26 »
New renders (finally one without the accents, your welcome Alexotos)
Offline 111239e7
  • hi
« Reply #115 on: Sat, 12 March 2022, 18:51:13 »
hi
Re: [IC] GMK Nimbus ☁️ | 1 WEEK LEFT FOR GB
« Reply #116 on: Fri, 18 March 2022, 00:12:29 »
One week of GB left :)
Re: [IC] GMK Nimbus ☁️ | GB ENDS IN 1 WEEK
« Reply #117 on: Sat, 26 March 2022, 01:43:40 »
The GB is over! Final sales numbers and further information will be updated on the GB Thread. Thank you everyone for your support.
Re: [IC] GMK Nimbus ☁️ FINAL NUMBERS!
« Reply #118 on: Fri, 08 April 2022, 22:25:16 »
Final numbers are out! Thank you everyone again.
Offline Fraaaan
« Reply #119 on: Sat, 09 April 2022, 05:04:25 »
This is not in IC phase anymore. Stop bumping your IC thread with GB updates when you have an active GB thread.
