Author Topic: PC Cases: fractal design meshify 2 compact vs be quiet 500dx  (Read 7264 times)
Offline Public Nuisance
  • I do my own stunts.
    • Follow me on Twitch!
« on: Mon, 12 July 2021, 14:02:50 »
Hello!
for my next build i am stuck between these two cases. i watched the gamersNexus reviews on both.  Both allow a 240 rad up top.
the gpu i will be using is a msi 3080 trio.
does anyone have personal experience with ether or both of these?
Offline Leslieann
Re: PC Cases: fractal design meshify 2 compact vs be quiet 500dx
« Reply #1 on: Mon, 12 July 2021, 21:51:09 »
Buy whichever you prefer, we can't tell you anything more than Gamers Nexus can other than personal opinions as few have probably worked with both.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline geauxflying
« Reply #2 on: Wed, 04 August 2021, 20:29:03 »
F a 240 rad. It won’t cool nearly as well as a (cheaper) Noctua D15 or Dark Rock Pro 4, and it’ll be louder too. Either of those air coolers will fit in your case.
I actually just returned a BeQuiet 500dx case for a manufacturing defect, and opted to replace it with a Phanteks P500A, which is VERY nice but not as small. I have no cooling problems. I definitely don’t need to worry about if it can fit a 240mm radiator.
