Author Topic: Dimensions of placement and size of stabilizer holes  (Read 18207 times)
Offline blondie
« on: Mon, 12 July 2021, 14:12:40 »
Does anyone know where the stabilizer holes are placed relative to the center of the key switch? Also, what is their size? I understand there are two main types of stabilizers, but I can't find any documentation on any of their placement or size.
There is no greater knowledge than the knowledge of one's self. There is no greater truth than the truth of moral conviction. And there is no greater keyboard than the one beneath my fingertips.
Re: Dimensions of placement and size of stabilizer holes
« Reply #1 on: Mon, 12 July 2021, 14:39:54 »
Most new DIY keyboard kits these days use PCB-mounted stabilisers, following Cherry's patterns.
Some are mounted to the PCB with screws, others just with clips.
The downside is that if you have a plate, the holes around the stabilisers need to be quite large.
Then there are stabilisers that mount to the plate instead: Cherry-style and Costar-style.
With Cherry's stabilisers (PCB or plate-mount) each stabiliser stem has a Cherry MX stem that is captive to the stabilisers, so you can pull and seat keycaps on them just like on switches.
With the Costar-style, you have to fiddle with the stabiliser wire each time you pull or seat a keycap.
You can see all types (and more) here: https://deskthority.net/wiki/Stabiliser under Cherry MX and Costar.
Cherry's older datasheets used to include hole patterns for stabilisers, both for PCB and plates.
A search for "keymodule MX" gave this: https://docs.rs-online.com/19cd/0900766b813d1126.pdf
The patterns are on page 2.
« Last Edit: Mon, 12 July 2021, 14:43:17 by Findecanor »
Offline MIGHTY CHICKEN
« Reply #2 on: Mon, 12 July 2021, 15:28:54 »
You can make a KLE using keyboard layouteditor than input into Ai03's plate generator to create an accurate plate with accurate holes
Offline blondie
« Reply #3 on: Mon, 12 July 2021, 19:25:00 »
I figured someone would suggest KLE. I don't like it for a couple of reasons. First, no matter what I tried, I can't log into GitHub and have KLE recognize it so that I can save anything that I create there. It just hangs at "Signing in..." I've tried different web browsers to no avail.
Secondly, I see that it is completely unmaintained. There are some passionate developers who would love to continue this project, but the original author has kept the license proprietary and has basically left the scene.
So what I'm doing instead is modelling my keyboard in FreeCAD. It works well. If I get really ambitious (don't hold your breath), I might even try to make a workbench.
The PDF from Findecanor's second link seems to have the proper dimensions that I need, thanks. I'm not certain about the spacing for a 6.25u spacebar, but I guess I can figure it out based on one that I have.
Offline Leslieann
« Reply #4 on: Mon, 12 July 2021, 20:42:27 »
On the KLE use the permalink button, then save the link.
If you're using freecad, check Thingiverse or grabcad and import someone else's files, just beware not all cad files are created equal, or working, or even valid, but comparing a few that are known to at least work should get you there. If you don't trust this, why trust a random person on a chat board as well, get a digital caliper and start measuring, harsh, but that's how it goes with free information.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #5 on: Tue, 13 July 2021, 04:09:11 »
Standard space bars have each stabiliser stem's middle 1/2 unit from the end.  This rule applies to 6u, 6.25u, 7u and 8u.
So, for a standard 6.25u space bar, the distance between the middle points of the stabiliser stems is 6.25 - 2*½ = 5.25u, or 100.0 mm.
Offline blondie
« Reply #6 on: Tue, 13 July 2021, 06:28:53 »
Thanks a lot, this is exactly what I needed.
