Author Topic: Scuffed and old IC  (Read 6803 times)
Offline xcaruso
Scuffed and old IC
« on: Mon, 12 July 2021, 17:07:27 »
 Hey there, (Told you its scuffed ima redo it)
Warning I am in the process of making a new post so I wouldn't want to waste your time making you read this bad post. You can wait for a decent post in 1-2 days after I make renders and fix up a lot of things and talk more with the manu.
This is an ic for a switch I (XM Customs or you may know me as xcaruso from discord) have been working on with Durock which is Not A Durock/JWK Recolor*.
This is the first switch I have made with a company which is why it is called XM1. The reason it has ST is that Durock is known for its super smooth stock switches. The t is for “thock” as the polyamide mix and long stem pole should create a nice “thocky” sound that will either be similar to h1 or deeper! You may be wondering why I went for Durock instead of gateron for a deep-sounding switch and the reason is an “ST” switch which means super smooth and as you know Durock is normally smoother than gateron stock. If I release the XM2T it will be probably not as smooth but deeper and with gateron.
Specifications
linear switch
5-pin
Manufactured By Durock
Housing: PC Top Housing, Polyamide mix bottom housing (The same one as H1)
POM Stem
67g spring and possibly a 62g option
Intrest Check links
Link to the IC Form https://forms.gle/uKUxZaTTnfqtdXtV6
*Please note these are not a JWK recolor but a custom switch with custom materials resulting in an extremely high MOQ making this a GB
« Last Edit: Tue, 13 July 2021, 17:50:15 by xcaruso »
Offline Baka Bot
Re: [IC] XM1ST Switch
« Reply #1 on: Mon, 12 July 2021, 17:29:21 »
Correct me if im wrong but isnt polyamide just nylon?
Offline lukelex
« Reply #2 on: Mon, 12 July 2021, 17:31:39 »
My good sir, you are drunk.
This entire IC makes no sense. You keep saying “you might be wondering” but in order to wonder about something there needs to be SOMETHING. You have only words and no product, sample or even a render.
Please come back when you’re sober.
« Last Edit: Mon, 12 July 2021, 17:33:36 by lukelex »
Offline homerowco
    • Homerow.Co
« Reply #3 on: Mon, 12 July 2021, 17:32:20 »
going to tag this to follow it - this is going to be good entertaining.
« Last Edit: Mon, 12 July 2021, 18:17:02 by homerowco »
Offline xcaruso
« Reply #4 on: Mon, 12 July 2021, 17:37:51 »
i said you might be wondering once for gateron vs durock?
Offline Pontus
« Reply #5 on: Mon, 12 July 2021, 17:48:00 »
Uh interesting?
Offline lukelex
[IC] XM1ST Switch
« Reply #6 on: Mon, 12 July 2021, 17:51:08 »
And yet you fail to provide any concrete information to the question you propose.
Apparently I might be wondering about your choice of Durock over Gateron. But the only information you provide is “one is smoother than the other but next time I’ll be using the other”. This in itself is so nonsensical that you might as well say that it’s because you always carry a towel with you.
Offline xcaruso
« Reply #7 on: Mon, 12 July 2021, 18:15:41 »
i said that because I said if I do a deeper switch with compromising some of the smoothness and if you read it in detail you notice they are different types of switches.
Offline xcaruso
« Reply #8 on: Mon, 12 July 2021, 18:25:04 »
Well I hope it will be good! Any concerns you may have?
Offline xcaruso
« Reply #9 on: Mon, 12 July 2021, 19:06:39 »
they are different in the way pure polyamide is much stronger and nylon is made up of polyamide but in a way, the properties are changed because of how it's linked together. So yes it's different in matter of strength.
Offline yicaoyimu
« Reply #10 on: Mon, 12 July 2021, 19:08:41 »
So this is not JWK / Durock recolor but H1 recolor?
Better yet, the color isn't even finalized.
Offline xcaruso
« Reply #11 on: Mon, 12 July 2021, 19:10:26 »
i have simplified it to I choose durock because they are smoother for a smooth thock switch
Offline Baka Bot
« Reply #12 on: Mon, 12 July 2021, 19:46:02 »
WE DO A LITTLE TROLLING
Offline xcaruso
« Reply #13 on: Mon, 12 July 2021, 20:35:17 »
no it is not. the stem is different entirely the same as a different spring. IF this was a jwk recolor it wouldn't have a moq of 100k.
Offline xcaruso
« Reply #14 on: Mon, 12 July 2021, 20:36:01 »
Offline justinm
« Reply #15 on: Mon, 12 July 2021, 20:57:08 »
so will these switches have custom molds then..?
Offline xcaruso
« Reply #16 on: Mon, 12 July 2021, 21:03:11 »
Same housing mold as H1 but the stem has a different one.
Offline see
« Reply #17 on: Mon, 12 July 2021, 22:29:14 »
I believe pa66 nylon (the one used for most switches) is a polyamide. But not all polyamides are nylon - in fact PA66 is just branded as nylon-66 (PA stands for polyamide)
Offline treeleaf64
    • treeleaf64
Re: Messy and old post making a new one dont view
« Reply #18 on: Tue, 13 July 2021, 09:34:18 »
How old are you my dear
Everyone must pay the cat tax
Offline aleeex
« Reply #19 on: Tue, 13 July 2021, 13:34:18 »
Yeah screw the “preview” button Amiright?
Offline Neely_12
« Reply #20 on: Tue, 13 July 2021, 13:39:21 »
Will we see any renders of the switch or any evidence that this could actually happen?
Offline xcaruso
« Reply #21 on: Tue, 13 July 2021, 14:28:32 »
Yep that's why I'm scarping the post. Forgot to include a bunch of stuff and was just posting the ic before I had to go. Its my bad
Offline xcaruso
« Reply #22 on: Tue, 13 July 2021, 14:30:10 »
Completely forgot about renders and realized how bad this post was. Never used geekhack before so it looked really bad and wanted to scrap this post and actually spend time making a good one.
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
Re: Scuffed and old IC
« Reply #23 on: Tue, 13 July 2021, 17:20:29 »
do you see the button that says lock topic
Offline stomaha
« Reply #24 on: Tue, 13 July 2021, 17:47:28 »
Reserved.
Offline xcaruso
« Reply #25 on: Tue, 13 July 2021, 17:51:17 »
I must be blind or smthn cause I have been looking for a while and I don't
