Author Topic: [IC] o60-1 | 3d printed 60% keyboard (PRICE UPDATED)  (Read 11566 times)
Offline Ja3_420
« on: Sat, 17 July 2021, 16:02:47 »
o60-1
An affordable 3d printed 60% keyboard
Prototype Pictures
Assembly and Typing Test
Specs
3d printed top, middle and bottom
PLA material
peen mount
POM plate
support for a universal 60% (poker) pcb
7° typing angle
20.16mm front height
~50 units (TBD)
Price
€60.00 + shipping
shipping :
NL - €7
EU - €13
OUTSIDE EU - €30
Options
Case colors are going to be chosen based on demand. If you have a preference, please fill out the IC form
HHKB, WKL and WK tops will be available
ANSI 7u and ISO 7u plates will be available
An optional SAM60 pcb will be available for €25
the board will come with black solder mask instead of green
VIA and QMK configurable (preconfigured with VIA), USB C
Plate Compatibility
ANSI
ISO
Peen Mount
Peen mount is a modified top mount with spacers in place of screws
In order to add durable threads into a 3d print, brass inserts need to be added into the case. While these are great in function, they can be quite difficult to install (an incorrect installation of just one insert requires the whole part to be reprinted). Using spacers in place of screws cuts the number of inserts used in one case from 14 to 6.
From my testing, I have found that peen mount feels and sounds exactly the same as top mount. While top mount is still a great mounting style, please do not purchase this keyboard expecting something different.
Designed for 3d Printing
The o60-1 was designed specifically for 3d printing.
In order to reduce the total time taken (and cost) to produce each unit, the boards are printed at a 0.32mm layer height. Everything along the Z axis is a multiple of 0.32 to ensure all parts are dimensionally accurate.
All visible or mating surfaces are parallel to the print bed to avoid stair stepping and uneven seams.
:thumb:
« Last Edit: Tue, 03 August 2021, 07:38:19 by Ja3_420 »
Offline Ja3_420
Re: o60-1 | 3d printed 60% keyboard
« Reply #1 on: Sat, 17 July 2021, 16:05:54 »
The GB is delayed for early 2022.
« Last Edit: Sun, 05 September 2021, 11:57:04 by Ja3_420 »
Offline Fraaaan
« Reply #2 on: Sat, 17 July 2021, 16:49:56 »
Pretty disappointing to see a board from Europe that doesn't have ISO support.
Offline TurtleGuy
« Reply #3 on: Sat, 17 July 2021, 16:53:05 »
gib iso
Offline Neely_12
« Reply #4 on: Sat, 17 July 2021, 16:58:22 »
I have a few questions. What does the “kit” come with. Screws, hardware etc. Does the board come with a pcb? How much does the proto weigh, and finally how many units are planned to be avail?
Offline Ja3_420
« Reply #5 on: Sat, 17 July 2021, 17:08:10 »
The kit comes with the board, a plate, screws, and bumpons. An optional pcb is available. I'm planning on making around 20 units but that hasn't been decided.
« Last Edit: Sun, 18 July 2021, 06:35:19 by Ja3_420 »
Offline SketchLol
« Reply #6 on: Sat, 17 July 2021, 17:18:53 »
Loving the influx of 3dp keyboards nowadays. GLWIC!
Btw, are you planning on releasing files in the future?
Offline TomatoMan
« Reply #7 on: Sat, 17 July 2021, 17:43:21 »
love this, it sounds amazing!! Why only 20 pieces?  :'(
Offline Ja3_420
« Reply #8 on: Sat, 17 July 2021, 17:43:55 »
Ty! The plate files are going to be available once the GB starts and I'm planning on releasing the files for the entire board after the GB is over
Offline keybo_hobo
Re: [IC] o60-1 | 3d printed 60% keyboard
« Reply #9 on: Sun, 18 July 2021, 03:01:40 »
Halfplate option\add-on please=)
Offline ShiroMoria
« Reply #10 on: Sun, 18 July 2021, 08:15:43 »
It's quite cool, i thought i wouldn't like the surface of the material, but the texture doesn't look that bad tbh. The sound is great as well. I know it's really early to ask, but have you already planned on doing any other layouts in the future?
Offline Ja3_420
« Reply #11 on: Sun, 18 July 2021, 11:31:25 »
I'm planning on doing a tkl next but it probably will be another design
Offline Neely_12
Re: [IC] o60-1 | 3d printed 60% keyboard (PRICE UPDATED)
« Reply #12 on: Sun, 18 July 2021, 11:47:23 »
I like the updated price, but it’s still hard to swallow as someone outside EU, especially since it’s a 3D printed board. Not to take away from the design, because it looks and sounds pretty good, but just comparing other boards in the price range it’s hard competition.
Offline Fraaaan
« Reply #13 on: Sun, 18 July 2021, 16:07:51 »
Really glad to use ISO support, more units and lower price. Hearing that you'll be open sourcing the board after GB is also really cool. Great work!
Offline seh0nk
    • tech advantage blog
« Reply #14 on: Mon, 19 July 2021, 02:04:42 »
Promising  :thumb:
Offline Ja3_420
« Reply #15 on: Mon, 19 July 2021, 16:26:06 »
A major factor in the o60-1's price was the POM plate. While POM is my favorite material, it is quite difficult and inconsistent to laser cut.
In order to reach a more competitive price, an FR4 plate will be offered instead.
The kit will now cost €60.
A prototype plate has been ordered
« Last Edit: Mon, 19 July 2021, 17:34:45 by Ja3_420 »
Offline SDKCAMPING
« Reply #16 on: Mon, 19 July 2021, 17:51:33 »
this looks awesome, I will definitely try for one.
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline rhyy
« Reply #17 on: Thu, 22 July 2021, 02:18:28 »
looks and sounds great and it's cheap, I'll probably try for one
Offline Automata-killa
« Reply #18 on: Tue, 27 July 2021, 13:27:36 »
Would be down for one or two units in wkl, how do I keep myself updated when and if the sale goes live?
Offline AstralYT
« Reply #19 on: Tue, 27 July 2021, 15:18:44 »
Consider offering the extra tops as add-ons, one could swap wkl and hhkb maybe do some colour combos too.
Sent from my GM1917 using Tapatalk
Offline Ja3_420
« Reply #20 on: Wed, 28 July 2021, 06:31:01 »
The fr4 plates should be arriving tomorrow and (hopefully) the final prototype is being printed right now. If everything goes well, the GB will start around mid august.
Definately will be offering extra tops
Offline Ja3_420
« Reply #21 on: Tue, 03 August 2021, 07:36:29 »
The plates have arrived but after shipping and tax, the price isn't much less than a pom plate and the quality isn't great.
The board will go back to including a pom plate however, after talking to my local laser cutting supplier, I have gotten the price down and the kit will still cost €60.
Production units will use m3 screws instead of the m2 screws used in the prototypes.
Offline Pyroo
« Reply #22 on: Tue, 24 August 2021, 18:03:28 »
Very nice board, will probably pick one up when it goes in gb  :thumb:
Bunny enthusiast
Offline Neely_12
« Reply #23 on: Tue, 24 August 2021, 19:58:34 »
Is there any chance the shipping to the US will be under that 30 euro price? Also, how much does the board weigh?
Offline Ja3_420
« Reply #24 on: Thu, 26 August 2021, 20:40:44 »
The board unbuilt weighs around 500g.
I'm not sure if I can get shipping prices lower for the US, not for now at least.
Offline Ja3_420
« Reply #25 on: Sun, 05 September 2021, 12:02:58 »
The design has been finalized but the GB will be delayed for early 2022.
The printer that was going to be used for production (heavily modified raptor 2+) is too unreliable and will be replaced with another printer (vcore 3).
I'd rather do things properly than run the GB prematurely.
