Advanced search
it's a keyboard thing
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Have you read the
geekhack TOS
lately?
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Marketplace
Great Finds
(Moderator:
Signature
What did I just buy? (Cherry G80-8113LUVEU-2)
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: What did I just buy? (Cherry G80-8113LUVEU-2) (Read 5691 times)
MissileMike
Thread Starter
on:
Fri, 27 August 2010, 22:26:52 »
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=390228430958
I am hoping these are clears or browns.
Logged
BS:
5 Space Savers || 9 42H || 10 1391401 or similar || 1x 1390131 || AT&T 305b || Dell Model M
Cherry:
Leopold FC200RC/AB || 3 Ducky 1087 || PLU ML87 || Cherry G80-8113LUVEU-2 browns
Alps:
Filco Zero Tenkeyless (fukka) || ABS M1 || 3x Dell AT101w || Ancer KF-191 || 6 Vivanco Compact
Misc:
NMB RT6855T+ || NMB RT101 Space Invader || Dell Quietkey || Ge Fanuc Industrial Metal
ironman31
Reply #1 on:
Fri, 27 August 2010, 23:44:01 »
I actually just asked the seller to post a pic, but I guess I'll find out what it looks like when you receive it, lol. And I'm not sure what switches it has, but I don't think they are browns.
Logged
Keyboards:
IBM Model M Space Saving Keyboard (Used), HHKB Pro 2 (White, Lettered), Realforce 87U all-45g in White, Filco Majestouch 2 TKL with Cherry MX Browns,
Model F PC/AT
Noppoo Choc Mini (MX Browns)
, Model F XT,
IBM Model M 1397735 (bought NIB)
(2) Siig Minitouch (GHSS) one with XM, one with complicated ALPs (modded)
,2 Dell AT101W, Cherry G80-11900HRMUS (modded with MX browns)
Pointing Devices:
MissileMike
Thread Starter
Reply #2 on:
Sat, 28 August 2010, 07:19:59 »
My money is on clears- just hope it's not black. But for 23$ shipped, it was worth it to find out.
Logged
BS:
Cherry:
Alps:
Misc:
Findecanor
Reply #3 on:
Sat, 28 August 2010, 09:48:43 »
I wouldn't worry. I am sure that it is a LUVEUly keyboard, either way.
Logged
EverythingIBM
Reply #4 on:
Sat, 28 August 2010, 14:55:11 »
That's a true thing to be said, don't worry, just be thankful. It will be good either way.
Logged
MissileMike
Thread Starter
Reply #5 on:
Thu, 02 September 2010, 11:01:30 »
The good news:
it has brown switches (but the space bar is a grey switch)
it appears to be new as advertised
The bad news:
when I plug it in, it seems like the space bar is stuck on. I can press backspace and the repeated spaces stop, but press another key and they start back up again. Is that a driver issue by any chance?
Here are the pics:
Logged
BS:
Cherry:
Alps:
Misc:
didjamatic
Reply #6 on:
Thu, 02 September 2010, 11:57:29 »
Pop the space bar carefully and see if the switch is stuck or if something is in it. It could also be something touching contacts behind the PCB. Like a piece of foil wrapper.
Logged
MissileMike
Thread Starter
Reply #7 on:
Thu, 02 September 2010, 11:59:15 »
Definitely not a mechanical issue. It goes up and down just fine.... Urgh I bet I am going to have to take this thing apart.
Logged
BS:
Cherry:
Alps:
Misc:
didjamatic
Reply #8 on:
Thu, 02 September 2010, 12:04:02 »
Just because it goes up and down doesn't mean it's just fine.
You might have something in the switch that is making contact, or something on the PCB. it's probably an easy fix and disassembling that board is a piece of cake, it might not even require tools on that case.
Logged
MissileMike
Thread Starter
Reply #9 on:
Thu, 02 September 2010, 12:15:34 »
Okay, I checked aquakeytest, and the results are interesting.
Resting, it registers as ON.
If i push down space a little bit, it registers as OFF.
If I push it down beyond the tactile point, it registers as ON.
Logged
BS:
Cherry:
Alps:
Misc:
MissileMike
Thread Starter
Reply #10 on:
Thu, 02 September 2010, 12:19:22 »
Is there any way to tell? The switch itself is grey.
Logged
BS:
Cherry:
Alps:
Misc:
MissileMike
Thread Starter
Reply #11 on:
Thu, 02 September 2010, 12:23:41 »
That assumption is correct...
Logged
BS:
Cherry:
Alps:
Misc:
MissileMike
Thread Starter
Reply #12 on:
Thu, 02 September 2010, 12:27:11 »
Here it is:
Thanks for the help!
Logged
BS:
Cherry:
Alps:
Misc:
MissileMike
Thread Starter
Reply #13 on:
Thu, 02 September 2010, 13:04:04 »
It's the switch that's bad. Rocking it side to side even a tiny bit causes the state to toggle.
Logged
BS:
Cherry:
Alps:
Misc:
ricercar
Elevated Elder
mostly abides
Reply #14 on:
Thu, 02 September 2010, 18:37:52 »
if you need a replacement MX brown, PM ripster.
or me.
Logged
MissileMike
Thread Starter
Reply #15 on:
Fri, 03 September 2010, 07:56:01 »
I took the switch apart and ruined it
So now, it looks like I am going to have to desolder.
Subjectively, this keyboard doesn't feel nearly as nice to type on as the Filco with the same switches, and it's certainly cheaper in terms of construction.
Logged
BS:
Cherry:
Alps:
Misc:
MissileMike
Thread Starter
Reply #16 on:
Fri, 03 September 2010, 08:03:13 »
Hey, is there any way to remove the metal leaf from a switch w/o desoldering the switch from the board? I have an entire top row of keys on this thing I could use to swap.
Logged
BS:
Cherry:
Alps:
Misc:
MissileMike
Thread Starter
Reply #17 on:
Fri, 03 September 2010, 20:27:52 »
I am happy to report that I desoldered a switch from the useless top row and swapped it with the space bar switch and it was pretty simple to do. I am typing on the board now. I wanted a brown in the space bar anyway
The quality difference between this and my filco is absolutely huge, though, and this one will go back in the box and serve as a backup/collector item only.
Thanks guys for the help!
Logged
BS:
Cherry:
Alps:
Misc:
Infinite north
Reply #18 on:
Fri, 03 September 2010, 21:21:55 »
Keep the grey stem, that is a clear stem in a different color. it's a good reminder in case you want one down the line, the only difference is the spring. I personally like the cherry build quality myself. I am guessing that you like the plate mounted switches more than pcb mounted.
Logged
MissileMike
Thread Starter
Reply #19 on:
Fri, 03 September 2010, 22:51:51 »
Exactly. The plate mounting feels a lot more solid to me. Don't get me wrong, it's still better than most keyboards out there by a mile.
I also didn't know that grey stem was a clear- definitely takes more force.
Logged
BS:
Cherry:
Alps:
Misc:
Infinite north
Reply #20 on:
Fri, 03 September 2010, 23:44:37 »
The tactile bump is the same, not the force. cherry spacebar switches are always heavier.
Logged
Print
Pages: [
1
Go Up
« previous
next »
geekhack
Great Finds
(Moderator:
Signature
