Author Topic: Screws under Feet  (Read 5119 times)
Offline 10centNickle
Screws under Feet
« on: Fri, 30 July 2021, 14:48:34 »
What is your opinion on keyboard screws under feet?
Re: Screws under Feet
« Reply #1 on: Fri, 30 July 2021, 16:13:14 »
On vintage keyboards that have them, the adhesive will not always stick when you put the feet back.
It's better when you don't have to remove the feet at all.
The worst are the ones that have screw only under some feet, which fool you into either/or both of:
- thinking that you have removed all screws, when there are some left hidden under feet
- unnecessarily removing feet that don't have screws under them
« Last Edit: Fri, 30 July 2021, 16:18:20 by Findecanor »
Offline _rubik
« Reply #2 on: Wed, 11 August 2021, 23:01:54 »
I'm generally not a fan.
I probably open up each board ~2 or 3 times a year. Some adhesive rubber feet are harder to find (or proprietary) or the adhesive is just plain bad. Having to constantly replace feet or stock up is a pain.
Offline MIGHTY CHICKEN
« Reply #3 on: Wed, 11 August 2021, 23:02:22 »
Hard to open board
Offline Leslieann
« Reply #4 on: Wed, 11 August 2021, 23:09:15 »
While it can be for cosmetics, it's often used as a way for companies to make a warranty void sticker without labeling it as such.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline treeleaf64
    • treeleaf64
« Reply #5 on: Fri, 13 August 2021, 12:17:25 »
Pressure fitted feet + screws  is the best because you do not see the screw holes and still maintain functionality.
Everyone must pay the cat tax
Offline Nuclear Nachos
  • Anima and Animus
« Reply #6 on: Fri, 13 August 2021, 13:18:16 »
geon has a cool system for screws under feet on his frog tkl that works really nice
Offline jcoffin1981
« Reply #7 on: Sat, 14 August 2021, 01:53:25 »
I'm not a fan of this system. I'd rather have a hole in the bottom of the board, or a sticker.
Offline samsamm777
    • Superhuman Keyboards
« Reply #8 on: Sun, 15 August 2021, 05:13:42 »
Yeah not a fan. I dont really understand why designers feel compelled to do it.
