Author Topic: [IC]Besides Studio--A motor lifting keyboard  (Read 7910 times)
Offline tzoyo512
« on: Sun, 01 August 2021, 06:31:04 »
Introduction
Hey all, this is tzoyo512 from Besides Studio. After month of preparation, we would like to introduce 2 new projects to the custom keeb community. First project will be a full metal key caps set proxy by Thocc Supply (by Mr. Nobody) and second project is our height adjustable 75% metal keyboard kit named M·ONE75% (R2)
M·ONE 75% is a height adjustable full aluminum keyboard feature a standard ANSI 75% layout. The project itself began in June 2019 and completed its first limited run of 100 units in China in December 2020. We made quite a number of improvements over the first run and now it is ready for the international custom community.
DISCORD:LINK
KBDFans IC Page:LINK
Review:
Specifications:
Pricing: 299USD
Typing Angle:3°-- 7°typing angle
Front Height: Around 20mm
Colours:
            Fireland Black Metallic:Black top case/Black front Plate / Burnt Orange bottom case/ Burnt Orange plate
            Cthuhu Silver Metallic:Silver top case/ Silver front Plate / E-White bottom case/ E-White plate
            Absolute Zero Blue Metallic:Blue top case/Blue front Plate /Silver bottom case/ Silver plate
Plate:Alu5052
Case Material:Alu6063(Anodic oxidation & electrophoresis)
PCB: Hot-swap, RGB,ESD protection
Weight:770g(Weight without Switches and Keycaps)
Vendor:KBDFans
Format:
Instock 200 units follow with unlimited GB
Since it is our first keybaord project, we organised with KBDFans to release instock units at GB price
             Fireland Black Metallic:80 units
             Cthuhu Silver Metallic:60 units
             Absolute Zero Blue Metallic:60 units
Layout:
M·ONE 75% R2 features:
CNC machined outer case
Hot swap PCB with per key RGB
Magnetically attached top cover
Bottom case featuring a tempered glass panel to reveal its internal components and RGB back light diffusion
Modified bottom mount with specially formulated silicon dampening O ring to improve typing feel and sound profile
Typing angle between 3 -7 degree adjustable with 2 motors built in to the bottom chassis and control switch double as a blocker near the arrow cluster
Due to its height adjustable feature, we use our own simple driver software allow macro, key remapping and RGB controls
Included in each kit(Height adjusable motor secion will be preassembled ):
Top case, bottom case,front plate,motor cover plate,lifting button
Aluminum plate,CR foam dampener,main PCB and daughter PCBH
L shape USB-C cable
Motor,transparent tempered glass cover plate ,copper guide rail,guide rail column
PET reflective strip,magnet
User manual (include download link to driver softerware)
Renders:
Prototype:
M·ONE75% R2 Structure Guide Line:
Drive software pictures:
« Last Edit: Wed, 11 August 2021, 01:05:32 by tzoyo512 »
Offline well_cooper
  • Turn metal in to typing machine
    • Thocc Supply
Re: Besides Studio--A motor lifting keyboard
« Reply #1 on: Sun, 01 August 2021, 06:33:01 »
RESERVED its my IC now  :p
Offline FamilyJoule924
Re: [IC]Besides Studio--A motor lifting keyboard
« Reply #2 on: Sun, 01 August 2021, 10:26:00 »
can you please make a green colorway?
Offline Havattack
« Reply #3 on: Sun, 01 August 2021, 20:27:21 »
I would like it a 1000x more if you replaced those motors with some solenoids.. Neat novelty though. GLIC
Offline Jefff
    • jlabs.co
« Reply #4 on: Sun, 01 August 2021, 20:48:11 »
Very impressive feat of engineering! Personally, I don't see myself actually using this function, but it is very neat.
Offline tzoyo512
« Reply #5 on: Tue, 10 August 2021, 22:52:58 »
GB will consider the choice of color
Offline _rubik
« Reply #6 on: Tue, 10 August 2021, 22:59:38 »
This is _wild_; are we finally in the future?
Offline japancakes
« Reply #7 on: Wed, 11 August 2021, 00:26:05 »
This is the kind of design that pushes everything forward. Hell yeah.
Offline tzoyo512
« Reply #8 on: Sun, 15 August 2021, 04:46:20 »
Thanx
Offline Flippy
« Reply #9 on: Mon, 06 December 2021, 06:34:45 »
Is there a chance to still get one model?
