Author Topic: [IC] Maya TKL - Gasketed Winkeyless F12 Board  (Read 22605 times)
Offline derpturtle
« on: Mon, 02 August 2021, 02:50:03 »
Maya TKL
Ne HHKB HG inspo avail??
IC FORM!
DISCORD!
Maya is my take on the ever-popular F12 TKL layout. It features a gasket-mounted design and a cute little turtle logo above the arrow cluster.
Case
Maya comes standard in an aluminum top case, bottom case, plate, and accent piece. It also comes with 3 internal brass weights. The plate is isolated from the case using EPDM rubber grommets.
The case is angled 7 degrees and has a 21 mm front height (as measured from case bottom to case at keycap row 5). The top and bottom case have each been angled off in such a way as to give off a slightly rounded appearance, and are joined at an exaggerated seam. A unibody accent piece makes up the entire floor of the internals as well as the accented sections of the bottom of the keyboard.
Internal sound dampening has been tested, however, they will not be available during the group buy. Files for custom cutting foams or fabrics of your choosing will be available regardless.
Two colorways have been decided upon and prototyped, “FORGE” and “KANAGAWA.” If there is significant support for additional colorways, they will be considered.
Plate
As stated previously, the plate will come in aluminum by default. Half and full plates will be available. Additional plate materials, including all of the most popular alternate materials as well as some more obscure ones, are being tested at this time. FR4 has already made the cut due to its popularity and will be featured as an add-on.
Plate files will be made available soon before keyboards are shipped out to group buyers.
PCB
Maya uses a traditional F12 function row and is compatible with many popular F12 PCBs that support a daughterboard, including the Hiney H87. The bundled PCB designed by Lfgberg also supports a 10u spacebar and an ALPS EC-11 rotary encoder in the function row “ESCAPE” position for those who feel so inclined.
Note: Although the Maya PCB supports windows keys, Maya TKL itself will be Winkeyless only.
Prototypes
Here is a typing test for the second Maya TKL prototype. It’s been built with JWK Moss switches on an aluminum half plate.
Here are some pictures taken of second-round prototypes. Note that the red case may not be available during GB unless considerable demand is met.
Additional Renders and Promotional Images
Group Buy Info
Information subject to change
> The group buy is slated to begin Q4 2021 or early Q1 2022.
> Current minimum order quantity is 100 units, and a maximum of 200 units will be produced.
> The target GB retail price is $450, however this is subject to change.
> North American orders will be handled independently. If considerable demand is found outside of North America, proxies may be established.
Thanks
Huge thanks to the following people who helped make this project possible:
Lfgberg for helping out with the PCB
Eg0t1st1k4l for the renders
02 for providing all the keyboard-related resources I never thought I would need
Terio for assisting in logistics and capital
Dudeship for looking over this IC
« Last Edit: Sat, 07 August 2021, 03:48:02 by derpturtle »
Offline derpturtle
Re: Maya TKL - Gasketed Winkeyless F12 Board
« Reply #1 on: Mon, 02 August 2021, 02:52:45 »
reserved
Offline eg0t1st1k4l
« Reply #2 on: Mon, 02 August 2021, 02:53:01 »
reserved
Offline hankyul33
« Reply #3 on: Mon, 02 August 2021, 02:53:25 »
MAYA RED GUTS
Offline katteeem
« Reply #4 on: Mon, 02 August 2021, 02:54:17 »
MAYA RED GUTS
Offline stellaidoscope
    • Stellaidoscope
« Reply #5 on: Mon, 02 August 2021, 03:02:38 »
MAYA RED GUTS
Offline schwartzasher
« Reply #6 on: Mon, 02 August 2021, 03:03:32 »
AMAZING! MAYA RED GUTS!
Offline Havattack
« Reply #7 on: Mon, 02 August 2021, 03:08:47 »
^LOL! You discord people and your inside jokes.. Maybe try and make some kind of point to go along with your super cool inside joke next time, instead of just filling the thread up with useless filler, that is what discord is for.  Just a thought.
Anywho, Not bad, and GLWIC.
Why "Maya" though? I was  expecting some kind of step-pyramid style keeb.. Kind of disappoint.
Offline derpturtle
« Reply #8 on: Mon, 02 August 2021, 03:16:32 »
I can't lie, I'm pretty bad with names (both remembering and making up) and so I ended up just rng'ing a name until I hit one that doesn't belong to a person I know irl  :))
Offline msrulz4
« Reply #9 on: Mon, 02 August 2021, 04:09:28 »
what makes this different from most tkl's?
Offline MoonOperator
« Reply #10 on: Mon, 02 August 2021, 05:03:40 »
Ooh that's really interesting, are you're using those anti-vibration washers that you find in DVD players as gaskets?
Offline derpturtle
« Reply #11 on: Mon, 02 August 2021, 05:35:55 »
Thanks! The gaskets in this board are rubber grommets, which are usually used for running wiring through pannels.
Offline FamilyJoule924
Re: [IC] Maya TKL - Gasketed Winkeyless F12 Board
« Reply #12 on: Mon, 02 August 2021, 07:39:46 »
please make a green colorway dieing to match up gmk court with a keyb
any pictures of the pcb?
Offline Mecxs
« Reply #13 on: Mon, 02 August 2021, 08:48:16 »
I want this but I want it to have more turtles. Like, an unreasonable amount of turtles. On the back (obviously), the front, the sides, the bottom, the top. Turtles everywhere. There should be turtles on all the blockers and extra blockers for less frequently used keys like scroll lock, pgdn, and 'q' should be added to accommodate more turtles.
Also.
Turtles on the inside. Internal turtle engravings.
Offline Kinesiologist
« Reply #14 on: Mon, 02 August 2021, 09:17:50 »
Really appreciate the clean look.
Please consider adding a green top + bottom option with Ral 6002.
:D
Offline ai06L
  • SEE YOU, SPACE COWBOY
« Reply #15 on: Mon, 02 August 2021, 09:20:13 »
really looking forward to this, luv the little turtle as the logo
Collection: Keycult No.1, 8XV2.0 Additional Ano silver WKL, FC660C Novatouched, Polaris, 8XV2.0 Additional coated black CWKL, Vega E-white, Vega Grey, Novatouch, Jelly Epoch SE
Waiting to ship: Cruelworld 60, 8XV3.0 light grey WKL
« Reply #16 on: Mon, 02 August 2021, 10:27:47 »
seconded please make a green colorway
Offline Senpai_deezy
« Reply #17 on: Mon, 02 August 2021, 11:04:57 »
MAYA RED GUTS MAYA RED GUTS
Offline Riizmaa
« Reply #18 on: Mon, 02 August 2021, 13:08:19 »
Very hot! I would like one very much please! also MAYA RED GUTS
Offline Poesjuh
« Reply #19 on: Mon, 02 August 2021, 13:25:17 »
Maybe less fancy pictures but more actual useful ones where we can see the keyboard. How does the side look, the rear, the front, a simple top-down picture, etc.
Offline treeleaf64
    • treeleaf64
« Reply #20 on: Mon, 02 August 2021, 14:32:41 »
Everyone must pay the cat tax
Offline derpturtle
« Reply #21 on: Mon, 02 August 2021, 17:29:59 »
Check under the "more" section for additional renders. :)
« Reply #22 on: Mon, 02 August 2021, 18:12:01 »
what about a pcb pic? any chance for led support (built in or solder ... i'll take either lol) also PLEASE make a green one
Offline Tuba_Joe
« Reply #23 on: Mon, 02 August 2021, 18:37:17 »
YO !!!! 10u support !!!! Love the design and colors. Killer looking board, def on my radar !
We have a cult like following of 10u growing in the scene so this is a dream come true <3
Offline Lfgberg
« Reply #24 on: Mon, 02 August 2021, 21:18:12 »
« Last Edit: Tue, 19 May 2026, 13:25:46 by Lfgberg »
Offline cashmunny
« Reply #25 on: Mon, 02 August 2021, 21:23:08 »
MAYA RED GUTS
Offline Lfgberg
« Reply #26 on: Mon, 02 August 2021, 21:31:49 »
« Last Edit: Tue, 19 May 2026, 13:25:59 by Lfgberg »
Offline ShadowKeebs
« Reply #27 on: Tue, 03 August 2021, 00:24:53 »
MAYA RED GUTS
Offline Ozone
« Reply #28 on: Tue, 03 August 2021, 05:11:17 »
That typing test sounds great!
« Reply #29 on: Tue, 03 August 2021, 08:25:06 »
There’s indicator led support, pcb pics to come, have been having trouble exporting.
i saw that in the pic but i want to build this for my girl and she loves leds
Offline Poesjuh
« Reply #30 on: Tue, 03 August 2021, 12:27:35 »
Those are renders. Why not pictures of the actual product :(
Offline dieaspen
« Reply #31 on: Tue, 03 August 2021, 20:55:37 »
MAYAS RED GUTS
-Aspen
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #32 on: Tue, 03 August 2021, 21:29:07 »
late to the party but looks sick and glwic
red guts so lit
Offline udller
« Reply #33 on: Wed, 04 August 2021, 07:11:59 »
this look really cool, hopefully this gets an australian proxy or im lucky enough to get it from america. having a board with a 10u space would be killer :)
Offline Alvin12356lol
    • zambumon
« Reply #34 on: Wed, 04 August 2021, 10:36:43 »
sheeeeesh
Offline actualglacier
  • ¯\_(ツ)_/¯
« Reply #35 on: Wed, 04 August 2021, 11:26:52 »
This is exactly the kinda TKL I've been waiting for, wish the top and bottom gap wasn't so exaggerated though :( Good luck with the GB!
actualglacier on youtube
Offline 002_GT
  • KR Boards OP
« Reply #36 on: Fri, 06 August 2021, 20:08:03 »
Red guts all the way
Offline Iksion
« Reply #37 on: Sat, 07 August 2021, 03:53:11 »
Nice board :thumb:
KBD75v1 | Kira | Melody96 | TX75v2 | TX-CP | hbcp | Keycult No.2 rev.1 | NK65 | Duck Octagon v3 | Percent Volt | TX65v2 | KY-01 | Sunsetter | Mr. Suit | J-01 | Dolphin 2021 | Phase One 65 | KBD8x Mark ii
Offline actress
« Reply #38 on: Wed, 08 September 2021, 17:35:15 »
I want a red one  :p
EU proxy and ISO plates please and thank you!
Offline minhbuinhat99
« Reply #39 on: Tue, 05 October 2021, 23:11:21 »
Reserved, definitely would get one.
Proxies from Asia would be much appreciated!
