Author Topic: [GB] Harimau and Penyu Switch - Live till 31 August!  (Read 5458 times)
Offline hong@RebultKeyboards
  • Rebult Keyboards
    • Rebult Keyboards
« on: Sun, 08 August 2021, 21:54:02 »
273898-0
Hey everyone!
After a lengthy IC and multiple sampling revisions, the wildlife switches consisting of Harimau and Penyu are finally ready! If you missed the IC, the Harimau (Tiger) and Penyu (Turtle) switches are inspired by frankenswitches such as Zykos and BCP/Creampacas. These tactile and linear switches respectively aim to provide a smooth and poppy experience with the switches bottoming out on the extended pole.
This project is also a tribute to Malaysian wildlife, with Malayan Tigers and Marine Turtles becoming increasingly endangered, we wanted to raise awareness and contribute through this project. Hence, we will be donating a minimum of $1,000 to WWF Malaysia's Malayan Tiger and Marine Turtle Funds. This amount is just provisional and the minimum, if the project does better than expected, the amount will scale accordingly. This is just on our end, certain vendors have expressed their interest as well to contribute, we will be sharing the final amount contributed after the group buy ends!
The switches will come packed in biodegradable and compostable zip-lock bags made of bioplastics, aligned with the spirits of the project and at the same time reducing as much plastic usage as possible.
Group Buy Info
Start Date: 8 August 2021
End Date: 31 August 2021
Est. Fulfilment Date: November/Q4 2021
Price: $0.70 Per switch, varies according to region
Vendors
US: ThocKeys
CA: Mech.land
UK: Proto[typist]
EU: CandyKeys
AU: ALLCAPS
SEA (MY/SG): Rebult Keyboards
SEA (PH): Zion Studios
IN: StacksKB
MX: RHESET
CN: Zfrontier
Specs
Harimau
  • Tactile
  • Nylon Top
  • Nylon Blend Bottom
  • Long Pole POM Stem
  • 67g 18mm spring
  • Force Curve
Penyu
  • Linear
  • Nylon Top
  • 62g spring
  • Force Curve
Miscellaneous
Sound Tests (Do note that the switches have gone through revisioning since these sound tests were made, which may not represent the final product, please take it with a grain of salt, which you should anyway for switches)
ThereminGoat's Review of Harimau
Our Discord Server
Original GH IC Thread
« Last Edit: Tue, 10 August 2021, 21:38:10 by hong@RebultKeyboards »
Re: [GB] Harimau and Penyu Switch - Live till 31 August!
« Reply #1 on: Mon, 09 August 2021, 13:14:53 »
Approved :thumb:
Offline damsenviet
« Reply #2 on: Fri, 15 October 2021, 18:37:11 »
Will extras be available through vendors? Really hoping to get a set.
