Author Topic: [IC] DSA Abyss Hunter (Canceled)  (Read 16897 times)
Offline Exembe
« on: Fri, 20 August 2021, 01:51:19 »
-Welcome to the interest check for DSA Abyss Hunter-
I made the decision to cancel the original concept due to possible IP problems. I began a new concept which I will post later on when it is ready. The new concept will keep the colorways and some kitting from this project.
Thanks for everyones advice and help with this project.
Straight from the depths of the abyss comes the Abyss Hunter. A keycap set inspired by space bounty hunters and galactic monsters. Blast your way out from ruthless waves of aliens with these double shot keycaps made of ABS by Signature Plastics
Interest Form
Colors
2765 C - 2715 C - 2354 C
Kits
-Base Set-
The base kit has compatibility for TKL, 75%, 65%, 60% and some 40% boards along with support for F13 boards and Alice layouts.
-Alphas-
Standalone alphas kit.
-Num Pad-
Child kit to add the standard number pad keys.
-Novelties-
Novelties set featuring custom other-worldly hieroglyphics to add a pop of abyss to your keyboard. All designs are by me.
-NorDe-
NorDe child kit can be added to the base.
Deskmats
TBA open for collaborations
Renders
All renders were created by me.
*Renders may not depict final product.
-Whimsy by PRKNS-
-Fuji 65 by CMM Studio-
-Maya by Vulcan-
—Molly by The Key Company-
-Isometria by ebastler-
Vendors
US: Dangkeebs
CA: Alphakeys
EU: MyKeyboard
UK: Keycrox
PH/SEA: Zion Studios
AUS/OCE: Daily Clack
Contact Me
Discord: Exembe #3649
Instagram: buzzmosa
Change Log
03/25/22: Project is canceled
09/01/21: Taking a break on the project for now
08/30/21: Added NorDe support kit, added arrow keys instead of text
08/28/21: Made the light purple lighter for legend clarity. New Molly by The Key Company render and Isometria by ebastler
08/27/21: Removed 40s kit and changed the name of the set
08/19/21: First post
Signature
Code: [Select]
[url=https://geekhack.org/index.php?topic=114264.msg3078763#top][img width=280 height=120]https://i.imgur.com/mCLkS2J.png[/img][/url]
« Last Edit: Tue, 26 April 2022, 15:14:19 by Exembe »
Offline William_S_Jones
  • Best Prime Ever!!!
Re: [IC] DSA Void Hunter
« Reply #1 on: Fri, 20 August 2021, 02:50:02 »
Definitely, loving this set; especially w/ it being DSA profile & having a 40s kit, please sign me up!!!
Sent from my Surface Duo using Tapatalk
Offline ad4m
« Reply #2 on: Fri, 20 August 2021, 04:08:27 »
me likey. colorway is nice and kitting is also good
glwic :thumb:
Offline haplopoda
« Reply #3 on: Fri, 20 August 2021, 05:15:36 »
Love, love, love the colorway! Definitely in for a couple kits. glwic!
Sent from my GM1900 using Tapatalk
Offline Mecxs
« Reply #4 on: Fri, 20 August 2021, 06:11:44 »
Okay, number one - fix your images.
Number two - I don't even know because I can't see your images because they are 640x360 resolution.
Offline AbanOnPC
    • My Design Instagram
« Reply #5 on: Fri, 20 August 2021, 09:53:09 »
Love the colorway! I don't play the game in question personally but I'd still use the base kit :)
Offline Demagine
« Reply #6 on: Fri, 20 August 2021, 09:58:05 »
Kaisa inspo?
Offline Exembe
« Reply #7 on: Fri, 20 August 2021, 13:10:57 »
« Last Edit: Tue, 24 August 2021, 12:20:21 by Exembe »
Offline tarokeebs
  • TMOv2r2 || Kikuichimonji
« Reply #8 on: Fri, 20 August 2021, 14:21:27 »
great concept! looking forward to the release of this set :thumb:
collection: tmov2 | kikuichimonji
Offline Ella
  • Why is it called an oven
« Reply #9 on: Fri, 20 August 2021, 14:48:01 »
this is most definitely a keycap set
Offline Exembe
« Reply #10 on: Fri, 20 August 2021, 17:01:07 »
Should be fine now
Offline hzsh
  • aspiring renderman
« Reply #11 on: Fri, 20 August 2021, 17:10:59 »
Looks pretty nice, a thematic background for the kitting and board renders would be pretty nice as well. Was good to see this set develop, GLWIC.
Offline Exembe
« Reply #12 on: Fri, 20 August 2021, 19:14:04 »
Thanks, working with an artist on a deskmat already
Offline Exembe
« Reply #13 on: Sat, 21 August 2021, 14:17:33 »
Well i hope it is haha
Offline Exembe
Re: [IC] DSA Abyss Hunter
« Reply #14 on: Fri, 27 August 2021, 18:22:01 »
UPDATE
Removed 40s kit as it was not needed since base has popular 40s keys anyway
Changed the title to Abyss Hunter instead
Offline vishydesigns
« Reply #15 on: Fri, 27 August 2021, 18:44:54 »
Name change?
« Reply #16 on: Sat, 28 August 2021, 08:29:08 »
UPDATE
That's fine, should cut the cost down too. Still interested!
Offline Exembe
Re: [IC] DSA Abyss Hunter (Updated Colors)
« Reply #17 on: Sat, 28 August 2021, 19:58:23 »
More color updates and added a few renders
Offline Exembe
Re: [IC] DSA Abyss Hunter (Updated NorDe Kit)
« Reply #18 on: Mon, 30 August 2021, 20:49:11 »
Update
Added Norde kit and more renders!
Offline Hima Parvata
« Reply #19 on: Tue, 31 August 2021, 06:36:04 »
Loving it! ;D
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #20 on: Tue, 31 August 2021, 14:48:42 »
So okay.
I can't really care that this is blatantly inspired by a popular IP, or that you're lying when saying it isn't even though you've posted on discord that it was.
What I'm more concerned about, is that Dangkeebs and Alphakeys are, once again, willing to take a risk running a keyset inspired by this IP. With what happened with Encore, I would think that they would be more cautious about picking up this sort of thing, since I'm sure sending out refunds for all those orders has been a logistical nightmare.
The effort you put into the novelties is amazing, I really commemorate you for doing so. But if you're willing to make this set a reality, I implore you and the vendors go all the way and make this as official as possible, for everyone's safety and peace of mind.
Offline Exembe
« Reply #21 on: Tue, 31 August 2021, 17:51:04 »
So okay.
First thanks for the positive feedback on my novelties, i did work hard on them.
Second, i think i am handling this wayy differently then the other set in question. I am open to any suggestions on anything related to the set. I am making it clear that everything is my original designs and not direct copies from other companies IPs
Thank you for your feedback
Offline dvorcol
  • Discord: dvorcol_5071
Re: [IC] DSA Abyss Hunter (On Hold)
« Reply #22 on: Thu, 21 October 2021, 08:21:44 »
Please consider adding a homing kit for alternative layouts.
« Last Edit: Sat, 27 November 2021, 03:07:35 by dvorcol »
Offline Exembe
Re: [IC] DSA Abyss Hunter (Canceled)
« Reply #23 on: Fri, 25 March 2022, 18:11:39 »
Canceled this project and moving on to another
