Author Topic: Identify MX mount switches in a Chicony keyboard  (Read 7261 times)
Offline norolim
« on: Sat, 04 September 2021, 02:46:47 »
I posted this on another forum, but there were no guesses. Can anyone identify this one? Looks like similar to Futaba MA but there are clear differences. It might be some kind of dome with slider. It's from an unidentified Chicony keyboard.
Offline Nerif
Re: Identify MX mount switches in a Chicony keyboard
« Reply #1 on: Tue, 07 September 2021, 01:34:37 »
This keyboard looks like Chicony KB-5191. I tried to check out the page about it in deskthority wiki but there is no KB-5191 variant with such switches
̷C̷M̷ ̷Q̷F̷ ̷X̷T̷ ̷[̷C̷h̷e̷r̷r̷y̷ ̷M̷X̷ ̷B̷l̷u̷e̷ ̷→̷ ̷C̷h̷e̷r̷r̷y̷ ̷M̷X̷ ̷B̷l̷a̷c̷k̷ ̷H̷y̷p̷e̷r̷g̷l̷i̷d̷e̷]̷
Anne Pro 2 [Gateron CAP Brown → Kailh BOX Dark Yellow]
Offline Sup
« Reply #2 on: Tue, 07 September 2021, 03:46:19 »
Pretty sure its foam with slider since with out the keycap the slider is inside the housing instead of being up. The spring pushes the keycap back up what also puts the slider up. So its not mechanical.
« Last Edit: Tue, 07 September 2021, 03:48:54 by Sup »
current
Coming soon
Offline norolim
« Reply #3 on: Wed, 08 September 2021, 13:38:29 »
Thanks guys. It's not a KB-5191. Since I posted this question, I was able to identify the keyboard as a mysterious Chicony KB-5391:
Unfortunately, there is absolutely no info about it on the internets. Someone on another forum suggested the switches might be Deyi foam and foil. It is indeed very similar: the housing is identical, but the slider is a little different. Whatever the switch actually is, I agree with @sup that it probably is a foam and foil mechanism.
Offline _rubik
« Reply #4 on: Wed, 08 September 2021, 16:33:55 »
Putting the model under the legs -- sneaky!
Offline didjamatic
« Reply #5 on: Wed, 08 September 2021, 18:36:59 »
I'm 98% sure they're just sliders over a rubber dome membrane.   The only way to know for sure is to crack that sucker open.
Offline svenge
« Reply #6 on: Wed, 04 June 2025, 18:39:19 »
Hey probably irrelevant post but I just acquired the same exact board in a box of old keebs I got from an old electronics collector.  Just noting incase we need another sample for any reason.
