Author Topic: [IC]JTK ERROR 404 (11.26 Updated)  (Read 39513 times)
Offline HappyB0T
  • I'm a Piggie
Re: [IC]JTK ERROR 404
« Reply #50 on: Tue, 28 September 2021, 17:55:18 »
the colors are interesting possibly consider adding 3key 40s support as well as f13 glwic :).
No.
Looks like JTK Dreaming Girl has a 40s kit and it is running in October :D
Offline pr0ximity
« Reply #51 on: Tue, 28 September 2021, 21:06:20 »
I dig the low contrast and cyan, and we need more JTK sets out there
Offline vishydesigns
« Reply #52 on: Wed, 29 September 2021, 20:42:59 »
Looks great, consider having subs in base and getting rid of alt alphas, base seems a bit blah by itself. Love the novs! GLWIC!
Offline santela
« Reply #53 on: Thu, 30 September 2021, 00:28:16 »
BTW, can you do a color comparison with ASCII?
Offline andrewstar03
« Reply #54 on: Fri, 01 October 2021, 04:51:15 »
Is the Discord Link broken?
Offline Rifen
« Reply #55 on: Wed, 06 October 2021, 02:10:30 »
I don't know ASCII's colour atla.
Offline Rifen
« Reply #56 on: Wed, 06 October 2021, 02:13:12 »
It's OK. I can link, pls try again.
Offline HappyB0T
  • I'm a Piggie
« Reply #57 on: Wed, 06 October 2021, 09:26:23 »
Format is a channel not an invitation:
https://discord.com/channels/712936541361799218/883647759469641728
Click on Server Name in Discord > Invite People > Click the blue hyper text to edit timeline > Set Expire After = Never | Max uses = your choice > Generate New Link > link should have a unique 10 digit code. Example format https://discord.gg/1122334455
« Last Edit: Wed, 06 October 2021, 09:32:27 by HappyB0T »
« Reply #58 on: Sat, 09 October 2021, 00:05:37 »
Still not working. Anyways I just want to get updated on this. Hoping that GB happens soon so I can stop thinking about this.  :))
Offline Rifen
« Reply #59 on: Sat, 09 October 2021, 19:06:18 »
Try it again.I fix it just now.
Offline Rifen
« Reply #60 on: Sat, 09 October 2021, 19:06:48 »
Offline HappyB0T
  • I'm a Piggie
« Reply #61 on: Sat, 09 October 2021, 22:50:41 »
It is good now :D
« Reply #62 on: Wed, 13 October 2021, 21:35:27 »
novelties looks awesome, honestly would merge spacebar kits, and this is a bit nitpicky but your kitting render camera setup just aint it, the scene looks a bit warped for lack of a better word, especially in the base kit
Offline mikestah
« Reply #63 on: Thu, 14 October 2021, 21:49:30 »
Not sure I see the warping that you're talking about on the kitting renders?
Offline Ensaum
« Reply #64 on: Thu, 14 October 2021, 23:00:19 »
I don't either. And I fail to see how this would be relevant even if it were true.
Offline keebieweeb
« Reply #65 on: Fri, 15 October 2021, 05:48:10 »
i love this set! glwic :thumb:
Offline matthewdias
Re: [IC]JTK ERROR 404 (11.26 Updated)
« Reply #66 on: Sun, 05 December 2021, 19:40:15 »
The 40s kit has some errors:
- remove 1.5u tab, this is not used on 40s and you already have it in base
- remove quote key, you already have it in base
- change R4 "End" to "Enter"
Offline HappyB0T
  • I'm a Piggie
« Reply #67 on: Sun, 05 December 2021, 21:01:43 »
Extra tab in 40s base to compensate for lack of tab in alt Alphas.
This way you can fit 2 boards with Base + 40 + alt alphas. If it is not in alt alphas it should be here.
Thanks for adding 40s support.
Offline matthewdias
« Reply #68 on: Sun, 05 December 2021, 21:43:59 »
If that's the intended use then it should just go in alt alphas. 40s users don't benefit from it and it makes it way more expensive for the people that just need that one cap from the kit.
Sent from my Pixel 5 using Tapatalk
Offline Radon86
  • Radon86
    • Rn86's YT Channel
« Reply #69 on: Wed, 08 December 2021, 21:19:26 »
Hi, I'm not sure if it has been mentioned before but could there be a R1 1u "| \ /" key for the Russian kit (/ in light blue), the key is in the base kit but without the sublegend.
Also, is it possible to have the full set of number keys along with "+/=" and "_ /-" in the Russian kit so that we could have a full set of spare alphanumerics for another keyboard?
Thanks in advance!
« Last Edit: Fri, 10 December 2021, 06:20:23 by Radon86 »
Offline bigmaxnonions
« Reply #70 on: Sat, 19 February 2022, 12:05:33 »
Would love to see some keys like Enter and ESC in the light blue color, maybe as an accent kit?
Offline JSaintS
  • Formerly eNrageDSainT
    • JSaintS
« Reply #71 on: Wed, 05 October 2022, 06:55:47 »
Is there any update regarding this set? Seen in rendered on the Haven65 and cannot seem to join the discord.
Definitely interested!
Offline MMJ1999
« Reply #72 on: Thu, 06 October 2022, 22:02:42 »
definitely love it!
Offline Motan22
« Reply #73 on: Fri, 07 October 2022, 05:39:38 »
Submitting my interest in purchasing this set if it goes to production and has a vendor that will ship to the UK.
Offline NightFox99
« Reply #74 on: Wed, 30 November 2022, 10:13:14 »
Can you please make a "normal" Д letter in the base kit ? My eyes are bleeding everytme I see it in "retro" style :D For example, GMK Perestroika got it right. Or GMK Taiga. Please consider.
Offline kajahtaa
« Reply #75 on: Wed, 10 May 2023, 12:44:27 »
