Author Topic: Getting first mechanical keyboard. Some Questions about WASD  (Read 5267 times)
Offline Scott102
« on: Sun, 26 September 2021, 06:16:37 »
Hi,
I am tired of my Logitech K120 where certain keys are so mushy, I have to slam my finger to move between Excel cells among other things.
I was browsing about WASD subreddit, and I see very contradictory opinions about the brand.
I do have some questions though:
What is Anodized mean in terms of the keyboard option? Is it worth it?
I saw a lot of people say that the V2 have think keycap issues? But I don't really comprehend what people mean by that.
Is that still a problem in the V3 Keyboard?
I saw some people recommend you buy the keyboard but get caps from elsewhere. How does that work? Does the board come with the switches pre built in, and I have to get caps elsewhere to just pop them in?
What is your overall opinion of the V3 keyboard from WASD? I'm a gamer, but I do other things too, and I like the more traditional minimalist look that isn't flashy. But I see some people say great build quality, but could be better if you are willing to pay for custom elsewhere, but other people say to avoid WASD? As long as the quality is good for the price I'm buying and the machine perform as describe, I would be happy with it.
Offline aerOcraft
Re: Getting first mechanical keyboard. Some Questions about WASD
« Reply #1 on: Wed, 29 September 2021, 00:54:23 »
Don't. My opinion which will likely be shared by most, if not all, is don't get a WASD. It's great if you have zero interest in really diving into this hobby, but I would assume anyone who found their way to GH and posted on here instead of on Reddit exclusively has at least some interest in building their own computer. But if that isn't the case, then I would say it is no different from any other entry mechanical keyboard which is what I would call anything made by a brand like Logitech, Corsair, Ducky, Filco, Das Keyboard, Leopold, Razer. Chyrosran22 does a lot of reviews of non-custom keyboards and I would browse his channel and even message him after you do that if you have any questions. He's a super rad dude and is mega helpful and knowledgeable in that pre-built and old school part of the community. Otherwise just build your own. The quality ceiling is so much higher for custom builds.
« Reply #2 on: Fri, 01 October 2021, 04:03:00 »
WASD keyboards used to be middle of the road.  Their keycaps were always a bit meh, but they used to be one of the few places that let you customise layout and colour across the board in a set - most keycap places don't do that.
They also developed the CODE keyboard - I have a CODE with MX clears and it hasn't missed a beat, although a couple of the ABS keycaps costings are staring to wear a bit thin.
Anodising is just putting an extra layer on the keyboard case or plate, sometimes in a different colour.  Go for it if you don't want just a black case.
There are lots of choices for keycaps these days - GMK keycaps are great (but still ABS and will shine over time).  Uncountable PBT sets are available in all colours and designs these days - an easy swap as WASD keyboards have a standard layout.
Offline HungerMechanic
« Reply #3 on: Fri, 01 October 2021, 12:14:57 »
Hi,
Congratulations on escaping the Logitech K120.
The WASD isn't much discussed in the modding community anymore. IIRC it's comparable in typing experience to a Filco Majestouch, although I'm not sure if it's built as solid.
One common recommendation that makes sense in your case is a Leopold FC750 / FC900 PD. It's a conservative, standard layout and it's built very solid. The keycaps are considered by many as the best-in-class.
Keycaps should not be a determining factor in your purchase because, as you hinted at, keycaps are replaceable. All MX keyboards use MX-mount for their keycaps. This means you can just pull off the keycaps with a keycap puller and replace them with new keycaps.
What kind of switches are you planning to get? Ducky Shine 7 and One Two keyboards of recent vintage had good MX Browns in them, and Varmilo sometimes does as well. For MX Blue or MX Clear, I'm not sure if there are differences in batches.
Truth is, even a basic custom keyboard can be made to feel and sound better than a factory keyboard. In my experience, all factory keyboards, even the 'high-end,' are mediocre at best in fit-and-finish. Decent designs, but the lubing, tightening, dampening etc... are all questionable. And factory Cherry switches leave a lot to be desired.
But I guess you have to start somewhere. Have you considered Logitech's high-end rubber-dome and scissor-switches, by any chance?
Offline aerOcraft
« Reply #4 on: Tue, 05 October 2021, 15:00:04 »
This. You can get an ID80 and even though it doesn't feel that good in comparison to other custom keyboards, it is still vastly better than any factory keyboard including WASD. I even solved its most notorious complaint which is the sound by creating custom cut butyl sheets and adhering them to the case and the PCB. The Tofu is a tray mount which is pretty stiff especially by the posts, and it still feels so much better than factory boards. If you're already putting this much thought into it then just get a custom board and build the one you want.
Start here for form factors: https://switchandclick.com/keyboard-sizes/
And then go here for mounting styles: https://keyboard.university/200-courses/keyboard-mounting-styles-4lpp7
For the mounting styles the cheat sheet at the end has the general benefits and drawbacks.
Then come back here and ask for some recommendations of in-stock stuff.
« Reply #5 on: Tue, 05 October 2021, 22:31:09 »
Yes, I agree. I would add that some of the nicer but affordable KBDFans boards like KBD67 Lite and KBD8X MKII can be built into very nice things, but even the cheap and more-available boards like Tofu, KBD75, and the 60% boards can be made into something better than a factory keyboard.
You can improve a factory keyboard too, including Leopold, Filco, etc... it's really a matter of what you want to do.
Offline _rubik
« Reply #6 on: Sat, 09 October 2021, 14:50:16 »
I feel like other have said it, but I'll say it in fewer words: avoid WASD.
There are better quality boards out there for a comparable price. Nothing from WASD I've ever bought has stuck around past 9 months.
Offline Leslieann
« Reply #7 on: Sat, 09 October 2021, 21:45:08 »
WASD makes a solid keyboard, a bit behind the times and pricey for what you get for features but you can say the same about Filco, Model Ms, old Alps etc... They work great, they just lack some modern features. The caps are easily replaced.  It may not be the best board financially or hype-wise, but it's a board that should last a long time.
The anodized option means it comes with an aluminum case rather than plastic, it's one of the few mass produced boards (especially in stock) you can get with one.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
