Author Topic: [IC] BUILTBYNIM LINEAR SWITCH *[IC] form attached*  (Read 14972 times)
Offline ClackCulture
« on: Sun, 03 October 2021, 23:50:18 »
276788-0
Designed by Builtbynim
Manufactured by Tecsee
Please fill out the Interest check form: https://forms.gle/Pjqm1JGpq6TZAwxg6
GB date initiation: 15th November 2021
GB duration: 1 Month!
ARE YOU TIRED OF SWITCHES SOUNDING AND FEELING THE SAME?
BUILTBYNIM LINEAR SWITCHES HAVE BEEN SPECIFICALLY DESIGNED AND MANUFACTURED TO INCORPORATE A UNIQUE SOUND PROFILE AND FEEL.
DESIGNED BY AN ENTHUSIAST FOR ENTHUSIASTS AND BEGINERS ALIKE.
builtbynim instagram: @builtbynim
builtbynim discord: https://discord.gg/5b4EAPpQEx (best place for all the info, please join)
Sound Tests (twitch streamers)
ozziiobsessions: https://www.twitch.tv/videos/1163910050
builtbynim:
jamboards
Type test: https://clips.twitch.tv/ImpartialAmericanButterOptimizePrime-E_c5bl6U3y6Vt7SB
Switch comparison vs popular linears: https://clips.twitch.tv/FastSpotlessCocoaDAESuppy-MUh9HVreQIqfAuxx
276794-1
CONTENTS
1. INFORMATION
2. PROGRESS
3. VENDORS
4. PHOTOS AND PROMOTIONAL
1. INFORMATION
- Top housing: Custom nylon blend BBN top housing
- Bottom housing: Polycarb clear bottom housing
- Stem: Linear Pom Long stem (longer than "long"?)
- Spring: dual stage 63.6g (builtbynim recommended/Researched) or 68g gold plated spring
276790-2
2. PROGRESS/ RESULTS
2019-2021
-Builtbynim linear switch was designed using client commission data and personal switch sound preferences to produce a unique sound profile and a snappy feel.
12/08/2021
-Initial prototyping done with JWK and TECSEE,
-TECSEE manufacturing was chosen for v2 prototypes.
01/09/2021- (testing phase)
-Dual stage springs tested for spring sound stock vs lubed (105g0)
disclaimer* due to the lack of research and current developments in dual stage springs, there are some spring sound in stock form*
Results: spring sound little to non-existent with 105g0 application in bag lube form.
-Dual stage spring characteristics tested on switch housing lubed with thick 205g0
Results: due to the snappiness and higher rebounding properties of the dual stage spring, switches retained their snappy and forceful upstroke even after a thick 205g0 application. 205g0 application increased the "thockky" low pitch sound of the switch while remaining snappy. (205g0 recommended for modification).
(1:Opblack, 2:Lavenders, 3:NK creams 4: builtbynim dual stage spring)
276796-4
06/09/2021- (testing phase)
-BBN (builtbynim) switches v2 tested against popular switches
BBN vs lavenders, milky yellows, opblack, marshmallows, banana splits (all switches used were lubed by 205g0 on housing (top+bottom only), 105g0 on springs and tested on actylic switch tester)
Results:
smoothness/scratchiness: similar to lavenders and banana splits, smoother than milky yellows, marshmallows and opblacks
sound profile: Unique sound profile, deeper tone than lavenders, opblacks, milky yellows, marshmallows, and banana splits on acrylic tester
(1:Opblack, 2:Lavenders, 3:NK creams, 4:Builtbynim stem)
276798-5
25/09/2021
colourway for the switch chosen
Top housing: Pantone 356c
Stem: Pantone 9224c
Bottom housing: Clear
01/10/2021- (content creater and streamer sound testing)
-oziiobsessions live switch testing stream.
11/10/2021
-spring compression data uploaded
63.5g (builtbynim spec weight)
277161-6
68g
277163-7
3. VENDORS and PRICING
SEA: qwertyqop
AUS: allcaps.store
US: Dangkeebs
CA: shockport
EU: NOESC
PH: Himo-mk
4. PHOTOS
276800-8
276804-9
276802-10
« Last Edit: Tue, 02 November 2021, 18:40:28 by ClackCulture »
Offline lush_bunny
Re: [IC] BUILTBYNIM LINEAR SWITCH
« Reply #1 on: Mon, 04 October 2021, 01:45:17 »
Nylon top and PC bot is an interesting switch (heh).
Any sound tests?
« Reply #2 on: Mon, 04 October 2021, 02:19:20 »
hey yes! it does have a specific top out and a bottom out sound that i went for specifically!, i have some sound tests done by ozzii. (iv put the link in the IC) more sound tests will come in the next couple of days! stay in touch :)
Offline jamboards
« Reply #3 on: Mon, 04 October 2021, 05:33:04 »
Excited to try these out man! Looking awesome.
Offline Nonnegaard
« Reply #4 on: Mon, 04 October 2021, 05:53:31 »
interesting.
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline Zanhana
« Reply #5 on: Mon, 04 October 2021, 06:01:43 »
this is interesting, to say the least. what are the actuation and bottom-out distances with the (very) long pole stem?
« Reply #6 on: Mon, 04 October 2021, 18:32:55 »
thanks so much bro! you will get the switches to do a stream soon!!
« Reply #7 on: Mon, 04 October 2021, 18:35:51 »
hey thank you so much for your comment! i will upload those data to the IC including the spring force graphs in the upcoming days before we go to GB!!
im going to be as transparent and community first as possible in this run!!
Offline SDKCAMPING
« Reply #8 on: Mon, 04 October 2021, 18:43:18 »
It looks like the travel distance will be very short.
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline autocast
« Reply #9 on: Mon, 04 October 2021, 19:41:37 »
Interesting idea :)
Looks like a Feijoa fruit tree in the first pic: Feijoa would be a much better name for the switch imo ™®© ;D
« Reply #10 on: Mon, 04 October 2021, 23:40:42 »
interesting.
thanks so much! i hope to get this in to your hands soon! cant wait to hear everyones feedback!
« Reply #11 on: Mon, 04 October 2021, 23:47:10 »
it will have a short travel distance.
However, it is very similar to NK creams in that aspect, because of the dual stage spring giving somewhat of a higher resistance in the mid stage of the press, the shorter travel distance feels sharp and comfortable to type for long time periods.
« Reply #12 on: Mon, 04 October 2021, 23:48:10 »
Interesting idea :)
i really like that idea as well! maybe if a large number of people will prefer a true name i might actually host a naming competition!
Offline Mistyyy
« Reply #13 on: Tue, 05 October 2021, 06:59:26 »
should have made the stem black and called them BBC's
« Reply #14 on: Tue, 05 October 2021, 19:49:38 »
hahah thats actually hilarious
Offline Volny
« Reply #15 on: Wed, 06 October 2021, 07:35:52 »
I'm pretty sceptical that you can achieve a "unique...feel" with a linear switch, just by tweaking the housing plastics and slightly reducing the travel distance. Linear is linear. I'd be happy to be proven wrong though.
Offline Neptune Keys
« Reply #16 on: Wed, 06 October 2021, 11:53:33 »
So how different are we talking?
« Reply #17 on: Thu, 07 October 2021, 05:18:29 »
i dont think its gonna be a complete different experience but what im trying for is a difference in sound profile and the stem retuen feel!, just a bit different from all the mainstream offerings from jwk and cherry ;)
« Reply #18 on: Thu, 07 October 2021, 05:19:51 »
at the end of the day it is still a linear, but what im hoping to achieve is a difference in sound profile and a difference in stem return feel! i will upload the spring compression data soon!!
Offline stidal
  • milo#3939
« Reply #19 on: Thu, 07 October 2021, 09:07:48 »
seems pretty interesting! love long pole linears, definitely interested in these stems :]
transition tkl // aksara ce // bully // valhalla // voyager // rs60 // adiuvare // ciel60 // jules // prime e // ut47.2 // sequence // bumper // q1 // gaff60
« Reply #20 on: Mon, 11 October 2021, 00:51:59 »
yeah man for sure! i love long stem linears :) i think you are gonna be enjoying the whole switch not just the stems ;)
Re: [IC] BUILTBYNIM LINEAR SWITCH *vendors updated*
« Reply #21 on: Sun, 17 October 2021, 19:04:59 »
hey guys i have updated some of the vendors!! hope everyone is happy with the selections (only aus and us atm). sound tests are yet to come :)
Offline chat and team
« Reply #22 on: Sun, 17 October 2021, 19:47:37 »
still is a switch and will sound like a keyboard switch. nothing much to see here
geekhack mods constantly break tos and refuse to read
Chinese overlords won
« Reply #23 on: Sun, 17 October 2021, 20:05:01 »
yeah at the end of the day it is a switch, but something different to everything else out there! thats all!
Offline ALL CAPS
  • ALLCAPS
« Reply #24 on: Mon, 18 October 2021, 00:15:16 »
Loving this Nim, can't wait to see them in action!
« Reply #25 on: Mon, 18 October 2021, 08:02:13 »
thank you so much for your support bro!!
Re: [IC] BUILTBYNIM LINEAR SWITCH *[IC] form attached*
« Reply #26 on: Mon, 25 October 2021, 02:40:38 »
google interest check form is attached! please fill it out to show interest, if MOQ arent met the switch will not be made :(
Offline ReverbSlush
  • 16/52 RNG score
« Reply #27 on: Mon, 25 October 2021, 06:57:36 »
I like the name Feijoa.... I bet they'll just be called "nims" as slang on streams and whatnot.  Looking forward to trying them out!
« Reply #28 on: Mon, 25 October 2021, 18:51:51 »
thank you so much bro! the only reason iv not given them a general name is becasue im going to be doing my linear mostlikely for one run and then im going to be doing a researched tactile run, bbn linear and bbn tactile! A different community researched linear and tactile option for everyone!
« Reply #29 on: Tue, 02 November 2021, 18:42:09 »
Hey guys after consulting with the team we decided to commence the GB on 15th of November! only 2 weeks away and the GB will go for 1 month!   LETS GET READY!!!
« Reply #30 on: Tue, 02 November 2021, 19:04:22 »
updated vendors list:
SEA: qwertyqop
AUS: allcaps.store
US: Dangkeebs
CA: shockport
EU: NOESC
PH: Himo-mk
« Reply #31 on: Wed, 10 November 2021, 19:59:25 »
5 days away for the group buy!
Offline Havattack
« Reply #32 on: Wed, 10 November 2021, 20:05:36 »
Cool, these will go better with my jadeite build then the anubis switches i was planning on using.
Offline vi0till
« Reply #33 on: Thu, 11 November 2021, 04:20:07 »
Ne price reveal?
