Author Topic: [IC] Eri F12 TKL  (Read 36269 times)
Offline halocantkb
  • Formerly 'shota_irl'
[IC] Eri F12 TKL
« on: Wed, 06 October 2021, 19:03:42 »
It’s a basic tkl with a big weight and a bottom gasket design.
geekhack sucks at showing youtube videos so click the link to hear the soundtest if it's broken
Geekark Dolch - set by Kumori, render by eg0t1st1k4l
GMK 1520 - set & render by hark
Technical Specs:
18.5mm front height from front bezel, 19.65mm from the inside edge of the bezel
7deg angle
~3kg (6.6 pounds) unbuilt, 3.6kg (7 pounds) built w/ a brass weight
SKUF
Ai03 UDB
Seperate ISO/ANSI Plates
PCB by Lfgberg (QMK/VIA compat)
Screwless, Seamless
Forced WKL
Vendors:
Keyspresso, rest tbd
Special thanks to:
Hugo - vendor
Lfgberg - pcb design
eg0t1st1k4l - renders
hark - renders
Siege - general advice and checking manufacturability
mangeHD - internal help
finally, shoutout to zdc for all their support <3
« Last Edit: Wed, 06 October 2021, 19:15:00 by halocantkb »
Offline eg0t1st1k4l
Re: [IC] Eri TKL
« Reply #1 on: Wed, 06 October 2021, 19:04:13 »
reserved
Offline halocantkb
Re: [IC] Eri TKL
« Reply #2 on: Wed, 06 October 2021, 19:05:18 »
FAQ
Mounting Style
Eri uses a bottom gasket mounting style, with the screw going straight through the gasket. The intent of the bottom gasket is to not mute the sound as much as a full isolation mount gasket, as the vibrations are not dampened on both the top and bottom of the plate.
Units?
This IC helps determine the amount of units that will be included in the gb. As such, there's no gb unit amount currently decided.
Pricing
I can't give an estimate on pricing as I don't want to set up any false expectations but I'll try to keep it at a reasonable level, especially for the brass weight.
Simulation
« Last Edit: Sat, 09 October 2021, 14:10:35 by halocantkb »
Offline hark
Re: [IC] Eri TKL
« Reply #3 on: Wed, 06 October 2021, 19:06:11 »
Wow that black set looks really good ;)
« Last Edit: Wed, 06 October 2021, 19:14:58 by hark »
Offline Sandy
  • Formerly cogitoergofemme
  • Sandy - Peach Tray Maker
    • the peach · studio
Re: [IC] Eri TKL
« Reply #4 on: Wed, 06 October 2021, 19:06:29 »
looks good 🅱ro! glwic
🍑C11🍑KWA.6🍑GPK60 47-GR1RE🍑Vast60🍑Rose60🍑EHKB🍑Viktus Sinne🍑Boop65🍑Jelly60 Pro🍑Fuji65🍑Ginkgo 65🍑S7.7🍑Treasure Type-9 II🍑Thermal R2🍑Jelly 60🍑
Offline soloplayer
Re: [IC] Eri TKL
« Reply #5 on: Wed, 06 October 2021, 19:09:47 »
look so good!! i'm very interested
Offline kumori
    • polartype
Re: [IC] Eri F12 TKL
« Reply #6 on: Wed, 06 October 2021, 19:17:24 »
eri so nice
glwic friend
Offline Hugs94
« Reply #7 on: Wed, 06 October 2021, 19:18:10 »
Wow very pog.
Offline Kinesiologist
« Reply #8 on: Wed, 06 October 2021, 19:21:18 »
I like TKLs
Offline Baka Bot
« Reply #9 on: Wed, 06 October 2021, 19:22:11 »
looks promising. any target price available?
Offline hali
    • hali.studio
« Reply #10 on: Wed, 06 October 2021, 19:23:37 »
great rectangle
Offline scrps
« Reply #11 on: Wed, 06 October 2021, 19:25:43 »
nice hands bro
Offline Alejo1707
  • Gimme some more caps!
« Reply #12 on: Wed, 06 October 2021, 19:37:01 »
Offline autobot
« Reply #13 on: Wed, 06 October 2021, 19:40:47 »
Very nice, I’m watching this!
Offline SDKCAMPING
« Reply #14 on: Wed, 06 October 2021, 19:42:45 »
GLWIC, all board the janecult no.2 train  :eek:
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline frostykoala
  • consider Nightlight
    • Check out some Renders :)
« Reply #15 on: Wed, 06 October 2021, 19:52:10 »
naisu
Offline Lfgberg
    • Lfgberg.org
« Reply #16 on: Wed, 06 October 2021, 21:04:23 »
hypehypehypehype glad to see this coming to fruition
Offline chat and team
« Reply #17 on: Wed, 06 October 2021, 23:53:01 »
estamos
geekhack mods constantly break tos and refuse to read
Chinese overlords won
Offline darthcapn
« Reply #18 on: Thu, 07 October 2021, 00:07:02 »
Glwic! Looks rad!
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline vi0till
« Reply #19 on: Thu, 07 October 2021, 05:58:18 »
How limited this will be? I am interested.
Offline halocantkb
« Reply #20 on: Thu, 07 October 2021, 06:40:39 »
I like TKLs
me too
not atm but hoping to keep it at a reasonable level, especially with the brass weight
no amount decided, just gauging interest before we decide on an amount
Offline halocantkb
« Reply #21 on: Thu, 07 October 2021, 11:06:56 »
quick update - faq added
Offline sup3r170va
« Reply #22 on: Thu, 07 October 2021, 13:02:41 »
Very nice looking and sounding board. Looking forward.
Offline cyyz
« Reply #23 on: Thu, 07 October 2021, 13:46:38 »
Looks great, interested.
Offline Surefoot
« Reply #24 on: Thu, 07 October 2021, 15:12:54 »
Mounting system sounds really interesting for us who like firm mounts. Brass plate would be great.
Offline actress
« Reply #25 on: Fri, 08 October 2021, 10:42:47 »
Looks very nice. Interested if there is an EU vendor.
Offline baka jiken
« Reply #26 on: Sun, 10 October 2021, 04:29:41 »
Very nice looking board! Heafty
Offline //gainsborough
  • MATRIXの日常
« Reply #27 on: Sun, 10 October 2021, 15:57:49 »
Is there a form we can fill out to show interest?
Offline halocantkb
« Reply #28 on: Sun, 10 October 2021, 16:38:55 »
the big google forms button beside the discord icon
Offline Zach
« Reply #29 on: Sun, 10 October 2021, 17:34:29 »
looks neat, interested
Whale x2 | Salamander | E6.5 x2 | E8.5 | Nunu | 2.0 ADD | 8XV2.0 | 1.2 OG | Noah | Polaris | Vega | Infinitum | KFE CE | Jaguar | Frog  | Whale75 | Mode80 | Kei | Mode65 | E7v2 SE | Dolphinv3 | *165 | *Tomo | *Cloudline | *Kage | *Bias | *3.0
Offline thejje
« Reply #30 on: Sun, 10 October 2021, 23:14:36 »
hot
Offline Whale_algorithm
« Reply #31 on: Sun, 10 October 2021, 23:21:24 »
Interested. Would you consider an offset USB port, or an F13 top row? (I know the title specifically says F12)
Offline Onnimar
« Reply #32 on: Tue, 12 October 2021, 09:41:25 »
I'm game. I really like the design.
Offline Quadrum
    • Quadrum Labs
« Reply #33 on: Tue, 12 October 2021, 10:55:50 »
wish it was f13 but eri ftw
Offline Vanquish
« Reply #34 on: Wed, 13 October 2021, 11:10:28 »
As the Eri is still in the interest check phase, are you considering adding WK optionality?
Offline halocantkb
« Reply #35 on: Thu, 14 October 2021, 10:39:47 »
currently not considering wk, sorry
Offline _rubik
« Reply #36 on: Thu, 14 October 2021, 11:48:24 »
This is nice. F12 > F13 IMO
Offline mikestah
« Reply #37 on: Thu, 14 October 2021, 13:25:22 »
I have a burning passion for TKLs, will be watching this. GLWIC  ;)
Offline whitewolf154
« Reply #38 on: Sun, 17 October 2021, 21:35:48 »
Very interesting gasket implementation. I just hope there's some engraving on the top case so it makes the board unique
Offline OscarPapa
« Reply #39 on: Wed, 20 October 2021, 04:43:52 »
This is pretty much standard wkl tkl. Nevertheless I like it a lot. Only thing I'm not sure about is the logo. I would be interested if the price is reasonable.
Offline Neptune Keys
« Reply #40 on: Wed, 20 October 2021, 06:08:05 »
How different would a mount like this be against just a top mount?
Offline Mandabanker007
« Reply #41 on: Thu, 21 October 2021, 09:26:28 »
Great looking board glwic
Offline Hiiro_XoXo
« Reply #42 on: Sat, 23 October 2021, 14:56:31 »
Yo this looks nice. Interested
Offline cadrev
« Reply #43 on: Sun, 07 November 2021, 03:38:18 »
This looks really great! Looking forward to own one!!  :eek:
Offline hicals
« Reply #44 on: Mon, 15 November 2021, 18:16:59 »
Looks great, interested. :)) :)) :)) :))
Offline zozzled
« Reply #45 on: Tue, 16 November 2021, 15:28:46 »
The design looks really well thought out. Looking forward to this one for sure!
Offline lunatictaco
« Reply #46 on: Sun, 28 November 2021, 11:23:56 »
bumped. very interested in how this turns out.
Offline FlamedSiegmund
« Reply #47 on: Fri, 03 December 2021, 21:23:34 »
Keeping an eye out on this one
Offline VXQN
« Reply #48 on: Mon, 06 December 2021, 09:16:39 »
Love everything about the board apart from the bottom engraving. Two capitals followed by a lower-case "i" looks a little off. Not enough to put me off purchase though!
Offline vutid
« Reply #49 on: Fri, 17 December 2021, 22:18:12 »
this is too nice im creaming
GMK Rave
