Author Topic: Green ALPS springs in other ALPS switches?  (Read 4437 times)
Offline didjamatic
« on: Thu, 02 September 2010, 13:56:19 »
Has anyone tried lighter springs from Green ALPS in clicky White or Blue switches?
Going into another linear switch would be fine I'm sure, but I don't know how the pressure of the click leaf would work with the lighter springs... or are the springs even lighter?  Perhaps it's the absence of the click leaf is what makes the Greens lighter.
Offline itlnstln
« Reply #1 on: Thu, 02 September 2010, 14:48:03 »
Seeing as the first, what, .3mm of travel starts roughly (no pun intended) in the same place, it would make me think the click/tactile leaf has something to do with resistance in some varieties.
Offline ch_123
« Reply #2 on: Thu, 02 September 2010, 15:27:06 »
I love how this linear switch is clearly not linear at all...
Offline Henry
« Reply #3 on: Sat, 04 September 2010, 22:34:37 »
If I hadn't seen that graph I would never have guessed green ALPS weren't perfectly linear, but my Chicony keyboard is old and possibly worn out.
Offline didjamatic
« Reply #4 on: Sun, 05 September 2010, 09:08:42 »
Wait, you have a Chicony with GREEN ALPS?  I think they've used every possible switch in existence except buckling springs, but at this point nothing would surprise me.
The Zenith boards I had with Green ALPS felt totally linear as well.
Offline Henry
« Reply #5 on: Sun, 05 September 2010, 09:13:08 »
Yes, a Chicony KB-5161.
Offline lmnop
« Reply #6 on: Mon, 06 September 2010, 02:27:27 »
Quote from: ripster;219269
ALPS are like Big Macs.  Nobody knows what's in it but the Secret Sauce makes it go down easier.
Seriously I don't have one so it would be sheer speculation on my part but since Yellows are linear that would be my guess as well.
Or Teflon.  Anything is possible with ALPS.
the secret sauce in Big Mac is thousand island salad dressing.
it's easy to make it's a simple tartar sauce. mayonnaise, relish, ketchup.
« Last Edit: Mon, 06 September 2010, 02:30:13 by lmnop »
Offline lmnop
« Reply #7 on: Mon, 06 September 2010, 02:30:24 »
the secret sauce is mayonnaise, relish, ketchup aka thousand island salad dressing not exactly a big mystery :P
« Last Edit: Mon, 06 September 2010, 02:39:16 by lmnop »
Offline 8_INCH_FLOPPY
« Reply #8 on: Mon, 06 September 2010, 19:38:38 »
That's disturbing
Notable Switches I have tried:
black cherry, blue cherry, brown cherry, clear cherry, cherry M84, white alps, black alps, cream alps, Monterey blue alps, Fujitsu Peerless, Gateway2000 rubber dome, Keytronic rubber dome, Model M buckling spring, Model F buckling spring, futaba, black space invader
HAPPY HUNTING
