Author Topic: [GB] Viktus Sinne : O-ring/Burger mount Polycarb 60% - In QC  (Read 15450 times)
Offline BlindAssassin111
  • I design keyboards and stuff.
    • Viktus
« on: Mon, 25 October 2021, 12:45:02 »
Viktus Sinne
by
Viktus Design
Specifications:
• O-Ring/Burger Top Mount (3 mounts top, 3 mounts bottom)
• HHKB, WKL or WK Layout
• Polycarbonate case
• 7 degree board angle
• Type-C PCB support only (more info below)
• ~1.7 Kg w/brass plate
• Designed in collaboration with OneCreativeMind.
Where to buy:
• The GB will go live on Viktus.Design
• I am accepting US and international orders.
Dates:
• November 1st, 2021 @ Noon CDT to November 30th, 2021 @ Midnight CDT
• Q2/Q3 2022 delivery (depending on order volume this might change)
Mounting:
• Above is showing the O-rings on top and bottom of the plate as designed but you can build the board with multiple different mounting methods if you wish.
• If you want a squishier mount and are willing to redrill the plate mount holes to ~4mm, you can use drone controller soft mounts (silicone) and M3 set screws for alignment. (note this will drop the plate down a bit lower than normal)
Viktus Sinne Info:
• Color options:
    • Clear PC with sandblasted brass plate, weight, logo
    • Smoked PC with sandblasted brass plate, weight, logo
    • Atomic Purple PC with sandblasted brass plate, weight, logo
    • Teal PC with sandblasted brass plate, weight, logo (not prototyped yet, reference image on the product page)
• Layout options:
    • HHKB
    • WKL
    • WK, 7U bottom row only (with included/sold plates)
• Pricing:
    • Board:
        - Dyed: $365
        - Clear: $360
    • PCB not included.
    • Extra Tops: $110 each (all layouts and colors. Colors may vary from your full board due to batch variance and the dye process)
• Plates:
    • Brass: HHKB, WKL, WK, 10U WKL
    • Smoked PC: HHKB, HHKB half, WKL, WKL half, WK, WK half
    • Forged carbon fiber: HHKB, HHKB half, WKL, WKL half, WK, WK half
• Quantity:
    • MOQ: 80
    • MAX: Human limit, depends on how interest goes but probably somewhere around 200ish.
• Name:
    • The name Sinne means "mind" in swedish because of OneCreativeMind
PCB Support:
• All PCBs must have USB Type-C
• Tested to fit:
    • ANC60 v1 and v2
    • WT60-D
    • H60
    • DZ60
    • Plain60
Layout Support:
Prototype Pictures:
Full album:
Viktus Sinne prototype album
A few more amazing pictures:
NinjaPirate picture album
Build Streams:
• TopClack did a build stream here.
• TaehaTypes did a build stream here.
Special Thanks:
• OneCreativeMind for the original concept and name along with all of the feedback and support.
• Nox for helping fund the prototypes
• Quakemz for helping with the first build stream and being an all around awesome person to talk with.
• NinjaPirate for the unbelievably amazing pictures of my prototype.
• TaehaTypes for the second build stream of my prototype.
FAQ:
• Is a PCB included? I will not be including a PCB with the board. It has been confirmed to work with the AN-C (v1 and v2), Plain60, h60, DZ60, and WT60-D. Basically if it has a type-c connector it should work but I can't test every single option.
• Can you release the files so I can 3D print it? No.
• Will there be an aluminum version? At the moment there isn't plans for it but maybe later down the road.
Updates:
To follow the project you can keep up with this thread, my website www.Viktus.Design or via the Viktus Design discord server where I will be most active.
Discord invite: https://discord.com/invite/4w6aUKb
« Last Edit: Wed, 26 October 2022, 16:44:39 by BlindAssassin111 »
    • Viktus
Re: [GB] Viktus Sinne : O-ring/Burger mount Polycarb 60% - GB Starts Nov 1st
« Reply #1 on: Mon, 25 October 2021, 22:34:22 »
Update:
Got the updated quote and was able to lower the pricing to $360 clear and $365 dyed!!! I know it is a small change but still saving you $10 you can now spend elsewhere in the build.
Offline kimhoon9
« Reply #2 on: Mon, 25 October 2021, 23:35:52 »
Count me in for the atomic purple!!!
Offline spacecables
    • Space Cables
« Reply #3 on: Tue, 26 October 2021, 14:59:49 »
Nice, this looks really good and the pricing is pretty attractive.
GLWS.
    • Viktus
« Reply #4 on: Tue, 26 October 2021, 15:51:33 »
Update:
After some talking last night, I have decided to go ahead and add extra tops as an option for those that might want multiple layout options on the same board without needing to buy multiple full boards.
Cost will be $110 each. All 4 colors and 3 layouts will be available to purchase. Please note that color may differ slightly due to batch variance and the dye process so they may not be a 100% perfect match to your full board.
Offline Woovie
« Reply #5 on: Tue, 26 October 2021, 18:25:55 »
hotness, great design. might have to pick one up for the wooting 60%!
Offline HappyB0T
  • I'm a Piggie
« Reply #6 on: Wed, 27 October 2021, 00:04:28 »
Price seems solid - board looks incredible. Crap!
    • Viktus
« Reply #7 on: Sun, 31 October 2021, 21:28:59 »
GB Starts Tomorrow:
Just a quick reminder the GB opens at Noon CDT tomorrow and has an MOQ of 80, with a max of ~200.
Price is $360 clear, $365 dyed.
    • Viktus
Offline Fredington
    • Instagram
Re: [GB] Viktus Sinne : O-ring/Burger mount Polycarb 60% - GB Live
« Reply #9 on: Mon, 01 November 2021, 17:35:36 »
Ordered :thumb:
Offline Ahngel
« Reply #10 on: Wed, 03 November 2021, 18:56:38 »
Nice price, wish more people followed gb model and kept prices good like this
Offline syberghost
« Reply #11 on: Thu, 11 November 2021, 08:22:58 »
Copped. Get out of my wallet man.
yes, I'm the guy who put box jades on a Polaris
    • Viktus
« Reply #12 on: Thu, 11 November 2021, 11:57:32 »
Update:
Currently at 50 sold, so still 30 more before MOQ but with more than half of the month still left we have a good chance of making it still!!
Thank you all for your orders so far, hopefully we can get this last bit in before the end of the month.
Offline Drax
« Reply #13 on: Fri, 12 November 2021, 12:50:24 »
Would've bought from an EU vendor. Shipping is 63 euros and custom will legit murder me. Another time i guess...
Still waiting for a high end purple PC keyboard  :(
    • Viktus
« Reply #14 on: Sun, 21 November 2021, 12:37:20 »
Update:
Quick little announcement but wanted to let all of y'all know that the Viktus Sinne will be made!!! Thank you all for the support the past 3 weeks but don't worry about the state of orders as the only thing that matters now is: Buy one while you can, and get you friends who are on the fence to buy one while they can as well.
    • Viktus
« Reply #15 on: Wed, 24 November 2021, 11:50:25 »
FINAL WEEK:
Reminder that the buy closes on November 30th at midnight CST. Make sure to place your order before then if you want to guarantee you will get a board.
    • Viktus
« Reply #16 on: Mon, 29 November 2021, 12:04:22 »
Ends Tomorrow:
    • Viktus
Re: [GB] Viktus Sinne : O-ring/Burger mount Polycarb 60% - GB Ends Midnight CST
« Reply #17 on: Tue, 30 November 2021, 14:32:45 »
ENDS TONIGHT:
Final reminder that the GB closes at Midnight CST tonight.
    • Viktus
« Reply #18 on: Thu, 09 December 2021, 17:56:52 »
Update:
First payment was sent to the manu today so production will be starting very soon.
    • Viktus
Re: [GB] Viktus Sinne : O-ring/Burger mount Polycarb 60% - In Manu
« Reply #19 on: Wed, 26 October 2022, 16:44:27 »
Update:
Boards arrived yesterday and QC has begun. Will have another update in about 1.5-2 weeks, for more up to date information join the discord server or check the viktus site as I will update those more often.
Wanted to show a built teal Viktus Sinne as the original color was just a mockup due to the timing of its addition.
292677-0
