Author Topic: New Model F: can't get into bootloader mode ?  (Read 8752 times)
Offline jknight
« on: Thu, 04 November 2021, 11:56:04 »
I have a New Model F keyboard and I'm trying to flash the firmware to change the layout.
I did this once successfully, but I'm trying to redo it and now I can't get it into bootloader mode.
The last time I used "qmk-pandrew-macos-util-20210321.dmg" and it worked great, but now it doesn't recognize the controller:
I've tried various keyboard shortcuts (shift+B, etc) and "shorting two contacts while plugging the keyboard in, and releasing after" but that doesn't seem to do the trick.
Any ideas how to get a new model F keyboard controller into bootloader mode ?
« Last Edit: Thu, 04 November 2021, 11:58:48 by jknight »
Offline Maledicted
Re: New Model F: can't get into bootloader mode ?
« Reply #1 on: Thu, 04 November 2021, 12:06:45 »
Hi jknight. Are you shorting the contacts and then plugging the USB cable in while they are still shorted and leaving them so for about a second after? I have had to do that a few times with New Model Fs to get mine into bootloader mode.
It might take a few attempts to get the process down, even if you're doing everything in the right order.
Offline jknight
« Reply #2 on: Thu, 04 November 2021, 13:10:35 »
Yes that's exactly right. 15 attempts so far and no luck ....
how do you do it exactly ? Use a paperclip to connect the two and plug it in ?
Offline Maledicted
« Reply #3 on: Thu, 04 November 2021, 17:06:22 »
Anything conductive should work. The blade of a screwdriver, a paperclip, a scrap piece of wire, etc. If there's any external coating on whatever you're shorting with, it might need to be scuffed off.
Offline cheater
« Reply #4 on: Sat, 09 August 2025, 14:36:22 »
for anyone who runs into this issue, newer pro micro's have a new bootloader. you have to power up the microcontroller and then short reset two times very quickly and then it'll be in boot loader mode for 8 seconds. hope this helps.
