Author Topic: Screw & Gadget Tray  (Read 4507 times)
Offline neonsuki
Screw & Gadget Tray
« on: Tue, 16 November 2021, 16:56:04 »
Looking for a list of tray choices!
Ala Rama Works, KBDFans, etc.
Anyone know of any good, small screw trays out there?  :-*
Offline Leslieann
Re: Screw & Gadget Tray
« Reply #1 on: Tue, 16 November 2021, 19:22:11 »
The best ones are the ones you make yourself, I have a 3d printed one that works well. Holds screws, SD cards, usb sticks, and misc.
« Last Edit: Tue, 16 November 2021, 19:23:42 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
