Author Topic: [IC] Premium Hope75 Gasket Mount Keyboard Kit  (Read 4866 times)
Offline john08099
  • Velocifire MK
    • Mechanical keyboards for typers
« on: Tue, 16 November 2021, 21:05:18 »
Hi Everyone,
Good news! We are introducing a premium Hope75 Keyboard kit today.
Please check Hope75 Keyboard kit Albums: https://imgur.com/a/Ycm4Y8I
The Hope75 keyboard kit is a premium, compact, gasket-mounted keyboard kit. It is designed to be screwless with a unique internal locking plus an external locking fixing method.
Both the PCB and the plate have been designed with many flexes cuts to ensure a soft typing feel and premium typing sound experience. No worries, they won't affect the strength of the PCB and plate since we have tested a lot.
The weight of the Hope75 keyboard is fixed in a through-through way. And we adopt the magnetic footpad to cover-up the screws to avoid the incongruity of extra screw holes. It makes the surface of the keyboard look tidy and clean and easier to disassemble the kit.
We are working hard to handle all details, only hope it can let you have a more good experience. Please fill in below IC form with your idea and make this kit better and better.
Default Specifications:
* Screwless design
* 6063 Alu case
* Gasket Mount
* 6° Typing Angle
* Type-C
* Wired
* Hotswap PCB with USB-C daughterboard
* PC plate(flex cut design)
* QMK/VIA Supported Hotswap PCB
* ANSI Layout
* Support PCB stabilizers
* Poron Dampening pads
* Hope75 keyboard kit Dimensions
Extra Soldered PCB: ANSI and IOS Layout
Color: E-White, Black, Yellow, Grey, Milky-White, Blue, Sky blue, Wine red
Estimated GB time: December 2021/ January 2022
Please fill in our IC form at: https://forms.gle/Hwyo2pPFBQn2rYe38
We will release more updates in the coming weeks. Update more photos, sound tests and more!
We recommend you join  our Discord for more details
Also, feel free to comment here.
Thank you!
Velocifire Website: https://www.velocifiretech.com/
E-mail: John@velocifiretech.com
Make Typing Better | Velocifire
Offline Ustinj
Re: [IC] Premium Hope75 Gasket Mount Keyboard Kit
« Reply #1 on: Tue, 16 November 2021, 22:14:18 »
Curious, what is the engraving of?
Offline john08099
  • Velocifire MK
« Reply #2 on: Tue, 16 November 2021, 23:02:00 »
you can look this picture: https://i.imgur.com/f4vTcy2.png
Offline alper_maestro
« Reply #3 on: Mon, 03 January 2022, 16:42:15 »
uhm, I'm seeing 3 topics about the same board. Isn't that confusing?
Which on must we follow for updates etc?
https://geekhack.org/index.php?topic=115418.0
https://geekhack.org/index.php?topic=115555.0
