Author Topic: [IC] Blue Bubblegum Linear  (Read 11150 times)
Offline caughtquick
« on: Fri, 10 December 2021, 10:14:51 »
From Keebhut, a small vendor out of Southern California comes it’s first switch, the Gateron Blue Bubblegum Linear.
Photo Album: https://imgur.com/gallery/QtEbpWG
Photographed by @[nangtendo](https://www.instagram.com/nangtendo/)
Specs:
* POM Stem
* INK Bottom Housing
* Nylon PA66 Top Housing
* 55g Actuation
* 65g Bottom Out
* 4.00mm Travel
* MX Style
* PCB Mount (5 Pin)
The color scheme for this switch is inspired by the color of bubblegum, combined with the color blue, cause why not. Hence the name, Blue Bubblegum. The materials were chosen to retain the smoothness and feel of the much loved Gateron Black Inks while using a nylon top to lower the pitch of the switch and a 65g spring rather than the heavier 80g spring in the Black Inks. This switch will come in at 70c per switch in the US and similarly priced in the rest of the world, adding taxes. The switch will also be unlubed.
IC Form: https://forms.gle/8H6tPp1Jue6aWXsb9
Vendors
US: https://keebhut.com
Mexico: https://switchclub.com.mx
Europe: https://keygem.store
SEA: https://en.zFrontier.com
OCE: https://allcaps.store
« Last Edit: Tue, 01 March 2022, 20:22:03 by caughtquick »
Offline Fraaaan
Re: [IC] Blue Bubblegum Linear
« Reply #1 on: Fri, 10 December 2021, 10:18:20 »
75 cents for a KS3 Gateron?
Offline caughtquick
« Reply #2 on: Fri, 10 December 2021, 10:21:35 »
It’s an Ink Gateron with a nylon top, not a KS3
Offline matthewdias
« Reply #3 on: Fri, 10 December 2021, 10:21:54 »
How is it ink V2 if it's nylon
Sent from my Pixel 5 using Tapatalk
Offline caughtquick
« Reply #4 on: Fri, 10 December 2021, 10:24:07 »
Ink Bottom Housing and Ink Stem
Offline stewfayew
« Reply #5 on: Fri, 10 December 2021, 11:43:58 »
(Ink v2 stem) + (Ink v2 bottom housing) = scratchy like Ink v2
Offline mvkb
  • Designer
    • MVKB
« Reply #6 on: Fri, 10 December 2021, 12:13:52 »
Nylon top best top.
Offline caughtquick
« Reply #7 on: Fri, 10 December 2021, 12:41:41 »
Yep, I prefer nylon top too so that’s why I’m running this GB. Also on the statement that these will be scratchy it’s still being decided on if we should run it with or without factory lube.
Offline stewfayew
« Reply #8 on: Fri, 10 December 2021, 13:41:29 »
They're scratchy with or without lube. I'd look into a different bottom. Or maybe a different stem would help.
Offline caughtquick
« Reply #9 on: Fri, 10 December 2021, 15:25:57 »
That would impact sound in a negative way
Offline stewfayew
« Reply #10 on: Fri, 10 December 2021, 18:29:15 »
so would scratch  :))
glwic!
Offline caughtquick
« Reply #11 on: Tue, 01 March 2022, 20:35:49 »
I've updated the IC with a new photo album, more accurate information, and a vendor list.
Offline Botty212
« Reply #12 on: Wed, 02 March 2022, 01:47:24 »
regional vendor = no 30$ shipping = no overpriced switches = happy EU customer
Offline 3tails
« Reply #13 on: Tue, 08 March 2022, 12:44:07 »
Will there be a sound test
Offline caughtquick
« Reply #14 on: Tue, 25 October 2022, 23:57:38 »
Round 2 will begin October 27th, 2022. GB thread will be posted shortly.
