Author Topic: Searching for a touchpad / trackpad to built into a 3d printed case  (Read 76891 times)
Offline ham5urg
I'm looking for a touchpad / trackpad to build into a keyboard. Something similar to https://www.cherry.de/cherry-g84-5500-xs-touchpad-keyboard.html but larger and without buttons.
But I have no clue what kind of touchpad is good for which microcontroller?
The responsiveness as well as left-click, left-click-and-hold, scroll-with-2-fingers, middle-click-with-3-fingers are important to me. I hope to get a touchpad that is somehow similar behaving like a good laptop-touchpad. Without the need of a extra driver in the OS.
How hard is it to get it electrically connected with a microcontroller? I hope not to hard.
Offline jennyluce
Re: Searching for a touchpad / trackpad to built into a 3d printed case
« Reply #1 on: Fri, 21 January 2022, 04:09:19 »
Logitech K400 PLUS WIRELESS TOUCH KEYBOARD you should get this
Offline Leslieann
« Reply #2 on: Fri, 21 January 2022, 08:22:55 »
Not sure how easy it would be to disconnect the touchpad from the rest of the keyboard, same for the buttons on it.
It's also a pretty small touchpad, barely any larger than the Cherry one.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline butre
« Reply #3 on: Fri, 21 January 2022, 13:52:20 »
there's no trackpad better than the apple magic trackpad, and it would be foolish to choose anything else
Offline Leslieann
« Reply #4 on: Fri, 21 January 2022, 15:54:51 »
Honestly, this is the bast answer.
Unless Lenovo makes one which could fit better, but even then the Apple would perform better.
Apple, especially on Mac, has the trackpad game dialed, Apple laptops are pretty much the only laptops where I felt I could get away without a mouse while browsing the net. Some newer ones are not bad and I can use them for a while without problem but Mac just really has it figured out. Unfortunately some of that is the OS. MacOS is almost designed for it, Linux (KDE in particular) does quite well with it, Windows lags far behind on this in my opinion.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Korban
« Reply #5 on: Sat, 04 June 2022, 09:35:12 »
Although I agree with you, I wonder how one could get his hands on the new Lenovo Thinkpad X1 Titanium Yoga Touchpad from Sensel. Probably the only one who can compete with Apple's, although finding an Apple touchpad might be much easier atm.
