Author Topic: [IC] Krush65 PCB & RE6.5 (Best choice for KBD67 lite replacement)  (Read 11974 times)
Offline nuxroskb
    • Keyboard from Vietnamese Maker
« on: Sun, 19 December 2021, 03:36:36 »
[IC] Krush65 PCB &RE6.5 by Nuxroskb
Features and the reason behind our product:
Today's ever-expanding custom keyboard market offers a variety of budget options. This includes the KBD67 Lite, which is a really decent keyboard at its price point. However, it has yet shown its full potential currently for the following reasons:
- Offer a rather stiff typing experience though being a gasket-mount board
- Lack contemporary features such as flex-cut or rotary encoder
 ----->Therefore, Krush65 PCB aims to fully address these issues.
Krush65 PCB will feature the following:
- Support for daughterboard
- USB Type-C
- Rotary encoder
- Underglow RGB
- 4 flex-cuts
- Keymapping through VIA/QMK
- Hotswap/solderable versions
Layout supported:
6.25u
7u
Split space
Changes that the Krush65 PCB combo brings to improve the KBD67 Lite:
- Complete redesign of the plate so the flex no longer centered in the alpha region, it can instead be felt on every spot of the keyboard
- Swapping silicon to poron gasket
----> The combination of plate+PCB+Poron gasket will bring your KBD67 Lite to a whole new level.
Plate
Flex test with KBD67 lite
Furthermore, if you haven't got a keyboard case, then the stacked acrylic RE6.5 case is also a considerable option.
There will be a version with weight that is heftier and a more unique acoustic-wise
Real photo
https://imgur.com/a/gY3ABIF
Soundtest & Flex test
by Taiyakeys
by Tailerkeebs
The Krush65 PCB combo can both be used for KBD67 Lite and RE6.5 case with just a little unscrewing. It is also compatible with other KBD cases like KBD67, Blade 65, D65, etc.
The most important is the price. We will try to make this the most affordable and accessible to everyone. Our Round 1 has just ended in Vietnam and Round 2 will open as soon as possible.
For further information about the Krush65 PCB and RE6.5 case, you can join our Discord at: https://discord.link/mechkey and turn on notification for our upcoming sales.
More infor about me here:
Insta https://www.instagram.com/nuxroskb/
« Last Edit: Sun, 19 December 2021, 03:40:14 by nuxroskb »
Offline wahfuhls
Re: [IC] Krush65 PCB & RE6.5 (Best choice for KBD67 lite replacement)
« Reply #1 on: Sun, 19 December 2021, 07:51:46 »
pricing?
Offline CloudyEyes
« Reply #2 on: Sun, 19 December 2021, 23:15:00 »
Im interested for this
Offline nuxroskb
Offline nuxroskb
« Reply #4 on: Sun, 19 December 2021, 23:41:16 »
Thank you so much! Please join our discord for more information and sale announcement
Offline CloudyEyes
« Reply #5 on: Sun, 19 December 2021, 23:42:54 »
Unfortunately, Im on my phone right now and my phone wont let me redirect to the discord app but I will join the discord when i got time to use my pc
Offline drfilco
« Reply #6 on: Mon, 20 December 2021, 14:07:02 »
Color me interested.
Offline nickthaskater
« Reply #7 on: Tue, 21 December 2021, 02:25:28 »
pricing?
It's under $150
$150 seems... High. Plate should be no more than $25. PCB maybe $60 at most?
Offline nuxroskb
« Reply #8 on: Tue, 21 December 2021, 08:49:22 »
pricing?
It's under $150
No. Under $150 for one kit which's including: Case + Plate + Gasket + PCB + PE Foam + Foam PCB
« Reply #9 on: Tue, 21 December 2021, 11:07:41 »
pricing?
It's under $150
Ah, that makes much more sense. Thanks for clarifying  :thumb:
Offline SE7EN_ate_NINE
« Reply #10 on: Tue, 08 March 2022, 09:32:20 »
Any update on the Krush65 B PCB? Since this will also work in the Sangeo65 and is the only option for that board, KBD67 MKII and 67 Lite with a 7U bottom row I'm hoping it's going to happen.
