Author Topic: How do you move a window that opens in another monitor in Win10  (Read 7473 times)
« on: Fri, 24 December 2021, 22:19:28 »
A. My 2nd monitor is busted so I cannot turn it on to just drag/drop
B. Windows Key+ Shift + Arrow does not work. I know it is supposed to work, but it 100% does not.
pls
Re: How do you move a window that opens in another monitor in Win10
« Reply #1 on: Sat, 25 December 2021, 01:18:06 »
i figured it out. managed to cobble together a 2nd monitor out of some goat milk, mud, shaved whale baleen, and my roommate's spare monitor.
all good, thanks
Offline Leslieann
« Reply #2 on: Sat, 25 December 2021, 09:57:54 »
Easiest way is to disconnect the second screen entirely or disable it in display settings, all windows will pop back to the main screen.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline phinix
« Reply #3 on: Fri, 11 March 2022, 09:20:15 »
You know what, I was looking for a keys shortcut for that few months ago. Some combination to press and get all windows centered on active screen.
Have not found it.
