Author Topic: [IC] Paintbrush | A 45% Keyboard | GB Date & New Vendor Announced!  (Read 33668 times)
Offline Zeus501
Paintbrush Redux
A 45% keyboard with exploded escape, arrows, rotary encoder/knob, and 'nav cluster.'
Featuring a gasket mounted plate, copper through weight and more!
Introduction
Inspired by the layouts of Abec13's 45-ATS and WalletBurner's Cajal, the idea for Paintbrush was born. After several changes and prototypes, the case was redesigned from the ground up with a focus on retaining the signature look and feel of earlier revisions while implementing more modern design elements.
Links
IC FORM
Layout
The PCB supports the following options for the bottom row:
Specifications
- Typing Angle: 7°
- Front Height: 18.1mm (23.1mm EKH)
- Case weight: 1.3kg (2 lbs 14oz) built
- Case Material: 6063 Aluminum for top and bottom | Copper for weight and knob
- Mount: Gasket Mount | 4 mounting points with 1/8" gaskets above and below the plate
- PCB: RP2040 with QMK/VIAL support and S1 UDB
Group Buy Details
- Case Colors: Blue, Grey, Green, Black
- Plate Materials: FR-4, POM
- Cost: TBD
- GB Date: March 4th - April 8th
- Vendor: CBKBD (Worldwide)
Media
V1 Proto build stream by Hedgey404:
Photos
The V6 protos are using the incorrect screws and will be fixed for GB. Copper weight and knob finish may differ depending on IC results.
V1 Photos
V2 Photos and Renders
V3 Photos
V4 Photos
V5 Photos
Design Changelog
V2 Prototype:
- Redesigned external case elements for a cleaner aesthetic.
V3 Prototype:
- Designed custom press fit knob with engraving.
- Reduced number and strength of magnets used for securing halves.
- Redesigned the weight to mount from the bottom with more magnets to be more secure.
- Moved the UDB lower in the bottom to avoid PCB bottoming out on the JST connector.
V4 Prototype:
- Modified knob engraving to accommodate easier CNC machining.
- Added cutouts for easier gasket placement on bottom case half.
- Added threaded holes to all parts for easier finishing.
- Changed from circle bumpons to custom cut rubber feet.
- Changed knob to use set screw for increased part consistency and reliability.
V5 Prototype:
- Redesigned case to be seamless and removed magnets.
- Lowered case height.
- Moved mounting points slightly.
- Changed the weight engraving.
- PCB MCU updated to RP2040.
V6 Prototype:
- Updated custom daughterboard to S1 UDB.
- Updated PCB to use Molex EZ-Mate connector for S1 UDB compatibility.
Acknowledgements
- OCM for the engraving artwork
- Olivia for the renders
- Hedgey for the build stream
- Dominic for being a nice guy
« Last Edit: Wed, 07 February 2024, 16:14:56 by Zeus501 »
Offline Zeus501
Re: [IC] Paintbrush | A 45% Keyboard
« Reply #1 on: Sun, 02 January 2022, 21:51:03 »
Reserved
Offline matthewdias
« Reply #2 on: Sun, 02 January 2022, 22:06:16 »
cool keyboard very hyped
Offline surplusofchairs
« Reply #3 on: Sun, 02 January 2022, 22:14:11 »
very hyped for this
Offline Hedgey
« Reply #4 on: Sun, 02 January 2022, 22:16:28 »
I don't know who on earth would buy this board??  It's so weird with no screws, magnets, gasket mounting, and copper material.....
J/k this thing feels amazing and is a real pleasure.
"Resellers don't kill the community, auctioneers kill the community. Look at what happened to Diablo 3"
Offline darthcapn
« Reply #5 on: Sun, 02 January 2022, 22:37:27 »
I have been waiting to take a plunge into the 40s world since long and I feel this would be the best board to have! It is an absolute peice of art. Glwic!
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline paperassgasket
« Reply #6 on: Mon, 03 January 2022, 00:24:52 »
Paintbrush gud.
I love it when 40's manages to leak into GH. GLWIC
Offline rainkeebs
  • rainkeebs.mx
    • Rainkeebs
« Reply #7 on: Mon, 03 January 2022, 00:25:32 »
Looks fantastic and the magnet construction is genius! Hope to see many of these on Reddit in the future. Well done Zeus :thumb:
Offline Ll3macorn
« Reply #8 on: Mon, 03 January 2022, 00:41:30 »
poggers
Offline derpturtle
« Reply #9 on: Mon, 03 January 2022, 01:57:17 »
love me a chunky 40
Offline Mecxs
« Reply #10 on: Mon, 03 January 2022, 04:02:38 »
Is there a default plate?
Offline growler
« Reply #11 on: Mon, 03 January 2022, 07:52:36 »
Thicc
Sent from my SM-G980F using Tapatalk
Don't just stare at it ...
Offline Cylent
  • Formerly cylentshadows
« Reply #12 on: Mon, 03 January 2022, 08:10:26 »
Looks cool, but why the exploded esc?
Offline Zeus501
« Reply #13 on: Mon, 03 January 2022, 09:25:14 »
I’m working on updating the plate to be universal for all bottom row layouts. Default plate material as it stands will be FR-4. There will be a choice between a full plate or half plate come GB time.
Offline Zeus501
« Reply #14 on: Mon, 03 January 2022, 09:28:52 »
Why not? But more seriously, I just think it looks cool. Not much more to it than that.
Offline Nurseh
  • Sorry for always apologizing
« Reply #15 on: Mon, 03 January 2022, 10:41:56 »
Copper engraved weight? Hype!
Offline Xury46
« Reply #16 on: Tue, 04 January 2022, 00:14:47 »
Very exciting, I saw this on the 40s Discord server a while back and I was wondering when I might be able to get my hands on one!
Offline floweryi
« Reply #17 on: Tue, 04 January 2022, 01:23:43 »
unfortunately i'm not deep enough in the hobby to warrant buying this but just would like to say that i absolutely love this layout and the aesthetics are incredible. glwic
Offline HappyB0T
  • I'm a Piggie
« Reply #18 on: Tue, 04 January 2022, 01:38:02 »
Don't daily drive 40s but I want in on this one. What a cool layout.  :cool:
Offline Rumblethumps
« Reply #19 on: Wed, 05 January 2022, 23:19:55 »
Whimsy was going to be my first 40s, but with it indefinitely on hold for now, this one might take its place. That wine color is slick!
Offline Madrigal
  • We're only immortal for a limited time
« Reply #20 on: Sat, 08 January 2022, 00:03:12 »
Any plans on a hotswap pcb  :p
I long to turn my path homeward / to stop a while with you
Offline white_rabbit
« Reply #21 on: Sat, 08 January 2022, 02:27:09 »
Keep up the great work Zeus ! :thumb:
Offline Zeus501
« Reply #22 on: Sat, 08 January 2022, 15:14:32 »
Currently there are no plans for a hotswap PCB due to the amount of supported bottom row layouts.
Offline wndy
« Reply #23 on: Sun, 09 January 2022, 10:39:28 »
This board looks absolutely fantastic, can't wait to see it run.
Offline depressedkeebs
    • Depressed Keebs
« Reply #24 on: Sun, 09 January 2022, 18:39:43 »
ngl i love the combination of brass and polycarb
Offline PixelPlays__
  • God, this hobby is so expensive.
« Reply #25 on: Sun, 09 January 2022, 22:31:00 »
Why is the escape key shifted away like that? I think moving it back into its normal place and using a smaller knob would look better. Reminds me of the Q2's exploded Insert key.
Besides that, I like the design here! Any chance of adding 2.25/2.75 split support alongside the 3/3 split support it already has?
Offline Mecxs
« Reply #26 on: Sun, 09 January 2022, 22:34:16 »
I like the exploded esc key. I am comfortable using it on an Alice layout, so it doesn't hugely bother me from an ergonomics perspective. The other benefit is that most GMK base kits offering basic 40s support in base don't add an accented esc in R2. So if you want to use accented esc you have to use the R1, which looks and feels weird when next to Q. This way that feeling disappears, or at least isn't as glaring.
Offline Zeus501
« Reply #27 on: Sun, 09 January 2022, 22:51:29 »
The escape is shifted away because I like the way it looks. As Mecxs pointed out, there are some actual benefits to it, though. Escape key placement will not change.
The knob size will also stay the same. The current size is ~18mm with the cutout being 19.5mm. This is a fairly standard size and supports a wide range of other knobs such as the Sat75 knob, GMMK Pro and most guitar knobs.
There is already 2.75/2.25 split support, but if there is enough interest in 2.25/2.75, I can look into adding it.
Offline Zeus501
« Reply #28 on: Sun, 16 January 2022, 00:52:10 »
I've been quiet on this project for a while, but I've got a nice update!
I got some great feedback on the proto and I've made several changes to fix some issues/criticisms that were experienced. Some of the changes made are to fix design flaws instead of actual functional issues.
Problems
- Case halves too hard to take apart.
- Weight not secure enough and can easily be dismounted during assembly/disassembly.
- PCB bottoming out on daughterboard JST connector with half plate.
- Too much lateral movement between case halves.
Changes
Case Magnets
- Adjusted placement | 4 magnets are placed in the corners and 2 magnets are placed in the middle. The are now also properly centered.
- Adjusted amount | 6 magnets used instead of 8
- Adjusted strength | 1.35lbs pull force each instead of 1.5lbs each. 8.1lbs total pull force instead of 12lbs.
Weight
- New bottom-mounted design | The weight now mounts from the bottom instead of through the top of the bottom case half.
    - Magnet changes | 4 magnets with a 2.65lb pull force each used instead of 2 magnets.
    - Push pins added | 2 push pins added to aid with removing the weight after it has been mounted.
- Size change | The weight has been widened in order to make up for some lost mass due to the redesign.
- Adjusted clearances | The gaps between the weight and the case has been lessened.
Alignments Pins
- Adjusted placement | All alignment pins are now centered.
- Adjusted clearances | The gap between the pins and the mating slots has been lessened.
USB Port
- Adjusted placement | The USB port has been moved lower and recessed. Similar placement to the MB-44.
- Daughterboard change | The case now uses the open source db that MelonBred designed to accommodate the placement change.
Let me know what you think about the changes! Nothing is set in stone yet, so I'm open to feedback.
Here are some renders showing the changes.
« Last Edit: Sun, 16 January 2022, 00:56:51 by Zeus501 »
Offline Cujo26
« Reply #29 on: Sun, 16 January 2022, 03:21:02 »
This board is so cute! I quite like it
Please help I am trapped in your computing device
[url=https://geekhack.org/index.php?topic=112457.0]
Offline XCaellaX
« Reply #30 on: Sun, 16 January 2022, 15:14:22 »
Gorgeous board! Might be my first high-end 40/45% (acrylic or wine for me) if I convince myself I can use a 45 daily.
Super nice update, congrats! Bottom mounted & widened weight will look much better on acrylic (& on aluminum as well)!
USB looks much better there.
Can't say much on alignment & magnets without seeing the product, but you have my full trust!
Question : how is the weight (copper) attached to / keep together with the magnets? Glued? Same question between the magnets & the board (aluminum / acrylic).
« Last Edit: Sun, 16 January 2022, 15:25:12 by XCaellaX »
Offline Zeus501
« Reply #31 on: Sun, 16 January 2022, 16:23:20 »
Yep, the magnets are glued in!
Offline crystal
« Reply #32 on: Sun, 16 January 2022, 16:41:44 »
Polycarb so hot
Offline Zeus501
« Reply #33 on: Wed, 19 January 2022, 23:54:52 »
Been working on a knob design. Let me know you what you think!
281349-0
Engraving courtesy of the wonderful ocm!
Offline Jsdfbn
« Reply #34 on: Thu, 20 January 2022, 01:47:09 »
Damn this is sexy, can't wait to see when this goes live.
Offline WHITEHOTACTION
« Reply #35 on: Fri, 21 January 2022, 01:23:34 »
I really like this knob design. While board is awesome. Hoping to make this my first 40.
Offline hottrout
  • I'd Hit Dat Key
« Reply #36 on: Fri, 21 January 2022, 09:31:11 »
cute
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline billyli19
« Reply #37 on: Mon, 31 January 2022, 18:13:08 »
Finally a 45% that isn't sold out yet, hopefully I will be able to get my hands on one. Is there any way to subscribe for the GB yet? Sorry, I'm still new to the keyboard community and GB.
Offline Zeus501
« Reply #38 on: Tue, 01 February 2022, 16:19:03 »
Thanks for the interest and support! The best way to stay up to date is by checking in periodically on this GH thread or by joining the 40s discord (https://discord.gg/40percent) and grabbing the Paintbrush role.
Offline billyli19
« Reply #39 on: Tue, 01 February 2022, 16:21:25 »
Thanks a lot! Will do that :D
Offline DeMechanica
« Reply #40 on: Thu, 03 February 2022, 03:48:10 »
Offline ihaveaquestion
« Reply #41 on: Sat, 05 February 2022, 03:05:08 »
I want it ;-; I'll have a numpad on the left side and have my dream setup!
Offline MelonBred
Re: [IC] Paintbrush | A 45% Keyboard | Updated 5/8 - New Design!
« Reply #42 on: Mon, 08 May 2023, 11:38:25 »
Stoked to see that this project was being worked on in the background and in full swing again. Redesign looks great.
« Reply #43 on: Mon, 08 May 2023, 12:21:21 »
Back with a vengeance!
Offline delacruxkeys
« Reply #44 on: Wed, 27 September 2023, 06:06:51 »
still keen for this! just what I've been looking for
Offline giacombum
« Reply #45 on: Wed, 04 October 2023, 09:25:40 »
Great board! Is it possible to put a key in place of the rotary encoder, or not?
Offline bombay.duck
Re: [IC] Paintbrush | A 45% Keyboard | GB Date & New Vendor Announced!
« Reply #46 on: Wed, 07 February 2024, 17:16:12 »
So glad this is alive and kicking
Offline Zeus501
« Reply #47 on: Tue, 09 April 2024, 08:53:53 »
I'm super thankful to CBK for helping me out and reviving this project! Hopefully any potential future projects go smoother.
