Author Topic: [IC] Moza - 65% O-Ring Board  (Read 12307 times)
Offline Nixytheria
  • nix studio
    • Instagram
« on: Mon, 03 January 2022, 10:01:46 »
Moza
Hello Geekhack, I'd like to introduce my recent 65% keyboard Project.
Moza is a 65% Gummy O-Ring Mount and I'd like to bring some new typing experience with this Gummy O-Ring Mount with its Meme Cut Plate that comes together with 3.5mm Poron Rubber dampening foam between the plate and PCB. And also we are going to have 1.5mm Poron dampening foam underneath the PCB. Hopefully this scenario will bring different and better typing experience.
Prototype
We are planning to having a prototype in this Jan or next Feb after CNY
Specs
  • 6063 Monoblock Aluminium Case
  • 7 degree typing angle
  • 5mm Brass Weight Insert
  • FR4 Plate with Skeleton/Meme Cut
  • 3.5mm Poron Rubber Foam between the Plate and PCB
  • 1.5mm Poron Rubber Foam underneath the PCB
  • Hotswap or Solder PCB with Daughterboard USB
  • Comes with Carrying Bag
Plate, Layout and Dimension
Color Option
GB Details
The GB will be run by Mechs & Co. (US)
GB Date: TBA
Units: 500
Price: ETA $350
GB Timeline: TBA
Proxies
ASIA: iLumkb
OCEANIA: DailyClack
IN: StacksKB
EU:
CA: Ashkeebs
*This is just an initial information, I will update more once I got an update.
Follow us on Instagram
Join Our Discord
« Last Edit: Wed, 05 January 2022, 05:32:45 by Nixytheria »
Offline Fraaaan
Re: [IC] Moza - 65% O-Ring Board
« Reply #1 on: Mon, 03 January 2022, 10:08:56 »
Will you be getting prototypes? Any chance for ISO layout support? Any more plate options other than FR4?
Price looks pretty alright. GLWIC!
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #2 on: Mon, 03 January 2022, 10:12:01 »
Thank you for your reply, I'm considering alu plate as an option.
And we are going to have prototype in the meantime.
« Last Edit: Mon, 03 January 2022, 11:28:34 by Nixytheria »
Offline Ella
  • Why is it called an oven
« Reply #3 on: Mon, 03 January 2022, 10:29:44 »
Where fillet?
Offline Alejo1707
  • Gimme some more caps!
« Reply #4 on: Mon, 03 January 2022, 10:36:09 »
Are you aware that in some Latin American countries, "moza" means mistress in a vulgar way?
Sent from my GM1917 using Tapatalk
Offline pfcmickey
« Reply #5 on: Mon, 03 January 2022, 10:39:28 »
pleeeeeeeease tell me there's split spacebar support for this
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #6 on: Mon, 03 January 2022, 11:31:46 »
I didn't noticed that  :eek:
Where fillet?
Hello, Thank you for noticing that. I've updated the file with its revision for the fillet :)
Unfortunately, I have to say this is not supporting the split spacebar :(
Offline LittleAad
  • Hello
« Reply #7 on: Mon, 03 January 2022, 11:57:16 »
proto avail?
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #8 on: Mon, 03 January 2022, 12:02:53 »
proto avail?
We are planning to have proto in this month or next feb after CNY
Offline SDKCAMPING
« Reply #9 on: Mon, 03 January 2022, 12:25:14 »
That's a 65% fjell if i have ever seen one!, well, with lines on the bottom.
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline bisoromi
  • Formerly Duwang
  • owo
« Reply #10 on: Mon, 03 January 2022, 14:07:44 »
mmmmm i love barbecue
(credits to Kokaloo)
Offline IMZO
  • Matrix shill, and TKL WKL Lover
« Reply #11 on: Mon, 03 January 2022, 14:38:02 »
65% percent RS . looks nice
Current boards: Jane V2 CE , Matrix 1.2og Silver WKL , Matrix 2.0add coating black WKL, Matrix 2.0add WKL Coating yellow, Satisfaction75 R1 Cloud white, Korno65, Bloop65, HHKB Pro 2 white,Lin Whale Pink WKL, Gok 7v White, Gok 7v Black, Orion V3 Silver WKL, Orion V2.5 Red WKL, Geon F1-8x Silver WK, Haus65 BlueGray, Plume65, Vertigo, Frog TKL WKL GreenF13
Offline Rafa_n
  • stuffforrectangles.etsy.com
« Reply #12 on: Mon, 03 January 2022, 16:01:31 »
launching in 4 years for double the price like Sofia?
Offline C_L | Soup
« Reply #13 on: Mon, 03 January 2022, 16:40:22 »
Ribbed for pleasure/ Will be waiting to see how the protos turned out! Have y'all decided on which colors you will run?
Offline Afresh
« Reply #14 on: Mon, 03 January 2022, 17:08:13 »
This is nice!
Offline sup3r170va
« Reply #15 on: Mon, 03 January 2022, 18:32:18 »
Nice. I’m interested. A few questions:
1. Does the PCB support 1.5/1/1.5/7/1.5u bottom row? Looks like a yes but I want to confirm.
2. Are u considering half plates?
3. What is the expected weight of the board?
Offline lovebee.co
« Reply #16 on: Mon, 03 January 2022, 19:45:31 »
trying to understand the color options. is the top case a different color from the bottom case? can you mix and match? for example the navy top case is rendered with a grey/black bottom case, but then there’s another render of a navy bottom case. thank you and glwic!  :thumb:
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #17 on: Mon, 03 January 2022, 19:53:24 »
Grill Pan Bottom will be clean without any weight visible on it
Barbeque Grill mmm  :thumb:
RS So lit, but this is another thing  ;D
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #18 on: Mon, 03 January 2022, 20:02:53 »
What happen with Sofia is not a thing that I want, and I don't want anything like that happen again. I hope our main vendor can run this one in the meantime.
Hello, thank you for your reply
1. Yes it is supported, I will update the PCB Layout later!
2. I'm not thinking a half plate right now. But we will help to make the half plate and share it once the GB is finished.
3. The total weight is expected almost 1.5kg Unbuilt
Hello, Obviously this is a monoblock case (single piece case) so there is no top or bottom housing. the render is showing the top and bottom view and I make different color for some color identity.
Offline lovebee.co
« Reply #19 on: Mon, 03 January 2022, 20:17:50 »
got it! that makes sense. I am new to the hobby and unfamiliar with “monoblock” - thanks for clarifying!
