Author Topic: [IC] Sangeo65 // 65% gasket keyboard - date and price settled (time added)  (Read 17869 times)
Offline monstargear
    • Monstargear
Hello,
We are Monstargear in Korea. We've launched few keyboards and about to drop a new 65% keyboard.
It's designed after Sangeo60, share almost same internal structure.
"Sangeo" means shark in Korea. We named it after cute shark weight.
It's not San-Geo
Sangeo65
Estimate date
1st batch 22nd Feb, 2022  10am KST
2nd batch Mid April ~ May 2022
GB style :In-stock
Vendor : World wide - Monstargear
Price :
Soldering - $395
Hot-swap - $410
Kit include
Housing
Alu plate(Dark blue anodize)
PVD coated brass weight
Foam type gasket pad(Poron)
mute foam btw plate and PCB(KBD67 MK2 foam made by KBDfans)
Case foam(Poron)
Sangeo65 Stickers(New)
Coiled cable(TBD)
KBD67 MK2 PCB
Typing Angle : 7˚
Colour option
Grey - Blue PVD weight
Dark green - Gold weight
Navy - Ti rainbow weight(Available at 2nd batch)
White(+$10) - Blue PVD weight
Housing : Aluminum 6063
Weight : Gold UV coated brass, Blue PVD coat brass and Ti Rainbow PVD coat brass.
PCB
KBD67 MK2 hot-swap(+$15)/Soldering
Renders
More Renders
Sangeo65 1st Prototype typing video
To get more updates feel free to join our Discord server.
Discord link
« Last Edit: Sun, 20 February 2022, 18:10:18 by monstargear »
Offline expensive
Re: [IC] Sangeo65 // 65% gasket keyboard
« Reply #1 on: Mon, 10 January 2022, 01:58:48 »
nic
Sent from my SM-N960U using Tapatalk
Offline HappyB0T
  • I'm a Piggie
« Reply #2 on: Mon, 10 January 2022, 02:47:21 »
If monstargear is simply running this keyboard as a presale / GB are you looking for feedback?
Could you please show the bottom / side of the keyboard?
This looks a bit different than the 60 but it looks good. Totally different vibe with Winkey.
« Last Edit: Mon, 10 January 2022, 02:55:02 by HappyB0T »
Offline monstargear
    • Monstargear
« Reply #3 on: Mon, 10 January 2022, 03:08:23 »
I will add more renders soon. Sorry for the lack of renders. It share same side design with Sangeo60.
Offline PurpleOmega
« Reply #4 on: Mon, 10 January 2022, 04:43:06 »
Oh wow the Sangeo making a come back. Can't wait to complete my Sangeo collection  ;D
Offline whirlwind
« Reply #5 on: Mon, 10 January 2022, 06:06:26 »
No IC link,  is this an advertisement?
Offline depressedkeebs
    • Depressed Keebs
« Reply #6 on: Mon, 10 January 2022, 13:29:10 »
it's a bit high pitched for my liking, i don't see much to make it stand out of the rest of gasket mounted boards
Offline zea
  • yeh
« Reply #7 on: Mon, 10 January 2022, 17:23:07 »
would you consider doing another batch of sangeo60s?
Offline sup3r170va
« Reply #8 on: Tue, 11 January 2022, 18:18:44 »
Thanks, looks promising.
Does the (solder?) PCB support - 7u bottom row i.e. 1.5u/1u/1.5u/7u/1.5u instead of the 1.25u/1.25u/1.25u/6.25u/1.25u/1.25u configuration? Also, does it support stepped caps lock?
Is the USB port centred?
What is the front height of the Sangeo65?
Do you have pictures of the said blue PVD? It sounds interesting, but really depends on the shade of blue.
Thanks.
« Last Edit: Tue, 11 January 2022, 18:20:51 by sup3r170va »
Offline QWER|key
« Reply #9 on: Wed, 12 January 2022, 00:40:30 »
I prefer this to the 60...  but I'm seriously hoping there'll be a 75  ;D
Offline unusuaL_
« Reply #10 on: Thu, 13 January 2022, 13:14:58 »
i can't say the "-geo" without sounding vietnamese
collection: hibike 1/1, garderie tkl, casper60, hhkb pro2, matrix 2.0additional, f1-8x og
Offline Nurseh
  • Sorry for always apologizing
« Reply #11 on: Sat, 15 January 2022, 00:21:08 »
Nice to see it return, looking forward to more renders/info.
Offline monstargear
    • Monstargear
« Reply #12 on: Mon, 17 January 2022, 09:02:03 »
Thanks.
For the soldering PCB we are going to use KBDfans MKII V3 SOLDERED PCB. And I don't think it support that layout.
