Author Topic: [IC]NEO Palette G88 - Gasket Stacked Acrylic TKL Kit|Build Guide Anime Updated  (Read 17115 times)
Offline Patrickwu
Ladies and gentlemen, this is Patrick, owner and designer of NEO Keys(Discord, Instagram) .
I’m honored to present you with NEO Key’s 4th project and the first TKL model, Palette G88.
While most details of the design have been finalized, there are a few more that I would like to leave to the community. Please fill in the IC Form.
Palette G88 is the second model of Palette series following Palette G67, the first gasket mount stacked acrylic keyboard kit.
Palette G88 inherited the simple yet effective gasket mount structure and is further improved on material application and engineering precision.
Palette G67 was a budget friendly, high performance, fun to build keyboard kit. But it was far from perfect. With the great feedback and advice for improvement from NEO Keys customers and Discord community,
Palette G88 has received a few major upgrades:
- Acrylic material and design upgrade:
Palette G67 featured fully customizable acrylic colors. An unexpected downside is the inconsistency of acrylic plate thickness.
Thickness of different color varies from 2.2mm – 2.8mm. With a certain color combination, the case body could get too thin to allow any plate flex.
Between the dilemma of typing experience, performance, engineering precision and aesthetics diversity, Palette G88 went for the former.
Palette G88 uses a hybrid of 3 different types of acrylic material, 2.7mm frosted clear cast acrylic, 2.5mm clear extruded acrylic and 3.5mm clear extrude acrylic.
The result is 3.25mm PCB to case bottom clearance (vs maximum of 2.35mm clearance on G67), allowing a lot more plate flex; more consistent external dimension and internal structure; more consistent gasket compression ratio which also delivers better performance and typing sound.
Because 2.5mm and 3.5mm extruded acrylic plate is available in only clear, plate color customization and color tab design is no longer available for Palette G88.
- PCB and general case structure upgrade:
All stacked acrylic keyboards share the same inevitable design flaw, the cut-outs on lowest 3 layers for integrated USB-C port.
To resolve the issue, Palette G88 PCB does not have an integrated USB-C port, instead uses C3 Unified USB-C Daughter Board.
The cable that connects PCB and daughter board runs through the bottom layer, which is covered and protected by an acrylic housing.
Palette G88 thus has a fully closed case body. It is visually integral, structurally more rigid, robust and durable.
- Feet design upgrade:
Palette G67 uses stacked acrylic plate feet design. It has an angled contact surface with desktop, thus grip and stability could become an issue for those who don’t use a desk mat.
Palette G88 features a new locking mechanism that binds stack acrylic plates vertically, thus creating a perfectly flat and level contact, providing a much stronger grip against your desk, and no doubt looks much cooler.
- Plate material and finish upgrade:
Due to the large size of TKL keyboard layout and the natural lack of stiffness in acrylic case, softer plates material didn’t test as well as stiffer plates during prototyping stage. Brass plate came out as the final winner.
With some properly designed flex cuts, it provides a great balance between soft typing experience and crispy and clear acoustics.
To compensate the lack of case color options, the brass plate comes in 4 polished PVD finishes, gold, gun metal grey and rarely seen blue and purple!
- Hardware upgrade:
Brass standoff used on Palette G67 has some rust issues and its gold color will not universally work well with some darker plate color options such as gun metal grey and blue. Palette G88 will use all custom made anodized aluminum M2 standoff.
Palette G88 Specs
- Dimension -
364.6mm*140mm*20.6mm(front)/36.5mm(rear); 6.5 degree typing angle
- Case -
Case layout option: Standard, WKL
Case color option: Frosted clear
- Plate -
1.5mm brass, polished chrome plating + PVD finish
Layout options: Solder Standard, Solder WKL, Hotswap Standard, Hotswap WKL,
Color options: Angelic(gold), Tungsten(gun metal grey), Abyss(blue), Nova(purple).
Other options: With Palette Logo, Without Palette Logo
- PCB -
QMK programmable, VIA supported
C3 Unified daughterboard
Soldered version – TKL F13 layout; ANSI/ISO compatible; split backspace, split right shift and WKL supported; LED underglow; screw-in stabs only.
Hotswap version – WKL F13 layout; ANSI only; LED underglow; per key LED.
Renders
- Angelic -
Tungsten
- Abyss -
- Nova -
Estimated kit price: $180-200
Extra Plate and PCB will be offered, but I recommend purchasing them only as pack up spare parts or for your own keyboard design project,
as changing plate/pcb module involves taking apart and reassembling 6 pieces of acrylic plates and 20 screws.
For the sake of your time and sanity, picking up extra plate and pcb for another set of key switches is not a good idea.
GB starting in early-mid March.
Build streams coming soon at Twitch channels of these awesome keyboard builders:
MechMerlin | MechMerlin's Unboxing Video | MechMerlin's Build Video
Andy Nguyen | Andy's Build Stream VOD | Andy's Build From SCRATCH Stream VOD
Alexotos | Alexotos' Build Stream VOD
Manoli Visuals | Manoli' Build Stream VOD
Build Gude Animation
Stay tuned!
« Last Edit: Thu, 10 March 2022, 04:57:47 by Patrickwu »
NEO Element G67 Kit Groupbuy
Offline norb
Re: [IC]NEO Palette G88 - Gasket mount stacked acrylic F13 TKL kit
« Reply #1 on: Thu, 20 January 2022, 12:56:34 »
100% in! i love my palette g67! :thumb: :thumb: :thumb:
Offline hussar_name
« Reply #2 on: Thu, 20 January 2022, 13:53:52 »
Please don't use a proprietary PCB, will the case design be made available as DXF?
« Last Edit: Thu, 20 January 2022, 13:57:10 by hussar_name »
Offline atyxiao
« Reply #3 on: Thu, 20 January 2022, 16:28:27 »
Possibility of a plate without the "Palette" cut out for a cleaner look?
Offline hussar_name
« Reply #4 on: Thu, 20 January 2022, 17:07:04 »
Thanks for this ... I'm in the #nologo train too.
Offline Patrickwu
« Reply #5 on: Fri, 21 January 2022, 04:37:39 »
I somehow posted the thread while I thought I was editing it. Any added some pics and renders. build streams coming soon.
Offline Patrickwu
« Reply #6 on: Fri, 21 January 2022, 04:44:16 »
I will release plate files for both with and w/o logo versions.
but the plate that comes with the kit will have logo
Offline Patrickwu
« Reply #7 on: Fri, 21 January 2022, 04:45:44 »
No off the shelf PCB meeds my requirement sadly.
Case no, plate yes.
Offline Firahlol
Re: [IC]NEO Palette G88 - Gasket mount stacked acrylic F13 TKL Kit
« Reply #8 on: Fri, 21 January 2022, 05:22:37 »
As someone who has bought Element G67 from you, your support in discord, and the way that you take feedback, I am 100% going to support and buy this.
Looking forward to the GB!  :thumb:
« Last Edit: Fri, 21 January 2022, 05:55:06 by Firahlol »
Offline Handke
« Reply #9 on: Fri, 21 January 2022, 06:15:48 »
I hate the "palette" logo, feels so art nouveau.
Plus not compatible with existing pcbs and case not open source. Not sure that I'll join.
Offline Patrickwu
« Reply #10 on: Fri, 21 January 2022, 21:35:56 »
thanks for the feedback.
Added a question for no logo plate option in IC. Will let community decide.
I use PCB of my own design and supply chain due to lead time and cost.
Like Palette G67, case file is actually available to customers.
Offline hussar_name
« Reply #11 on: Sat, 22 January 2022, 03:03:40 »
Thanks, for that. I tend to prefer h88c compatible PCBs because I hot swap them, and I don't like to do it for each new keyboard.
Offline Patrickwu
Re: [IC]NEO Palette G88 - Gasket Mount Stacked Acrylic F13 TKL Kit
« Reply #12 on: Sun, 23 January 2022, 03:25:05 »
Added plate layout options, standard/WKL, with logo/without logo.
Offline Patrickwu
« Reply #13 on: Wed, 26 January 2022, 01:33:04 »
added MechMerlin's unboxing video:
https://www.twitch.tv/videos/1276246975
Offline Patrickwu
Andy V Nguyen is streaming a Palette G88 Abyss build right now
https://www.twitch.tv/andyvnguyen
Offline Patrickwu
Andy Nguyen's build stream VOD:
https://www.twitch.tv/videos/1290869531
Offline Patrickwu
Alexotos' build stream VOD:
https://www.twitch.tv/videos/1302550629
Offline lush_bunny
I really dig this. And those builds from Andy and Alex are really nice. GLWIC (and eventually, GB).
Offline Patrickwu
Manoli Visual's build stream VOD:
https://www.twitch.tv/videos/1307110106
Offline REI41
Looks quite nice! GL for the group buy, might look to pick it up.
Offline Porsha
  • Porshe best car
I'd add that to my collection, good luck with the gb!
Offline Patrickwu
updated with Andy and Merlin's new build stream.
Also considering adding lower cost plate options.
Offline Patrickwu
Updated build guide animation
Offline norb
gb when? i got cash on hand, gotta throw it out before someone finds out  ;D ;D ;D
Offline jiminojimi
Any updates on this?
