Author Topic: [IC] Foundation – γ (Gamma): Seamless, Screwless, F13 TKL, GB DATE: April 10  (Read 30681 times)
Offline AxolStudio
    • Axol Studio
281372-0281374-1
My take on a seamless, screwless F13 TKL. Designed around the use of heavy linear or tactile switches.
IC Form
Proto gallery
Case specs:
-   Case: 6063 Aluminum
-   Weight: polished stainless steel
-   Typing angle: 7 degrees
-   Width: 372.79 mm
-   Height: 19.18 mm (front), 34.77 mm (back)
-   Effective typing height: 24.65 mm
-   Weight: 2.9 kg excluding plate
-   Mounting method: Gasket mount
-   WKL or WK options
-   Plate options: FR4, Aluminum, Polycarbonate, Carbon Fiber
281376-2
PCB specs:
-   QMK/VIA compatibility
-   ESD Protection
-   Daughterboard: Unified C3 (USB C – Centered)
-   Soldered only
-   PCB will be opened sourced under non-commercial clause after GB ends.
281378-3
281520-4
Plate not final, will be adding stepped caps compatibility.
Plate will be open sourced under MIT license after GB ends. This includes a version without any flex cuts. Please feel free to experiment.
Pricing:
-      $630 USD with FR4 plate, $645 USD with other plate (CF, PC, Alu) @ 350 MOQ
-      Group buy date: April 10
Contents:
-      Keyboard Top
-      Keyboard Bottom
-      Weight (polished stainless)
-      PCB
-      Daughterboard + JST cable
-      Gaskets
-      Screws
-      Bumpons
-      MechandCo Carrying case
Vendors:
-      NA: MechsandCo
-      CAN: Deskhero
-      AUS: Dailyclack
-      UK: Prototypist
-      EU: MkbEU
-      SEA: Hex
-      CN: Frontier
Lead time: 3-4 Quarters.
Typing test
Prototype units are being sent out. Expect proper sound tests soon.
Alexotos
Remarks
Why no renders?
Renders are an artist's interpretation of an item. Prototypes are the item.
Discord
« Last Edit: Sun, 10 April 2022, 14:43:14 by AxolStudio »
Offline AxolStudio
    • Axol Studio
Re: [IC] Foundation – γ (Gamma): Seamless, Screwless, F13 TKL
« Reply #1 on: Thu, 20 January 2022, 22:11:36 »
Reserved
1/21/2022: Updated pricing and kit contents.
1/22/2022: Updated correct Effective typing height.
3/14/2022: Updated vendors, tentative GB date, sound test
3/19/2022: Updated open sourcing information of PCB and Plate
« Last Edit: Sat, 19 March 2022, 21:09:57 by AxolStudio »
Offline atl22033
  • Signature art by Shima
« Reply #2 on: Thu, 20 January 2022, 22:13:00 »
shut up and take my money
Offline Meepergon
« Reply #3 on: Thu, 20 January 2022, 22:13:30 »
Great first offering from TKLStudios!!
Can't wait to see this board in GB!
Offline Myu
« Reply #4 on: Thu, 20 January 2022, 22:13:47 »
Pog
Offline Alessio
    • YT Channel
« Reply #5 on: Thu, 20 January 2022, 22:14:15 »
what does the plate look like
Offline NivlakN
« Reply #6 on: Thu, 20 January 2022, 22:15:12 »
Metal rectangles yes
Offline yahoon
« Reply #7 on: Thu, 20 January 2022, 22:17:58 »
Very pog
Offline SkyBoy
« Reply #8 on: Thu, 20 January 2022, 22:20:29 »
Looks great! Can't wait for more info
Offline C_L | Soup
« Reply #9 on: Thu, 20 January 2022, 22:26:10 »
Great color choices for the boards! That side profile is a thing of beauty. Thanks for coming to IC with proto's, very good showing.
Offline nqbshas
« Reply #10 on: Thu, 20 January 2022, 22:38:47 »
Niceee. Looking forward further details..
Sent from my SM-G998B using Tapatalk
Offline nqbshas
« Reply #11 on: Thu, 20 January 2022, 22:39:21 »
Offline SDKCAMPING
« Reply #12 on: Thu, 20 January 2022, 23:01:09 »
this is only like the third or fourth board named foundation in the past month .... seems everyone wants to use that name lol
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline Nurseh
  • Sorry for always apologizing
« Reply #13 on: Thu, 20 January 2022, 23:04:20 »
Man that white and teal is clean! Good work m8  :thumb:
Offline cthalupa
« Reply #14 on: Fri, 21 January 2022, 01:35:33 »
TKL Studios finally releasing a TKL to the public?!
Good looking board.
Offline sagarsiddhpura
« Reply #15 on: Fri, 21 January 2022, 04:08:43 »
There is already an IC for a TKL board call foundation
Offline IOVERCALLHISTIOCYTES
« Reply #16 on: Fri, 21 January 2022, 04:17:18 »
Any chance we could have a teal top too?
Offline eriz
« Reply #17 on: Fri, 21 January 2022, 07:33:14 »
Very cool rectangle
Offline 7h3of7
« Reply #18 on: Fri, 21 January 2022, 08:58:32 »
Ne plate pics avail?
Also any pricing avail?
« Last Edit: Fri, 21 January 2022, 09:01:01 by 7h3of7 »
Current Board: OTD 356 Mini v1 Black
Offline Handke
« Reply #19 on: Fri, 21 January 2022, 09:05:10 »
Any chance of ISO & hineybush pcb?
Offline Sumthingasian
« Reply #20 on: Fri, 21 January 2022, 09:09:07 »
ne plateless avail
glwgb
Offline fropsie
« Reply #21 on: Fri, 21 January 2022, 09:50:59 »
That f-row spacing is questionable.
Offline AxolStudio
    • Axol Studio
« Reply #22 on: Fri, 21 January 2022, 10:42:09 »
Preference.
281391-0
Ill upload images of the proto plate later.
Check updated post.
See above
ne plateless avail
glwgb
Unforunately no.
Offline AxolStudio
    • Axol Studio
« Reply #23 on: Fri, 21 January 2022, 10:43:55 »
Colours are final.
Offline Handke
« Reply #24 on: Fri, 21 January 2022, 10:48:09 »
This group buy is original for the sake of it, to see how does it feel to be unique.
« Reply #25 on: Fri, 21 January 2022, 10:57:31 »
are the bumpons adhesive? at this price point i would expect an IM friction fit bumpon (which are available on mcmaster, just not in this shape) to cover the screw, especially since the adhesive on bumpons tends to be pretty beefy.
« Last Edit: Fri, 21 January 2022, 11:01:39 by Puddsy »
Offline AxolStudio
    • Axol Studio
« Reply #26 on: Fri, 21 January 2022, 11:08:13 »
Bumpons are adhesive, with extra bumpons to be provided. Theyre custom made, and the adhesive doesn't make the process of removing them difficult. Cost mainly comes from the top piece and the size of the board.
Offline Ella
  • Why is it called an oven
« Reply #27 on: Fri, 21 January 2022, 11:39:57 »
Yikes
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #28 on: Fri, 21 January 2022, 12:39:08 »
Are the bumpons used adhesive? If so, what will happen to the adhesion after accessing screws during multiple assemblies/disassemblies?
oops i just noticed puddsy's message
« Last Edit: Fri, 21 January 2022, 13:58:15 by hali »
Offline Laur
  • Formerly dudeship
  • gmk retro runic
    • wip
« Reply #29 on: Fri, 21 January 2022, 12:47:16 »
hali don't be dumb, you're just not supposed to build it more than once obviously.
Offline derpturtle
« Reply #30 on: Fri, 21 January 2022, 12:52:55 »
the polishing of the internal weight seems... superfluous to say the least, especially considering the fact that dissassembling the board to actually take a look at it once built will be annoying with the bumpon issue others have mentioned
Offline ManiacMarc
    • Twitch
« Reply #31 on: Fri, 21 January 2022, 13:21:33 »
I can't wait to see more of this.
Offline herfalerf
« Reply #32 on: Fri, 21 January 2022, 13:52:07 »
Am I wrong in thinking that due to the f-row spacing this is incompatible with readily available TKL pcbs?
Offline Sicowa
« Reply #33 on: Fri, 21 January 2022, 17:13:10 »
I think ive seen a roboco version of this no?
Collection: Khajit 60, Leopold FC980C, Pepper, Ex. Visa, Daedalus
pfp:https://twitter.com/kuroseP/status/1305179874429079553?s=19
Offline stidal
  • milo#3939
« Reply #34 on: Fri, 21 January 2022, 22:44:44 »
650 yikes
transition tkl // aksara ce // bully // valhalla // voyager // rs60 // adiuvare // ciel60 // jules // prime e // ut47.2 // sequence // bumper // q1 // gaff60
Offline SDKCAMPING
« Reply #35 on: Sat, 22 January 2022, 04:39:13 »
Can you share how you measured the front and typing height? I can't understand how it could be 19.18mm front, then 20.5 effective typing hight which is super super low (like frog), and without a xon ledge...
Offline CrazyAssMonkey
« Reply #36 on: Sat, 22 January 2022, 09:52:04 »
https://www.instagram.com/p/CQq-i1Anquu/
That? It does look quite similar. We should get that one.
« Last Edit: Sat, 22 January 2022, 10:03:19 by CrazyAssMonkey »
Offline AxolStudio
    • Axol Studio
« Reply #37 on: Sat, 22 January 2022, 11:55:47 »
I stand corrected, the effective typing height was measured wrong. Ive provided a diagram of the correct method of calculating said typing height. Correct E Typing height is 24.65
Previous measurement was from the lowest point of the spacebar keycap to the bottom of the case without bumpons.
281427-0
Offline AxolStudio
    • Axol Studio
« Reply #38 on: Sat, 22 January 2022, 11:59:03 »
Its adhesive, that being said its not particularly hard to get to the screw. You can lift up the corner of the bumpon without much issue and the adhesive stays on the bumpon.
281429-0
281431-1
Offline AxolStudio
    • Axol Studio
« Reply #39 on: Sat, 22 January 2022, 12:04:01 »
You are correct with this statement. Readily available PCBs such as H88 and such wont fit due to layout and the USB port location.
Offline spikedsynapse
« Reply #40 on: Sat, 22 January 2022, 14:50:59 »
This is really cool!
Offline mcpatty_mk
  • Formerly McPatty1926
« Reply #41 on: Sat, 22 January 2022, 23:34:38 »
SHEEEESHHHHHH this looks amazinggggggg. I think a clean engraving of some kind on the bottom of the board would look even cooler! Nice design overall though! I love it!
Offline Vanquish
« Reply #42 on: Sun, 23 January 2022, 22:11:41 »
I love this board. I do hope a friction fit bumpon would be considered.
Offline Handke
« Reply #43 on: Mon, 24 January 2022, 03:45:58 »
I will never buy a keyboard which has adhesive bumpons that need to be removed to access the screws. I've been through too many cheap keyboard. I'm not going to live in hell again.
Offline cthalupa
« Reply #44 on: Mon, 24 January 2022, 08:17:32 »
All bumpons suck, and I've not had great luck with the McMaster Carr friction fits, either, including on a variety of products higher end than keyboards. Kinda surprised it's something that factors in at all in people's decisions.
Offline Vanquish
« Reply #45 on: Wed, 26 January 2022, 22:41:17 »
Eagerly awaiting groupbuy details!
Offline AxolStudio
    • Axol Studio
« Reply #46 on: Mon, 14 March 2022, 01:39:33 »
Details updated, more to come soon.
Offline SDKCAMPING
I would like to see how big the weight is, it feels kind of expensive for a board with a smaller weight. I like the interesting spacing wth the Function row though
Offline AxolStudio
    • Axol Studio
Most of the cost comes from the top piece.
Dimensions in cad: 188mm x 50mm x 8.4mm
Images of the sample being measured provided. Keep in mind that its not a perfect measurement due to the way you measure with calipers. x-plane measurement was larger than my calipers allowed for.
283716-0
283718-1
283720-2
Offline phinix
Why $630?
For what? Another keyboard for such a high price.
I thought that Geon showed everybody with Frog TKL that it is possible to make it cheaper, or simply, ask less for this kind of keyboard.
Even if this one has gasket mount and few small differences, Still $400-450 would be closer to proper price.
