Author Topic: [IC] NEO KNOB KN01 | Industrial Designed Knob - Rotary Encoder  (Read 12476 times)
Offline neoknob
    • Neo knob
« on: Wed, 26 January 2022, 13:39:53 »
KN01
SINGLE KNOB FOR ALL ROTARY FUNCTION
EXPLODED VIEW
BEARING MOUNTED KNOB
KN01 comes with a bearing mounted knob which makes it wobble free.
PROGRAMING
Set your custom function to knob using VIAL software.
DIMENSIONS
PROTOTYPE
INTRO
KN01 is an industrial design knob for daily usage. It is made out of 6061 aluminium which is CNC turned and milled from a solid rod. You might have used other knobs but they are not as stable as this one, because this one uses a bearing mounted knob which makes it wobble free. It can be programmed according to your need. It can be used for video editing, volume, brightness, media player and many more. It also comes with an EC12 encoder with no detent which makes the knob as smooth as gliding on a butter.
Some of you might be having a question. Does it take click input?
Yes, it takes both rotary and click input. It was the most difficult part of design.
FEATURES
•   WOBBLE FREE KNOB
•   TYPE  - C PORT
•   POWERED BY QMK
•   VIAL CONFIGURATOR COMPATIBLE
•   2-Piece CNC Turned Aluminum-6061
Available in two Variants:
•   Knob : Black | Bottom : Black
•   Knob : Silver | Bottom : Black
Surface Finish:
Bead blasted and anodized
Pricing : $69.99
Please fill out this IC Form if you're interested : https://www.neoknob.com/kn01-ic-form
Product Page : https://www.neoknob.com
GROUP BUY IS EXPECTED IN FEB 2022
Contact
Email:support@neoknob.com
Please leave your feedback below
« Last Edit: Sun, 30 January 2022, 13:39:27 by neoknob »
Offline Sandy
  • Formerly cogitoergofemme
  • Sandy - Peach Tray Maker
    • the peach · studio
Re: [IC] NEO KNOB NK01 | Industrial Designed Knob - Rotary Encoder
« Reply #1 on: Wed, 26 January 2022, 13:46:24 »
Not bad I like the idea nad the price is good. It does look pretty close to the BNR1 although I know that you can only do so much with the shape it's just the two tone is literally a colorway they have. ano is sometimes hard to photograph but the ano quality looks a little noisy maybe a higher grit or polish the unit then chamfer after.
GLWIC
🍑C11🍑KWA.6🍑GPK60 47-GR1RE🍑Vast60🍑Rose60🍑EHKB🍑Viktus Sinne🍑Boop65🍑Jelly60 Pro🍑Fuji65🍑Ginkgo 65🍑S7.7🍑Treasure Type-9 II🍑Thermal R2🍑Jelly 60🍑
Offline treeleaf64
    • treeleaf64
« Reply #2 on: Wed, 26 January 2022, 14:55:33 »
where keybort ?
Everyone must pay the cat tax
Offline JQ27
« Reply #3 on: Wed, 26 January 2022, 15:52:54 »
Good to see wider knobs.
Offline mozaic
    • [IG] Mozaic
« Reply #4 on: Wed, 26 January 2022, 16:31:43 »
This looks heavy duty, but I would suggest that you rethink you're choice of MCU for the PCB. It's way too overkill for a knob with three function, especailly considering the chip shortage issues
Offline Hugs94
« Reply #5 on: Sun, 30 January 2022, 10:44:54 »
I think the MCU comment above is a good point. Maybe a different option could help reduce prices too.
« Last Edit: Sun, 30 January 2022, 11:08:30 by Hugs94 »
Offline Oddstag
« Reply #6 on: Sun, 30 January 2022, 11:50:43 »
I like it.
Offline neoknob
    • Neo knob
Re: [IC] NEO KNOB KN01 | Industrial Designed Knob - Rotary Encoder
« Reply #7 on: Sun, 30 January 2022, 13:53:25 »
UPDATE 31/1/2022
The name has been changed from NK01 to KN01, as it was similar to NovelKeys NK1.
Offline Oddstag
« Reply #8 on: Sun, 30 January 2022, 13:57:25 »
UPDATE 31/1/2022
Well now you might as well call it KN013!
Offline pngu
  • send noots
« Reply #9 on: Sun, 30 January 2022, 15:24:50 »
UPDATE 31/1/2022
KN08
Offline Revanized
« Reply #10 on: Sun, 13 February 2022, 14:50:54 »
This is an easy buy for me if it makes it through IC.
Offline Mecxs
« Reply #11 on: Mon, 14 February 2022, 06:03:27 »
This is Binepad. Neoknob is Binepad with a different brand name.
I assume because their awful track record of QC and customer support left them unable to run a GB with their old name.
The reason I know it's them is because they emailed me an ad for this GB at an email address I gave only to Binepad (I bought a BNR-1, which I eventually had to charge back because it just literally wasn't delivered and the shipping company they hired refused to respond to any messages about it).
I would strongly recommend avoiding this.
Offline neoknob
    • Neo knob
« Reply #12 on: Sun, 03 April 2022, 14:55:33 »
We are definitely going to change the MCU as of now ATMEGA324-MU cost around $10.
Offline neoknob
    • Neo knob
« Reply #13 on: Sun, 03 April 2022, 16:37:10 »
Anyone in for this?
« Last Edit: Mon, 04 April 2022, 12:12:00 by neoknob »
Offline dankthock
« Reply #14 on: Mon, 04 April 2022, 01:26:40 »
I certainly am. I now have a board with a knob but would like to switch to an alice layout without one. I still need the knob though.
Offline neoknob
    • Neo knob
« Reply #15 on: Fri, 08 April 2022, 15:14:03 »
Here's a good news. KN01 Price drop to $64.99
GB starts tomorrow.
Offline neoknob
    • Neo knob
« Reply #16 on: Fri, 08 April 2022, 15:28:07 »
GLWIC
Final Product will have better finishing closer to render.
