Author Topic: [GB]Class 65 v2-Coming  (Read 21529 times)
Offline Totoro
« on: Wed, 23 February 2022, 03:55:49 »
Hi,we are MM Studio.
It's been a long while since the in-stock FCFS, and as the request of many guys, our decided to relase the Class65 v2 GB. Class65 v2 carries our understanding of the classics and our insistence on practicality.
The updates for Class65 v2 as follows:
1. Color we retain the retro white, ano-black and ano-silver, Space Gray instead of E-pink.
2. We have added Ble version ,and the wired version will be equipped with foam in the location of the battery, you can also order extras filling weight.
3. Ble version solution is provided by Dana, the battery is 3000mAh, and support custom key change, Ble version without Capslock Light. The wired version will retain the Capslock Light.
4. the PCB space bar is optimized, and it should be noted that the Ble version only supports hot-swap layout.
5.We have also make some layout changes on the Plate - to go to the long slot, which is make the typing more consistent and more liner .
For more details on Class65 v2, pls refer our Class65 IC:
https://geekhack.org/index.php?topic=115182.0
GB Information
Sale Date:February 24nd, 2022, 20:00 GMT
Website:https://mmstudio.store/
Fulfilment: 60-90 days
Quantity:350pcs
Color:Retro White, Ano-Black, Ano-Silver, Space Gray
Price: USB version  $350
                      Ble version  $400
                        Shipping  $50
Extras cost
Hot-swap PCB:40$
Soldered PCB: 35$
Ble Hot-swap PCB: 65$
POM fixing plate: 35$
Foam Kit: 15$
Weights:40$
Renders
Pls join our https://discord.gg/Kv9PVyEZ2M to get more update,you are very welcome to join our small community!
Class65
 The Class65 designed by us, MMStudio, was inspired by
by the artist Florian Renner his take on the modern Gameboy gave us the idea to try to incorporate parts of its design into the board.
Please make sure to give feedback on the board on the IC FORM
Design Elements
The Class65 features a Macro column and an exploded 65 column, with a plateless design. It uses leaf springs gaskets in order to have a both soft and bouncy typing experience. There is an optional POM plate. To help give it a strong sound we implemented a hidden brass weight. We will offer two types of plates PCB mount and Plate mount. This option was done because we wanted to allow for others to chose what they wanted. The ease of access to stabs with plate mount, or the stronger connection with PCB mount. Final design decision was center USB-c Port because Centered life is best life.
With an expected price of 270 for the whole kit
The GB will be held on our site MMStudio
Breakdown
Poron kit (Foam is not required, only included for optional use)
Colors
Pink, Beige, Silver, Black
Renders
Mod Edit: Adjusted BBCode tag of two images to correct size ratio and avoid stretching. OP, feel free to remove this edit notice when you see it. :thumb:
« Last Edit: Wed, 23 February 2022, 08:57:10 by HoffmanMyster »
Re: [GB]Class 65 v2-Coming
« Reply #1 on: Wed, 23 February 2022, 08:58:25 »
Approved :thumb:
Please note that while it is fine to offer updates through a Discord server, all updates must also be posted here in this thread for any buyers who do not wish to join another communication channel.
Offline nickthaskater
« Reply #2 on: Thu, 24 February 2022, 00:26:24 »
Got my order in. Can't wait 👍
Offline azzipa
« Reply #3 on: Thu, 24 February 2022, 20:43:18 »
interesting board! is the weight included? i知 confused about ordering a weight since it is listed as [extra]. same with plate. is a plate included in the base price?
« Reply #4 on: Fri, 25 February 2022, 01:47:00 »
All boards include a pom plate.
The hotswap and solder boards do not include a weight. It is sold separately as an "extra."
The Bluetooth version includes a battery which goes where the weight otherwise would go (that is, you cannot use both the battery and weight at the same time).
Offline dokternik
« Reply #5 on: Fri, 25 February 2022, 17:35:20 »
Good lord I want this
« Reply #6 on: Fri, 25 February 2022, 18:32:22 »
« Reply #7 on: Fri, 04 March 2022, 10:35:20 »
Prototype incoming
Offline Getsome!!!
« Reply #8 on: Tue, 08 March 2022, 00:47:23 »
God damnit. Figures I take a month or 2 break from the hobby and miss out  on this dope keep. Bummer.
« Reply #9 on: Wed, 09 March 2022, 02:36:01 »
V2 prototype progress update
Offline syberghost
« Reply #10 on: Tue, 10 May 2022, 14:24:19 »
Approved :thumb:
Yeah, that's not happening. They haven't even sent out any newsletters, despite the store page recommending that as the best source of info.
I heard a rumor it's shipping, but I haven't heard a peep out of them since joining the GB.
yes, I'm the guy who put box jades on a Polaris
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #11 on: Tue, 10 May 2022, 16:15:42 »
Today announcement:
ォHow much wood could a woodchuck chuck if a woodchuck could chuck wood?サ
« Reply #12 on: Tue, 24 May 2022, 13:49:13 »
V2 deliveries have started - here's one in the wild:
Waiting patiently for mine :)
« Last Edit: Thu, 26 May 2022, 12:32:20 by nickthaskater »
« Reply #13 on: Fri, 27 May 2022, 17:48:49 »
First sound test of V2:
« Reply #14 on: Wed, 08 June 2022, 16:54:38 »
Received mine today. This thing is legit and MM Studio did an amazing job.
« Reply #15 on: Sat, 11 June 2022, 01:39:49 »
Sound test of my build:
Board: MM Studio Class 65 V2 - soldered, plateless, no foam
Switches: Gazzew Boba U4T Black 68g unlubed
Stabilizers: TX Rev 3 lubed with 205g0 and dielectric grease
Keyset: Drop MT3 Extended 2048
Naked PCB for clicks:
Offline syberghost
« Reply #16 on: Tue, 21 June 2022, 11:47:26 »
Wow, re-reading this, it seems more negative than I'd intended it.
Anyway, typing this on mine, and it's great.
288134-0
Offline Yung Thelonious
« Reply #17 on: Mon, 04 July 2022, 01:44:11 »
I know I知 way too late to this party, but will this ever be restocked/have extras sold? I知 fiending for these thick bezels.
Offline jetjagaa
    • Giga-Robo
« Reply #18 on: Thu, 07 July 2022, 15:05:36 »
A stock and B stock extras are on sale now: https://mmstudio.store/products/instock-class65-v2
« Reply #19 on: Fri, 08 July 2022, 12:48:43 »
Hellllllll yeah, thanks boyo! I picked one up a solid five minutes after I saw your reply lol.
