Author Topic: 【IC】Melody 96 Pro Case RGB Hotswap PCB Kit With Acrylic Bottom And Brass Weight  (Read 6339 times)
Offline vincent88928
  • Have Fun Everywhere
    • YMDK
We are preparing to luanch a new GB for our YMD96 RGB hotswap V3 PCB kit.And this times,will come our newest melody 96 pro case that have acrylic bottom with brass weight.
283246-0
Case
Top part use aluminum designed,and anodized or powder coated.Weight 0.377 kg,size about 382*136mm.
Bottom part use acrylic with brass weight designed,CNC and anodized.Weight about 0.826kg,size about 381*132mm.
Angle about 5°.
Case height about 20-30mm
283258-1283260-2283262-3283264-4
PCB(Green as the sample,black for production)
Size about 360*112mm
Weight about 0.159kg
RGB South facing
Support VIA
VIA manual:(Will add it after GB,thanks for your understanding)
283248-5283250-6283252-7283254-8
Plate(9 pcs color in below)
Melody 96 plate and anodized,size about 366*118*1.5 mm,weight about 0.078kg
283256-9
Black-Clear Gold Wired Screw in Stabilizers
Weight about 0.019kg,use oil better,from this link.
Special note
Our old kit 1 or kit 2 case support this acrylic and brass weight bottom and RGB hotswap PCB.
GB gift of this times in Melody 96 Pro Kit(Only can choose one for one GB Kit)
1)A 1 key switch tester,one random switch.
2)5 usd for this GB in discount code.
Please note if you use the discount,there will have not the other Gifts.
3)A free assembly service for our new Kit,but need add switches and keycaps together.
4)A opportunity to get a free keycap in order(10 pcs order have one times)
When we confirm the information,will contact with you to provide some sets as option.
We will use a random number to confirm the winner.Such as 7,The 7th,17th,27th etc orders will get the free keycap set of option and email.
Price
New colors kit 228 usd
Old colors kit 218 usd
Only PCB 65 usd
Only acrylic bottom with brass weight 75 usd
Color option for Case
New Colors
283266-10
Old Colors(Plate color in below)
283268-11
IC in our new meoldy 96 pro kit,click here to website.
Contact us with email:david.chen@ymdkey.com
Contact us with discord:https://discord.com/invite/rvgWYRAacc
@Ymdkey
« Last Edit: Sun, 06 March 2022, 23:48:59 by vincent88928 »
Have Fun Everywhere
Offline cosmo10292
Ill take a PCB/Acrylic brass weighted bottom!
    • YMDK
Have Fun Everywhere
Offline vinorodrigues
Yes - I would buy this.
Offline Bakkoutou
I've been looking for a 96% keyboard, will there be a rotary dial choice available for this board? I'm interested in the full kit!
« Last Edit: Sun, 06 March 2022, 22:37:36 by Bakkoutou »
    • YMDK
We are considering to add it in this keyboard,but I am not sure what function needed.
1)Change volume?
2)Change the parameter in PS software?
3)More about this?
Have Fun Everywhere
Offline Bakkoutou
I was thinking about using the dial for volume control. Will this board be compatible with the YMDK96 PCB Plate Foam or will there be new foam addons available for kit?
    • YMDK
If so,let us consider the function.And it support our foam in middle of pcb and plate.
Have Fun Everywhere
    • YMDK
Let us open the GB here.
Have Fun Everywhere
