Author Topic: [IC] Treasure TYPE-9 Series III | 9 keys brass macropad  (Read 19411 times)
Offline Treasure
  • Industrial Designer / Inventor / Maker
    • Design & Eng
« on: Wed, 16 March 2022, 06:31:40 »
Hi everyone, this is the third edition of the Treasure TYPE-9 macropad we are making since 2017.
This new version will come with updated internals and new finish/color options.
Treasure TYPE-9 is a fully programable metal 9-keys keyboard, that can be used for shortcuts, as a Stream Deck or simply for Artisan display.
With QMK & VIA support, compatible with Windows, MacOS and Linux. It also works on iPad ( Works great on Procreate ).
Design-wise, it is a mix of rounded lines and sharp edges, a compact and timeless design that makes it stand out on your desk.
Features
  • 2-piece body construction ( Dedicated Plate and Case )
  • USB-C interface
  • In-Switch RGB LED
  • QMK & VIA support
  • Kailh Switch Sockets ( Or solder PCB as extra )
  • Low Profile custom silicone pads
What's in the box
  • 1 x TYPE-9 Case - Bead blasted anodized aluminum or PVD Mirror Polished brass
  • 1 x TYPE-9 Plate - Bead blasted anodized aluminum
  • 1 x USB-C to A Treasure Cable
  • 1 x TYPE-9 Series III Hot Swap PCB
  • 2 x TYPE-9 Silicone Feets
Brass Editions :
Full brass case ( 370gr )
  • Full Solid Brass / Jet Black ( Jet Black PVD + Mirror Polish )
  • Full Solid Brass / Purple Mirror ( Purple PVD + Mirror Polish )
Aluminum Anodized versions
  • Aluminum / Anodized Silver
  • Aluminum / Anodized Midnight Green
  • Aluminum / Anodized Purple
  • Aluminum / Anodized Matte Black
Aluminum E-coated versions
  • Aluminum / E-Grey
  • Aluminum / E-White ( Same finish as Series II )
  • Aluminum / E-Sable
  • Aluminum / E-Pink
For information,the following parts will be sold as extras during the Group Buy :
  • Extra PCB ( hotswap and solder )
  • Extra Aluminum plate ( Custom colors )
  • Extra Feets (Custom colors & Low profile version )
  • Treasure TYPE-9 Starter Kit ( 9 Custom Keycaps + 9 Keyswitches )
  • Treasure TYPE-9 Small Travel case ( Will be available in Red, Grey and Black )
Jet Black finish Prototype :
Other Info
Concerning the pricing, we are awaiting for final quanity before the definive pricing. For information the last run was $99 to $129 ( + Shipping )
Concerning the finish, Series III "Jet black" is darker than Series II's "Black Mirror" ( Jet Black is more akin to iPhone 7 Jet black )
Also, a lot of colors will be common with the upcoming Treasure TYPE-30 ortho keyboards,
For information, a clear PMMA version is also in the works, more info soon for this one.
And one more thing, thanks for your amazing support during the Series II run of the macropad.  :)
Below photos by @alexotos, @macherstudio @karanchauhan @tinymakesthing, @elyxyrine and @backslashrabbit  of TYPE-9 Series II
« Last Edit: Thu, 06 October 2022, 03:13:49 by Treasure »
Offline Treasure
    • Design & Eng
Re: [IC] Treasure TYPE-9 Macropad Series III
« Reply #1 on: Wed, 16 March 2022, 06:32:56 »
Reserved
Offline Sandy
  • Formerly cogitoergofemme
  • Sandy - Peach Tray Maker
    • the peach · studio
« Reply #2 on: Wed, 16 March 2022, 09:46:42 »
Glwic def my fav pad. You guys put so much care into the last one
🍑C11🍑KWA.6🍑GPK60 47-GR1RE🍑Vast60🍑Rose60🍑EHKB🍑Viktus Sinne🍑Boop65🍑Jelly60 Pro🍑Fuji65🍑Ginkgo 65🍑S7.7🍑Treasure Type-9 II🍑Thermal R2🍑Jelly 60🍑
Offline Treasure
    • Design & Eng
« Reply #3 on: Wed, 16 March 2022, 10:34:20 »
Hey, thanks for your support, glad you like the last one !
Offline FitLabb
    • FitLabb
« Reply #4 on: Wed, 16 March 2022, 11:13:49 »
Been looking forward to this GB for a while now, as I missed the last couple rounds!
Founder of FitLabb.com - an online fitness & nutrition platform
YouTube - FitLabb
Offline Nurseh
  • Sorry for always apologizing
« Reply #5 on: Wed, 16 March 2022, 11:34:00 »
Really glad to see this come back; looking forward to it!
Offline productkun
« Reply #6 on: Wed, 16 March 2022, 12:22:49 »
Looking forward to buying a purple one~!
Offline Zyrophr
  • https://zyrophr.com
    • zyrophr.com
« Reply #7 on: Wed, 16 March 2022, 14:30:34 »
Oui.
French keyboard streamer
Offline Treasure
    • Design & Eng
« Reply #8 on: Wed, 16 March 2022, 14:32:42 »
Merci !
Offline Treasure
    • Design & Eng
« Reply #9 on: Fri, 18 March 2022, 06:25:15 »
Closer look on the "Jet Black"  :D :
283870-0
« Last Edit: Fri, 18 March 2022, 06:46:13 by Treasure »
Offline Xuey
« Reply #10 on: Fri, 18 March 2022, 12:33:29 »
Such a good macropad, have one in white and this would be a good opportunity to get another...  :)
Offline MSA_Vision
« Reply #11 on: Sat, 19 March 2022, 06:22:37 »
Sic Parvis Magna
Offline Treasure
    • Design & Eng
Re: [IC] Treasure TYPE-9 Series III | 9 keys macropad
« Reply #12 on: Sun, 20 March 2022, 09:46:16 »
Yeah let's go !
Offline Treasure
    • Design & Eng
« Reply #13 on: Tue, 22 March 2022, 09:03:49 »
Travel case proto :
Offline Treasure
    • Design & Eng
Re: [IC] Treasure TYPE-9 Series III | 9 keys brass macropad
« Reply #14 on: Mon, 18 April 2022, 07:45:26 »
Hello to all, this is the red travel case sample ( With the Brass Jet Black TYPE-9 ) ! :
Offline EdgeOfInfinity
« Reply #15 on: Thu, 05 May 2022, 15:21:43 »
purple PVD looks bangin
Offline tsukune1349
« Reply #16 on: Fri, 06 May 2022, 02:57:01 »
I need it yesterday, merci  :thumb:
Offline infinitum
  • i buy expensive plastic
« Reply #17 on: Sun, 08 May 2022, 12:30:37 »
yes this is amazing
Offline digitalnothing
« Reply #18 on: Tue, 10 May 2022, 00:58:18 »
I'm always broke when these go live, hopefully I can get in this time
Offline bshendy
« Reply #19 on: Wed, 11 May 2022, 11:03:33 »
Only thing I could ever wish for (Which im not even sure if it's possible) is fitting a battery and bluetooth compatible pcb in that thing so you can really make it a pocket macropad. Will cop nonetheless
Offline LumiP
  • A lil Faedude on the net. Fave layout is FRLTKL!
    • Sometimes I do builds on Twitch! :3
« Reply #20 on: Sun, 15 May 2022, 13:25:09 »
I definitely need one. Will be keeping an eye on this!
Current Boards: Aaru TKL (Old Dark Sand) | Drop + Planck (Purple) | Mr Suit WKL (Black w/Gold Chamfers) | Sangeo60 (Black) | KBD67Lite (White) | D45 (E-Grey) | Wind X (Pink) | NCR 80 (Beige) | QK65 (Dark Green) |Av4 Claymore | TGR x Monokei Tomo (Suave Blue) | Heracles80 (Holy White) | Snake60 (Rust) | Array (E-White) | Capsule (E-White) | QK75 (E-White) | | QK80 (Black) | Envoy 65 (Clear PC) | Mode Sonnet (Ice Blue) | Cycle 7 (Lavender, E-White) | Neo70 (Retro White, Black) | Reflection (Chocolate) | Matra Alice 90 (Glossy Red) | Haven TKL (Silver/Red) | Baldur64 (Black) | XOX70 (Bonsai) | SWISS | Cycle 80 (Zeal)| QK80 MKII (Pink) | Polygon 7 (Grey) | QK75N (Smile Yellow) | Han80 (Beige) | THE BASE (Black) | NV-70 (Silver) | Matrix Carnival (Asagao Purple)
Offline Treasure
    • Design & Eng
« Reply #21 on: Mon, 16 May 2022, 05:59:16 »
Bluetooth is not in our plans at the moment
Hey thanks for your support !
Offline Treasure
    • Design & Eng
« Reply #22 on: Tue, 09 August 2022, 07:08:11 »
Hello to All
Hope you are doing well ! Thank you for your feedback for the macropad.  :thumb:
We received the final anodized and brass cases samples this week, so the GB sale will start very soon.
You still can fill out the survey to be notified at the start of the GB here : http://tre.sr/type9ic
Extra Accessories will include : Travel Case / Custom color feet / Aluminium plate
Offline acaban
« Reply #23 on: Fri, 26 August 2022, 11:30:50 »
I'm really liking the minimal design of this macropad and the polished brass, is there any planned date range for the GB?
Offline Treasure
    • Design & Eng
« Reply #24 on: Tue, 30 August 2022, 04:06:33 »
Yes, the GB will start in September.  ;D
More details to come.
INTEREST CHECK FORM
« Last Edit: Tue, 30 August 2022, 08:57:27 by Treasure »
Offline infinitum
« Reply #25 on: Wed, 31 August 2022, 13:09:37 »
cant wait for gb
Offline vladimir108
« Reply #26 on: Sat, 03 September 2022, 07:27:35 »
idea: would be possible to buy extra keycaps please?
example: i will buy with purple macropad purple keycaps, but I would like to buy also extra set of 9 white.
Thanks for considering!
Offline Treasure
    • Design & Eng
« Reply #27 on: Fri, 30 September 2022, 11:30:09 »
Here’s our official announcement for the upcoming macropad drop ! 💛
Treasure TYPE-9 ( Series III ) Group Buy will start September 30th  ( 02:00PM EDT / 08:00PM CEST ) on our website http://treasuretypes.com/
We are proud to present our new finishes : Matte Black, Purple, Silver, Green, Jet Black Mirror (Brass) and Bronze Gold Mirror (Brass), E-White is back. 🔥
TYPE-9 Series III prices:
$99  for Aluminum / Matte Black & Aluminum / E-White ( For the 100 first backers then $119 afterwards )
$119 for Aluminum Versions
$159 for the Special Editions full Brass ( Jet Black Mirror and Bronze Gold Mirror ).
Features:
Crafted from Aluminum 6061 or Solid Brass
USB-C interface
In-Switch RGB LED
Switch Sockets (hot-swappable/no soldering required)
PCB compatible with QMK firmware / VIA
Low Profile custom silicone pads with 3M adhesive
Finish:
Aluminum Versions : Beadblasted Anodized Aluminium
E-White Version : Beadblasted Electrophoresis coated Aluminium
Brass Special Editions : Mirror Polished PVD coated Solid Brass
Contents :
1 x Case ( Beadblasted Aluminum / PVD Coated + Mirror finish Brass )
1 x Plate - Bead blasted anodized aluminum ( Grey color )
1 x Treasure USB-C Cable
1 x Treasure TYPE-9 ( Series III ) Hot Swap PCB ( In-Switch RGB LED)
2 x Custom molded TREASURE Foot ( Silicone - Grey )
1 x Cleaning Cloth ( Brass Special Editions only )
Quick Start Guide
Screws + Screwdriver
Packaging
WEIGHT ( built with keycaps - Estimate )
150gr ( Aluminum version )
360gr ( Brass versions )
Optional Extras :
TYPE-9 Feet  ( 10 available colors )
TYPE-9 Plate ( 4 available finishes )
TYPE-9 Carrying Case ( Grey and Red )
TYPE-9 DSA Line - Keycap Set ( WoB and BoW )
TYPE-9 PCB
Group Buy Opens: September 30th, 2022 @ 08:00PM CEST ( Duration: 1 month )
Estimated Ship Date: Early Q2 2023
Offline fantasyrunner
« Reply #28 on: Tue, 04 October 2022, 22:46:37 »
Looks awesome, is the the one under the green in the photo above the matte black? Looking forward to it!
« Last Edit: Tue, 04 October 2022, 23:15:18 by fantasyrunner »
Offline Treasure
    • Design & Eng
« Reply #29 on: Wed, 05 October 2022, 01:37:49 »
Yes it is the green.
The GB is live ( geekhack post : https://geekhack.org/index.php?topic=118485.msg3142480#msg3142480 )
