Author Topic: [IC] EVIL TROY 92 With numeric keypad  (Read 19656 times)
Offline EvilKeyboard
« on: Fri, 18 March 2022, 09:26:43 »
This project originally started in 2020 but due to unsatisfaction of surface finish, the project was put on hold. This year we found a better surface finish factory and we felt like we could start it again. At the end of 2021, we updated the project, and please allow me to introduce you our Evil Troy 92
Evil Troy 92
7 degrees
Poron Gasket Mounts/ Silicon Gasket Mount (Both options)
Hotswap Only
On board Type C / Aviator Connector Optional
Default RGB Name Plate (Aviator Module Optional)
Standard Layout with Per Key RGB PCB or Supports Split Left Shift, Step caps lock and split back space with rgb PCB
Aluminum Housing with Brass Weight
Brass Insert for the back logo
Alumimnum Plate / PC Plate
Originally rendered in 2020
(At that time, we also designed a separate keycap set to match the color)
Revised version renders
Renders of revised version(Prototypes were made with this version)
Revised version will be compatible with RGB Nameplate and Aviator Plug
Revised Version Raw Prototype (The final product is subject to change)
We used two fixed methods
In the revised version, we have added a separate aviation plug (The final product shall be subject to the integrated scheme)
We have added a glass module at the logo on the back.
You can choose whether to install or not. The glass is fixed by rubber rings, which is very convenient to install and disassemble.
The foot pad has also been modified and improved. Now the foot pad is integrated with silica gel, which can be disassembled and replaced freely, which is more convenient.
We are already making new prototype based on the revision. We will update it in the post if there are new developments in the follow-up. If you have good suggestions, you can leave a message to us. Thank you.
« Last Edit: Fri, 18 March 2022, 23:39:15 by EvilKeyboard »
Offline SxM Designs
  • https://sxmdesigns.com
    • Website
Re: [IC] EVIL&TROY 92 With numeric keypad
« Reply #1 on: Fri, 18 March 2022, 09:35:51 »
Pics?
Offline Alejo1707
  • Gimme some more caps!
« Reply #2 on: Fri, 18 March 2022, 09:59:56 »
Interesting
Sent from my GM1917 using Tapatalk
Offline xiaoxuesheng
« Reply #3 on: Fri, 18 March 2022, 10:29:26 »
laji huan  ;D ;D ;D
Offline yrneh
Re: [IC] EVIL TROY 92 With numeric keypad
« Reply #4 on: Fri, 18 March 2022, 12:42:39 »
oooh very interested
« Reply #5 on: Tue, 22 March 2022, 21:12:47 »
Offline Kacperoni
« Reply #6 on: Tue, 22 March 2022, 21:15:17 »
Beauty
Sent from my iPhone using Tapatalk Pro
Offline superjackie
« Reply #7 on: Wed, 30 March 2022, 02:45:24 »
OMG! This is an amazing layout for me. I never use the winkey in my life and I do sometimes use number pads for work. I'd super excited for this board!
I prefer a hotswap pcb and I know lots of people like hotswap option.
Offline superjackie
« Reply #8 on: Wed, 30 March 2022, 02:52:28 »
What's the best way to keep in touch with the updates for this board? Discord? Geekhack? Instagram?
Offline InvidiousIgnoramus
« Reply #9 on: Wed, 30 March 2022, 03:24:03 »
I like how you looked at the 1800CP layout and thought, "Wow, that is really functional! But how can I make the numpad utterly useless?"
I long for the day when I find a beamspring. (At a not insane price)
Offline Faceman76
« Reply #10 on: Wed, 30 March 2022, 04:13:10 »
Unless you don't need a +, -, or ENTER key, lol.
Sent from my SM-G975U using Tapatalk
1800s and heavy springs
Offline superjackie
« Reply #11 on: Wed, 30 March 2022, 21:07:32 »
There seem to be 6 screws on the brass weight and 4 more screws on the bottom case. Is there a way to make it screwless or reduce the number of screws?
The black color rendered case seems a bit dark grey(maybe it's just my phone), hope the final color is a "darker black" color. Like really black.
Flex cut alu plate seems to be very popular, look forward to seeing the typing flexibility of this board. Assume this layput is greatly suitable for office works, a flexible typing experience would be great.
Offline Psyquack
« Reply #12 on: Wed, 30 March 2022, 23:21:59 »
There are some cool aspects. I like the glass insert. That said, I just can’t get over the numpad. Removing enter, -, +, etc seems to defeat the purpose of it.
Regardless, good luck with the project
Offline AuroraCamo
« Reply #13 on: Thu, 31 March 2022, 00:56:59 »
Just wondering, where would the numlock key be?
Also there seems to be a missing 3, 4, 6, 9, 0, ., and / from the sub legends in your guys renders. Might wanna take a look at that
Offline superjackie
« Reply #14 on: Thu, 31 March 2022, 02:13:28 »
I love the idea of not having the -, +, enter keys. I sometimes use the numpad for work such as Excel or other apps just to enter a whole bunch of numbers, but rarely used the -, + keys because I'm mot using nu
pad as a calculator.
Also not having the full numpad reduces the width of this compact "full size" board.
Do you guys have Discord? Any estimated timeline for this board?
« Reply #15 on: Thu, 31 March 2022, 09:08:12 »
In the new design, we have reduced the two screws in the middle. The gray color is the reason for rendering the image
« Reply #16 on: Thu, 31 March 2022, 10:51:43 »
Thank you for your praise, winkey can also choose
« Reply #17 on: Thu, 31 March 2022, 10:53:58 »
I will update the progress on geekhack and instagram. Instagram account: evilkeyboard_ huan
« Reply #18 on: Thu, 31 March 2022, 10:56:54 »
I have registered instagram. Instagram account: evilkeyboard_ Huan, it's estimated that we need to wait for new samples
« Reply #19 on: Thu, 31 March 2022, 11:03:15 »
What does the EVIL ABED keyboard look like then?
« Reply #20 on: Thu, 31 March 2022, 22:53:13 »
Sorry, I don't quite understand what you mean
Offline salgiza
« Reply #21 on: Fri, 01 April 2022, 03:37:24 »
Lol, I'm happy to know that I'm not the only one that thought that after seeing the title of the thread.
Evil Troy and Evil Abed are characters from the Community TV Series.
« Reply #22 on: Fri, 01 April 2022, 03:40:22 »
Hahaha, you are so funny
Offline superjackie
« Reply #23 on: Fri, 01 April 2022, 22:53:21 »
Any timeframe for the GB?
« Reply #24 on: Sat, 02 April 2022, 02:30:40 »
free shipping
« Reply #25 on: Sat, 02 April 2022, 22:37:04 »
The time is uncertain, because the new samples are still being processed.
Offline superjackie
« Reply #26 on: Tue, 05 April 2022, 02:02:47 »
What are the dimensions? Does alu plate have flex cut? Does pcb have flex cut? WKL possible?
« Reply #27 on: Tue, 05 April 2022, 05:41:05 »
Size 360 * 133 * 35mm, slope 7 degrees, ALU plate have flex cut (as can be seen in the photo), PCB have flex cut and WKl can be selected.
Offline superjackie
« Reply #28 on: Fri, 08 April 2022, 09:46:36 »
Are color options confirmed?
« Reply #29 on: Tue, 12 April 2022, 00:27:06 »
The color has not been determined yet. In addition to the ink splashing anode, we have also added coating coloring
Offline superjackie
« Reply #30 on: Tue, 12 April 2022, 09:14:23 »
Nice. Looking forward to the colors/renders.
Offline superjackie
« Reply #31 on: Fri, 06 May 2022, 00:35:42 »
Any update?
Offline MortalKonga
« Reply #32 on: Fri, 06 May 2022, 13:32:34 »
It looks much more enticing with ISO support. I'm looking forward the updates.
« Reply #33 on: Fri, 06 May 2022, 20:37:04 »
Any update?
There are updates. The new samples have been received. They have just been updated in INS. Thank you for your attention.
Offline superjackie
« Reply #34 on: Thu, 09 June 2022, 23:54:53 »
Monthly update time. When will colors be confirmed?
Offline Tommy206
« Reply #35 on: Tue, 14 June 2022, 14:36:27 »
Looks amazing. Would be the perfect keyboard to use at work.
Offline BUTTER KEYBOARDS
    • BUTTER KEYBOARDS
« Reply #36 on: Tue, 14 June 2022, 18:34:55 »
Do yall have a website or IG?
Offline Hentoys
« Reply #37 on: Tue, 14 June 2022, 22:43:28 »
I love it! What a neat way to plug in your board.
Offline superjackie
« Reply #38 on: Wed, 01 March 2023, 02:13:30 »
project gone?
