Author Topic: [IC] Mechlovin' Exclusive E6-V2 & UTD 356 Mini Compatible PCB  (Read 10735 times)
Offline flying1911
    • Mechlovin' Studio
« on: Thu, 24 March 2022, 04:45:23 »
We continue our quest for making PCBs compatible with old and “non-standard” boards. After difficult projects such as OTD and Duck (Jetfire & Black Bird) and many other revival projects that we’ve done in the past, there’s probably not that much left to tackle, but there’s one that’s always been on the back of our minds: an Exclusive E6-V2 compatible PCB.
We initiated this project in early 2020 and finished drawing up a basic design soon after that. The special (and difficult) aspect about the E6-V2 PCB is that it has a non-standard switch spacing on the “custom” PCB version with a middle USB connector. There was another version with standard GH60 footprint, and since it’s standard, it is not the subject of this project. To be clear again, only the Non-standard E6-V2 PCB with centered USB port will be made.
Interestingly enough, we were recently asked to look into an UTD 356mini compatible PCB, and accidentally found out that it has the exact same switch spacing as the E6-V2 PCB that we’d been working on. The main difference is the spacebar stab orientation (south on the E6-V2 and north on the UTD), and we're thinking about whether we should separate this design into 2 versions (one north and one south) or make a hybrid one that supports both orientations. This decision will be informed by the form responses.
Current PCB design is basically final, and we’re waiting to test a final prototype before posting the GB. It is based on our latest Kay60 design, which is already QMK and VIA compatible. Some further specs and options to be considered:
• PCB thickness and material: FR4, 1.6mm or 1.2mm?
• Flex cuts
• Powered by Atmega32A MCU
• Supported layouts: 6.25U & 7U, ISO & split backspace supported
• RGB underglow (for E6-V2 sideglow)
• USB TYPE-C: 100% working on the E6-V2. Is a tight fit on the UTD 356mini, but should still work.
• MX Only
• ESD protection blah blah
• PCB color: will probably do red.
PLEASE FILL OUT THIS IC FORM
JOIN MECHLOVIN' DISCORD
Q & A
Q: When is the GB?
A: We're waiting to test the final prototype. GB should go live mid-end April.
Q: Will you make plates?
A: We have a working plate file (based on our own research and measuring) for the E6-V2, and are on the fence whether we should offer plates in the upcoming GB. Form responses should inform this decision. In any case, the file will be checked again and open-sourced for your own plate cutting pleasure.
Q: What about other Exclusive boards?
A: Our upcoming Kay65 PCB is compatible with the E6.5. It will be in stock on our site. We also did some research on the E7-V1 and had an initial design, but haven't really had the time to follow up. We'll revisit it if there's enough demand.
« Last Edit: Mon, 28 March 2022, 01:49:16 by flying1911 »
Jane V2 | Jane CE | Jane V2 CE | Police | Kaze | KMAC 2 | BRG Haus | Sessantacinque | Ori CLS-2 FE | Dalco 959 Mini | Mechlovin' Unikorn | G81-3100 SAV | Model M SSK
Offline soloplayer
Re: [IC] Mechlovin' Exclusive E6-V2 & UTD 356 Mini Compatible PCB
« Reply #1 on: Thu, 24 March 2022, 07:04:09 »
GLwIC
p.s: em yeu anh
Offline treeleaf64
    • treeleaf64
« Reply #2 on: Thu, 24 March 2022, 08:03:43 »
 :D :D :D :D  Ayaya ayaya ayaya ayaya
Everyone must pay the cat tax
Offline IMZO
  • Matrix shill, and TKL WKL Lover
« Reply #3 on: Thu, 24 March 2022, 10:15:53 »
ayyyy lets go
Current boards: Jane V2 CE , Matrix 1.2og Silver WKL , Matrix 2.0add coating black WKL, Matrix 2.0add WKL Coating yellow, Satisfaction75 R1 Cloud white, Korno65, Bloop65, HHKB Pro 2 white,Lin Whale Pink WKL, Gok 7v White, Gok 7v Black, Orion V3 Silver WKL, Orion V2.5 Red WKL, Geon F1-8x Silver WK, Haus65 BlueGray, Plume65, Vertigo, Frog TKL WKL GreenF13
Offline Mowo
  • Criminal Mastermind
« Reply #4 on: Thu, 24 March 2022, 11:25:45 »
Been wanting this forever, im in.
Offline HappyB0T
  • I'm a Piggie
« Reply #5 on: Thu, 24 March 2022, 13:08:20 »
Interested :D!
Offline Malvix Studio
    • Malvix Studio
« Reply #6 on: Thu, 24 March 2022, 19:14:44 »
Consider this interest checked! 1.2mm CEM-3 PLEASE
Offline mou$e
« Reply #7 on: Sat, 26 March 2022, 06:13:08 »
Will UTD356Mini plates be offered as well?
Offline pr0ximity
« Reply #8 on: Sat, 26 March 2022, 06:32:30 »
Interested to see if a USB-C would fit in an OTD mini… 🤔
Offline flying1911
    • Mechlovin' Studio
« Reply #9 on: Mon, 28 March 2022, 03:10:28 »
We really appreciate your interest and input. Taking the responses so far in consideration, we'll probably make 2 separate versions for the E6-V2 and the UTD 356mini. E6-V2 plate is likely to be offered in FR4 only, and the plate file will be published after GB fulfillment. No plans for the UTD 356mini plate at the moment, and we'll try to work on a plate file later.
Please note that the UTD 356mini compatible PCB WILL NOT WORK on the OG OTD 356mini, due to the different switch spacing. We might work on the OTD 356mini later, but having worked on the OTD TKL before, we're sure it's going to be a very difficult project.
Offline flying1911
    • Mechlovin' Studio
« Reply #10 on: Fri, 22 April 2022, 02:32:24 »
Update: Final prototype approved.
Fitment confirmed for UTD 356 Mini as well (see pic)
The GB will be run early May. 2 PCB variants will be made available: South-facing with RGB underglow for E6-V2, and North-facing without RGB for UTD 356 Mini. We're still thinking about whether we should do FR4 plates, but in any case, plate files for both E6-V2 and UTD 356 Mini will be made publicly available.
Offline C_L | Soup
« Reply #11 on: Fri, 22 April 2022, 19:48:53 »
 :thumb: Can't wait, thanks for all the hard work to give more options for the UTD!
Offline prelude46
« Reply #12 on: Sat, 23 April 2022, 12:55:23 »
Interested! Would this work for E6-V2 R2 boards too? I wasn't part of the R1 buy so I wasn't sure if R1 and R2 use the same PCB. Thanks!
Offline flying1911
    • Mechlovin' Studio
« Reply #13 on: Mon, 30 May 2022, 05:48:48 »
Group buy is live in case anyone misses it: https://geekhack.org/index.php?topic=117303.0
Offline jacky
« Reply #14 on: Mon, 30 May 2022, 09:05:47 »
E6-V2 classic one  :D
Offline deska
« Reply #15 on: Wed, 01 June 2022, 09:20:24 »
Agreed!! Need this ASAP
Offline lampmk
  • box art peddler
« Reply #16 on: Mon, 18 September 2023, 13:40:48 »
Will there be any more runs of this  :-[ my e6v2 has finally given out on me
My collection -
Ovinnik - Spyder TKL - FMJ TKL - Keycult 1/60 Raw - Lin Whale - Duck Lightsaver V1
